'99 Safari "Quality" Door Handles?
Postby FGravity [OP] » May 15th 2020, 6:28pm
I'm getting ready to paint (errr Raptor really) my 99 Safari, and it seems to be the best time to address my door handles. I'd like to replace both the front and the sliding door handles, as they are all in various states of broken, and my paint job will be way cleaner if I just take them off for it. I found a rad YouTube vid on drilling a hole for swapping the front handles to access the upper nut, but can't seem to find anything similar for the sliding door. Any idea on how much of a chore the sliding door handle is, or if there's a similar shortcut to be taken like with the front doors? Also, there seems be a WIDE range of door handle "quality" - it seems they all break eventually, but some are worse than others. If anyone has a recommendation for the "best" door handles, I'm all ears.
ETA - I've got a good sense of which front door handles to buy from the relevant threads, but no clue on the sliding door handle.
FGravity
Years of Membership: FGravity has been a member for 1 full year
Alias (AKA): Sky
  • 1994 Safari Exterior Fuel Door
    by edwina » September 13th 2020, 5:04pm in Exterior
    September 14th 2020, 3:18am
  • Remove License Plate / Rear Door Handle
    by Ladytron » July 10th 2020, 4:11pm in Exterior
    July 10th 2020, 10:32pm
    9
    57
    December 1st 2020, 1:04pm
Re: '99 Safari "Quality" Door Handles?
Postby tonydobbs » August 5th 2020, 3:34pm
Which ones did you decide on? The Dorman ones I bought are impressively awful.
tonydobbs
Years of Membership: tonydobbs has been a member for 1 full year
Topics: 9
Alias (AKA): Tony
Extra Info: RWD
Postby joseluisrivera » August 5th 2020, 3:43pm
More importantly than door handles, what is your prep work for the raptor paint.....I want to do toos....pictures?
I'm looking at this paint -
https://www.amazon.com/Raptor-Urethane- ... 49&sr=8-57
Jose
joseluisrivera
Years of Membership: joseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full yearsjoseluisrivera has been a member for 8 full years
Topics: 41
Extra Info: sle
Postby Ironsides » August 5th 2020, 4:34pm
I purchased https://www.amazon.com/gp/product/B01BNDIOYG/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1 these back in February 2020, they were painted gloss black and I had no issues installing or performance. Unfortunately these are not available and T1A TruBuilt 1 Automotive do not have any left now, nor do they have slider door ones either. As I logged in to Amazon to collect the link for you and typed this up, it occurs to me I've wasted your time, these companies buy or make something today, sell it and move on tomorrow...
If I can assist at all: It is a PITA installing our door handles, I found I really needed my telescoping magnet a lot, after several attempts to install per the service manual, I just connected the rod, then feeding through the door and attaching the upper screw worked best. They are also not made to fit perfectly and require quite a bit of tightening to get the mating flange flush. My driver handle was first and there is a slight protrusion, the passenger side was done after and is perfectly flush, I have no desire at all to re-open the door panel and fix this unless I have to go in there. Also the GM manual says to use the access hole, I found it to be worthless :2:
Hope your Raptor Paint goes excellently!
Good luck!
Ironsides
Years of Membership: Ironsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full yearsIronsides has been a member for 5 full years
Topics: 5
Van Model Year: 2001
Extra Info: RWD Custom HD
Postby augidog » August 5th 2020, 5:33pm
I learned a particular lesson while shopping Bicycles and engines. look for "stock" photos to realize one-maker several re-branders. since I have had good luck with other Dorman products, I went with them for my front door handles. the driver side handle hinge was drilled off-center. it works, but it looks like an old broken one.
I don't have a magnet helper, but a dab of grease in the socket (and box wrench) held the nut while I started it.
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby tonydobbs » August 5th 2020, 5:42pm
augidog wrote:I learned a particular lesson while shopping Bicycles and engines. look for "stock" photos to realize one-maker several re-branders. since I have had good luck with other Dorman products, I went with them for my front door handles. the driver side handle hinge was drilled off-center. it works, but it looks like an old broken one.
Mine took 6months to slowly bend the metal until they are recessed just like my old stock ones. I'm going to try fixing it myself with some epoxy and a washer.
tonydobbs
Topics: 9
Alias (AKA): Tony
Extra Info: RWD
Postby augidog » August 5th 2020, 6:47pm
ha! mine came "over-recessed" and all I can do is treat it gingerly to avoid busting it.
augidog
Topics: 16
Alias (AKA): Augie
Postby Toskavat » August 5th 2020, 7:33pm
I have replaced the handles on my 99 and most recently on the 94 I acquired. Have used these purchased from Amazone. Well made and have held up well. I did drill extra access holes and lubed them well.
Toskavat
Years of Membership: Toskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full yearsToskavat has been a member for 5 full years
Images: 24
Alias (AKA): ASTRORC
Extra Info: 4.3 V6 2WD
Postby tonydobbs » August 5th 2020, 8:11pm
I seem to have the same ones as Toskavat. When did you order yours? Mine are less than a year old and already starting to 'over-recess'.
tonydobbs
Topics: 9
Alias (AKA): Tony
Extra Info: RWD
augidog wrote:ha! mine came "over-recessed" and all I can do is treat it gingerly to avoid busting it.
I try to delicately release the handle, but I forget a lot and they are recessing not so slowly.
tonydobbs
Topics: 9
Alias (AKA): Tony
Extra Info: RWD
Postby Leeann_93 » August 5th 2020, 11:58pm
Toskavat wrote:I have replaced the handles on my 99 and most recently on the 94 I acquired. Have used these purchased from Amazone. Well made and have held up well. I did drill extra access holes and lubed them well.
I have those as well, bought on Amazon. They are definitely heftier than the replacements they're replacing.
Return to Exterior
It is currently December 1st 2020, 1:04pm
Exterior Forum
Tanino
in Exterior
Date: Nov 29 '20
Time: 11:30am
kevinfin
in Exterior
Date: Nov 24 '20
Time: 10:20pm
foxfire
in Exterior
Comments: 43
Date: Nov 23 '20
Time: 9:30pm
in Exterior
Comments: 43
Date: Nov 18 '20
Time: 9:04pm
foxfire
in Exterior
Comments: 43
Date: Nov 15 '20
Time: 2:33am
Users browsing this forum: Google [Bot] and 1 guest
cron
