Window Rubber
Window Rubber
Postby Mickmon [OP] » May 10th 2020, 11:32am
HI,
i have a 1997 Astro AWD Tiara. The outer rear side window rubbers have shrunk in places and wanted to replace. I live in the UK and was looking for somewhere i could by replacements. Happy to purchase from anywhere.
Thanks Mick.
Mickmon
Alias (AKA): Mickmon
Extra Info: Tiara AWD
  • Window track rebuild
    by smokinjoe » June 18th 2020, 5:17am in Exterior
    Last post by smokinjoe View the latest post
    June 27th 2020, 5:25am
  • Advice on sealing up this loose window/weather strip?
    by pottsitive » July 13th 2020, 6:53pm in Exterior
    Last post by pottsitive View the latest post
    July 14th 2020, 6:35pm
    12
    December 2nd 2020, 5:27pm
Re: Window Rubber
Postby Rinny » May 10th 2020, 12:49pm
DomSan might have some info on that. He is going to need some also, I doubt he will he use the old ones.
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full years
Images: 6
Extra Info: 5.7L NP236
Re: Window Rubber
Postby augidog » May 10th 2020, 3:04pm
Mickmon wrote:HI,
Thanks Mick.
welcome. You could start by checking with Steele Rubber Products. I'm not affiliated, but I AM a happy recipient of excellent customer service. They have tons of universal extrusions. Heck, your inquiry may even prompt them to develop the part in question, they're that good.
https://www.steelerubber.com/search?yea ... senger-van
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Re: Window Rubber
Postby Wiley » May 10th 2020, 5:31pm
I would be surprised if you can find them, and they do not come out of old vans at a junk yard. The rear window I cut out came with one even though the other windows on my van did not have the rubber molding you mention, I left it both for a more secure fit, and cause it would have been difficult to remove.
I think you will need to use a black sealant and use your finger to try and just try to make it look ok.
2guys1truck.com: 2004 AWD Chevy Astro from California to Colombia!
Wiley
Years of Membership: Wiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full yearsWiley has been a member for 6 full years
Topics: 7
Extra Info: AWD 2 inch Lift
Re: Window Rubber
Postby 90safari » May 11th 2020, 12:34am
augidog wrote:
Mickmon wrote:HI,
Thanks Mick.
Failing that, you might want to look for some urethane in a tube (3m window weld). Don't know which you'll find easier. You could always try Woolies, and see what they have that might work.
867378671386681
90safari
Firing on 1 Cylinder (L2)
Topics: 5
Images: 160
Van Model Year: 1990
Extra Info: plus an 88 Astro
Re: Window Rubber
Postby Mickmon [OP] » May 12th 2020, 1:23pm
Hi,
thanks for all your advise.
Mick
Mickmon
Re: Window Rubber
Postby Wiley » May 12th 2020, 4:39pm
90safari wrote:Failing that, you might want to look for some urethane in a tube (3m window weld). Don't know which you'll find easier. You could always try Woolies, and see what they have that might work.
In the USA they sell a back roofing sealant at Home Depot that I used to stop my leaking windshield (due to Jeep guys using it with success), but now I think HD has started to sell a black Polyurethane sealant as well, but the roofing stuff is great.
Wiley
Topics: 7
Re: Window Rubber
Postby MechBob » May 12th 2020, 6:26pm
Being a Tiara, your rear side windows should be aftermarket.Tiara went out of business quite some time ago.A good chance your windows are "pop in", where the seal actually holds them in, instead of being glued in. I recommend drive it by one of your better caravan places over there, a good parts man might be able to fix you up with seals, but, like older caravans, parts get obsolete, and you might have to replace the window assembles.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Re: Window Rubber
Postby Mickmon [OP] » May 13th 2020, 12:06am
Wiley and MechBob,
thanks for the help.
Will take pics tomorrow of issue.
Hope all in the USA staying safe in these crazy times.
Thanks
Mick
Mickmon
Re: Window Rubber
Postby sixsix » May 13th 2020, 12:15am
Mickmon wrote:...
Thanks
Mick
Back atcha' Mick - Tip o' me Bonnet to Boris if ya' see him around.
:banana: :banana: :banana: :banana:
Well, after all... what would Banacek say ?... “May be hard to believe... President Trump should rest easy and concede what was in fact a foregone conclusion: Another OLD MAN won with only about 50% of the Change Believers/Fools showing up."
Firing on 4 Cylinders (L5)
Topics: 38
Images: 1303
Re: Window Rubber
Postby Mickmon [OP] » May 24th 2020, 7:48pm
Hi.
these are the side windows i have issues with the window rubbers.
Cheers
Mick
Pics (1).zip
Pic of windows
(3.52 MiB) Downloaded 35 times
Mickmon
Re: Window Rubber
Postby Rod's Trucks » May 24th 2020, 8:45pm
I have seen a lot of windows and P/U toppers that look like they might have the very same rubber inserts, and that have shrunk. It is likely an item that fits a common glass to an aluminum extrusion that may commonly be used in that RV window industry.
But I have no idea how to order such an item. I would think a photo of a cut end would likely be a minimum to get anything that is close. A sample would be better yet, but I would certainly try to contact the Steel Rubber Products here in the US.
I've looked over their site. They have a huge selection of similar molding and weatherstripping products, so they might just have the exact same thing. They could possible be the OEM supplier.
Rod J
Rod's Trucks
Topics: 26
Images: 54
Alias (AKA): Rod and/or WE7X
Re: Window Rubber
Postby Mickmon [OP] » May 24th 2020, 11:23pm
Thanks. much appreciated.
Mick
Mickmon
Re: Window Rubber
Postby MechBob » May 24th 2020, 11:33pm
Yep, aftermarket, as I said. Look around the inside of the frames, even behind the screens, for a sticker or name of manufacturer.Otherwise, like I said, run van by a caravan distributor.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Re: Window Rubber
Postby Mickmon [OP] » May 24th 2020, 11:57pm
Cheers. Bob.
Will do.
Mickmon
Return to Exterior
It is currently December 2nd 2020, 5:27pm
Exterior Forum
Tanino
in Exterior
Date: Nov 29 '20
Time: 11:30am
kevinfin
in Exterior
Date: Nov 24 '20
Time: 10:20pm
foxfire
in Exterior
Comments: 43
Date: Nov 23 '20
Time: 9:30pm
in Exterior
Comments: 43
Date: Nov 18 '20
Time: 9:04pm
foxfire
in Exterior
Comments: 43
Date: Nov 15 '20
Time: 2:33am
