What is this vent for?
Postby rstro [OP] » July 7th 2020, 1:23pm
Anyone know what this vent is for? It’s located on the body behind the sliding door.
I found a leak somewhere in this vicinity, nothing to do with the vent, but I am thinking of completely sealing this thing. I’m building out my van as a camper so I don’t want any holes/vents that could let water get behind the walls.
rstro
Van Model Year: 2001
Extra Info: Cargo
Re: What is this vent for?
Postby bradaskins » July 7th 2020, 2:56pm
I believe it's just flow-through vent for the interior and it helps with sealing the door shut.
Sealing off that vent may make it harder to close the door and get a proper seal.
bradaskins
Years of Membership: bradaskins has been a member for 1 full year
Topics: 41
Alias (AKA): Breaking Brad
Postby rstro [OP] » July 7th 2020, 3:29pm
Got it, thanks!
rstro
Extra Info: Cargo
Postby markmitchmarkmitch is online! » July 7th 2020, 4:19pm
its also part of the air flow to stop moisture from building up on inner body panels. Not sure if it works by design but I read in a body manual that was part of the reasoning behind it. Mark
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
Postby augidog » July 7th 2020, 5:56pm
markmitch wrote:its also part of the air flow to stop moisture from building up on inner body panels. Not sure if it works by design but I read in a body manual that was part of the reasoning behind it. Mark
I've seen a diagram of the body air flow system, and cannot remember where. I flipped almost every page of my FSM's but no dice. I'm not sure sealing it off is a good idea, because I'm almost certain it also sheds air from the engine compartment. corrections welcome.
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby bradaskins » July 7th 2020, 6:27pm
Really?
This is a vent next to the sliding door. I'm not sure I want that vent exhausting air from the engine component into the van.
Maybe I wrong but this doesn't sound right to me.
bradaskins
Topics: 41
Postby augidog » July 7th 2020, 7:14pm
Really?
you may completely disregard what I said, clearly memory is not serving me correctly. I went to the van and looked, which I should have done before posting, and there are no mating openings on any of the doors.
of course, now I'll go nuts trying to remember what diagram it was I saw, IF I even really saw one.
augidog
Topics: 16
Alias (AKA): Augie
Postby bradaskins » July 7th 2020, 7:25pm
Hopefully, someone who really knows will chime in and help us all understand what the vent is for :-)
bradaskins
Topics: 41
Postby markmitchmarkmitch is online! » July 7th 2020, 8:11pm
From Google: The jamb vents are to the inside of where the door seals seal to the body. They are for flow-through ventilation for the interior.
Topics: 615
Images: 20
Extra Info: RS V8
Postby bradaskins » July 7th 2020, 8:17pm
Yup, that's what I thought and wrote.
bradaskins
Topics: 41
Postby sixsix » July 7th 2020, 10:36pm
Yeah, with the way the pic is oriented - it was hard to tell where it was... oh well.
Yup... you are right! I am VERY upset - everyone should be.
Well, after all... what would Banacek say ?... “May be hard to believe... President Trump should rest easy and concede what was in fact a foregone conclusion: Another OLD MAN won with only about 50% of the Change Believers/Fools showing up."
Firing on 4 Cylinders (L5)
Topics: 38
Images: 1303
Postby M_a_t_t » July 8th 2020, 12:15am
sixsix wrote:Yeah, with the way the pic is oriented - it was hard to tell where it was... oh well.
What a waste of time and effort.
"Have to click on the photo to see how the OP wanted it"...
What a joke.
Nobody here knows. Period.
You seem upset. It seems after a certain event you have been upset and it has been reflecting in your posts. I don't understand why you are being so pessimistic to everyone when it has nothing to do with them.
You know the forum has picture problems and that it has nothing to do with the OP.
The only way to find out if nobody knows is by asking and it's not like we can just ask the engineers that designed the van.
To the OP: I agree with bradaskins. It just makes the most sense. You could always pull the cover off and see where it leads.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby augidog » July 8th 2020, 12:31am
ta-DA! 1995 Astro Owner's Manual...
I almost had it remembered right, and bradaskins was right.
augidog
Topics: 16
Alias (AKA): Augie
Postby M_a_t_t » July 8th 2020, 12:40am
Is that the owners manual for the conversion van or the stock van? My owners manual is different than yours.
1995 Mercury Tracer
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby augidog » July 8th 2020, 12:48am
M_a_t_t wrote:Is that the owners manual for the conversion van or the stock van? My owners manual is different than yours.
supposed to be an exact authorized repro. seems legit, dunno if true, but no reason to doubt. it's nicely made.
augidog
Topics: 16
Alias (AKA): Augie
Postby M_a_t_t » July 8th 2020, 12:55am
My bad. I was thinking mine was printed the other direction (binding on short side), but I just looked and it matches yours. :doh:
1995 Mercury Tracer
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby augidog » July 8th 2020, 1:03am
please delete. thank you.
augidog
Topics: 16
Alias (AKA): Augie
Postby augidog » July 8th 2020, 1:30am
hey, wait a doggone minute. I just realized it's on the exterior side of the weatherstripping. my mind had it going in the wrong direction. the diagram isn't very helpful. I checked and there is a duct behind it, built into the body, where to or from I do not know. I don't see anything obvious inside my (conversion) interior. don't think I'd seal it without knowing.
curiouser & curiouser
augidog
Topics: 16
Alias (AKA): Augie
Postby Rod's Trucks » July 8th 2020, 3:33am
Yes,
Mine is on the outside of the weatherstripping, so it is an exhaust for stale interior air.
The diagram posted shows the make up air coming from the forward vents.
Rod's Trucks
Topics: 25
Images: 54
Alias (AKA): Rod and/or WE7X
Postby augidog » July 8th 2020, 4:37am
but it appears to show the air exiting the interior into that vent, not out through it. in other words, the vague diagram is useless from a technical perspective. I can't find any place, vents or grills, on the interior, that would enter the ductwork in the body and then exit out slider's vent.
augidog
Topics: 16
Alias (AKA): Augie
Return to Exterior
It is currently November 28th 2020, 3:28am
Exterior Forum
kevinfin
in Exterior
Date: Nov 24 '20
Time: 10:20pm
foxfire
in Exterior
Comments: 41
Date: Nov 23 '20
Time: 9:30pm
in Exterior
Comments: 41
Date: Nov 18 '20
Time: 9:04pm
foxfire
in Exterior
Comments: 41
Date: Nov 15 '20
Time: 2:33am
foxfire
in Exterior
Comments: 41
Date: Nov 14 '20
Time: 9:57pm
Users browsing this forum: Yandex [Bot] and 5 guests
