Remove License Plate / Rear Door Handle
Postby Ladytron [OP] » July 10th 2020, 4:11pm
Hi folks,
I want to remove my license plate and got into some trouble I can't really handle. I removed every cover on the rear door to access the mounting nuts and finally detach the handle assembly from the door. Haynes Repair Manual and all Youtube-content that I could found show different settings than my Astro Van from 1998.
Two pictures are added below..
Do I have to simply push the metal sticks out of the white rings?
If I do so, will these rings break for sure?
If so, is it easy to get some new ones, because these rings could be standard for other vehicles as well?
Thanks so much!
Since I am German my English is not the best... Sorry about that.
Greetings from the Black Forest.
Ladytron
Ladytron
  • Dutch door handle part number?
    by Coyotecamper » September 7th 2020, 4:53am in Exterior
    Last post by Coyotecamper View the latest post
    September 7th 2020, 8:15pm
  • Rear bottom door wont open
    by Diablo_deth » January 2nd 2021, 7:42am in Exterior
    January 2nd 2021, 8:23am
    46
    January 26th 2021, 2:31am
Re: Remove License Plate / Rear Door Handle
Postby SportsBoy » July 10th 2020, 8:09pm
Ladytron wrote:1 - Do I have to simply push the metal sticks out of the white rings?
2 - If I do so, will these rings break for sure?
3 - If so, is it easy to get some new ones, because these rings could be standard for other vehicles as well?
You're doing the rear door handle, is that right? If so -
1 - yes
2 - ye3 - probably not, new door handles come with new nylon inserts though....
SportsBoy
Topics: 23
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby markmitchmarkmitch is online! » July 10th 2020, 9:23pm
Remove the license plate? there should be 2 screws through the plate -take them out and that's what hold the plate on.
As for the door handle you should be able to buy a pack of them white things the rods go into. They do break easily when you take the rods out. Please explain what your goal is here?
Firing on 7 Cylinders (L6)
Topics: 624
Images: 20
Extra Info: RS V8 AWD
Postby Leeann_93 » July 10th 2020, 10:32pm
^ they meant license plate holder, since a German plate doesn't fit in there.
Return to Exterior
It is currently January 26th 2021, 2:31am
Exterior Forum
VincentVanGo_M
in Exterior
Date: Jan 17 '21
Time: 1:19am
rorgeastro
in Exterior
Date: Jan 05 '21
Time: 3:32am
rorgeastro
in Exterior
Date: Jan 04 '21
Time: 3:37am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 7:41am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 12:20am
