Any Issue With Using L-Track as Roof Rails ?
Postby SportsBoy [OP] » July 24th 2020, 12:44am
So, this is somewhat similar to what RiseAbove asked about E track, but a little different application.
I'm looking at making my own roof rack to go on my fiberglass high top (to be installed eventually).
I was thinking about using L Track as the rails that attach to the roof, and then having a couple of mounts for roof rails that can be pretty easily moved.
L-Track - https://www.cargoequipmentcorp.com/Heavy-Duty-L-Track?l_track_profile=Angled&l_track_mounting_option=0.3125%20Inch%20Mounting%20Holes&l_track_length=92%20IN
"Towers" or feet for the roof rack rails I'll eventually put on - https://www.cargoequipmentcorp.com/10-Pack-Double-Lug-Threaded-Stud-Fitting-For-L-Track
I can't find evidence of anyone doing anything like this before, so I'm wondering if there is a reason? Planning to refinish the top, then install the rails with butyl tape between the rails and the top.
Thanks for the input!
SportsBoy
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
  • Window track rebuild
    by smokinjoe » June 18th 2020, 5:17am in Exterior
    Last post by smokinjoe View the latest post
    June 27th 2020, 5:25am
  • Help with roof rack rivets?
    by Astroworld » April 1st 2020, 4:28am in Exterior
    Last post by albrow100 View the latest post
    April 2nd 2020, 7:01pm
    34
    September 23rd 2020, 2:27pm
Re: Any Issue With Using L-Track as Roof Rails ?
Postby pmou » July 31st 2020, 8:35pm
I have no input on this as I haven't done it (although my transit connect came with T channel that held the ladder rack on) but am interesting in doing something similar.. following.
Would this be able to take a slight bend for a little curve in the roof? Or are our roofs "dead flat" front to back?
pmou
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Alias (AKA): Paul
Extra Info: V6 AWD 3.73 no LSD
Postby SportsBoy [OP] » July 31st 2020, 10:40pm
Normal roofs have a slight curve, but I'm planning to put this on a high top roof with a bunch more curve, and I'm not worried about it. I have seen videos of it installed on curves and it just bends as you tighten down the mounting hardware.
It seems like t channel is just as expensive, but not as easy to modify, which is why I'm looking at l track.
SportsBoy
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby 97cargocrawler » August 2nd 2020, 3:47am
This would be convenient inside the van but for the roof you would save a bunch just using a shallow steel electrical strut channel. Might be a pinch heavier but way cheaper and easily purchased at HD. Strut will bend to the shape of the roof and attach with a bolt through it just like this stuff.
You might even find aluminum strut channel at an electrical supply house. I suggest steel though for a roof rack application. I've had super heavy duty ALUMINUM roof rack supports snap of the roof of my Land Cruiser. They were 1/2" thick holding a rack half the size as what I have on the roof of my van. SO I don't ever consider aluminum for holding a rack, or the rack itself.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Postby pmou » August 2nd 2020, 3:59am
Looking at this again, how are you planning to build towers out of those bolt down points? the bolts look quite short
pmou
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Alias (AKA): Paul
Postby SportsBoy [OP] » August 2nd 2020, 11:45pm
97cargocrawler wrote:This would be convenient inside the van but for the roof you would save a bunch just using a shallow steel electrical strut channel. Might be a pinch heavier but way cheaper and easily purchased at HD. Strut will bend to the shape of the roof and attach with a bolt through it just like this stuff.
Aw man, don't tell me that about aluminum - I don't want to use steel - rusty rusty rusty
Also heavy
Considering what l track is usually used for, I really don't think I'll get anywhere near its breaking point. I'm never going to have more than 200lbs maybe up there - just surfboards and kayaks. Plus it will be on a fiberglass high top, so I don't want to put much weight on that anyways.
The cost of superstrut is appealing though...
pmou wrote:Looking at this again, how are you planning to build towers out of those bolt down points? the bolts look quite short
I was going to use some "C" shape angle bolted to it to give me the height I want between the roof and the crossbars
SportsBoy
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby MechBob » August 2nd 2020, 11:50pm
The question here is,what does the roof manufacturer recommend for adding a rack, and weight?
MechBob
Blue Status (L2)
Blue Status (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby SportsBoy [OP] » August 3rd 2020, 12:32am
No idea, but whatever it is, I'm sure I won't be putting too much up there.
SportsBoy
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby 97cargocrawler » August 3rd 2020, 5:10am
SportsBoy wrote:I don't want to use steel - rusty rusty rusty
Also heavy
The stuff at Home Depot is galvanized and the shallow strut really isn't that heavy in 10ft lengths. It's also costs less than $20 for 10ft. Worth looking at. My entire rack is made from shallow strut. Prolly 50ft or more of it.
97cargocrawler
Topics: 42
Postby WoodButcher » August 3rd 2020, 6:55pm
https://www.astrosafari.com/viewtopic.p ... 40#p910386
There ya go. I carry ladders all the time, once in a while lumber but not much and not far on bad roads. (4, 2"x10" x 16' this AM)
I haven't pulled the headliner down to support the rear yet but I did block up the front over the door jamb. Key are the four corners, the front gets loaded on braking and rear on take off and uphill.
Plus for the channel I used is the ability to hang a tarp the whole length of the rack, water- proof front to rear so if your a camper it would be ideal.
WoodButcher
Firing on 4 Cylinders (L6)
Years of Membership: WoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full yearsWoodButcher has been a member for 9 full years
Topics: 30
Images: 512
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby SportsBoy [OP] » August 4th 2020, 3:40am
Also heavy
Yeah, the cost is most appealing for sure
WoodButcher wrote:https://www.astrosafari.com/viewtopic.php?f=127&t=17922&start=340#p910386
Cool idea Woodbutcher - I'll have to keep this in mind when I'm doing an awing later on down the road and don't want water coming in behind it. Had no idea they made molding like that
SportsBoy
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby ri$e*above » August 6th 2020, 2:42am
Sounds good. Looking forward to seeing how it turns out.
I'm thinking of directly fitting E Trac to the roof, and using the roof channels as a brace and maybe something else to support the roof. I was also thinking of attaching some to the rear sides as accessory rails...still figuring that out. Maybe on the swing out dutch door panels too.
Harbor Freight has E Trac pretty cheap.
CURRENT: 2002 GMC SAFARI AWD SLE 'GOLD DIGGER'. 5 INCH LIFT. G80. GT4.
ri$e*above
Fueling (5/8 tank)
Fueling (5/8 tank)
Topics: 17
Images: 4
Van Model Year: 2002
Extra Info: AWD SLE
Return to Exterior
It is currently September 23rd 2020, 2:27pm
Exterior Forum
Tanino
in Exterior
Comments: 21
Date: Today
Time: 12:40am
Bigforkg
in Exterior
Comments: 21
Time: 1:30am
SoccerMom4x4
in Exterior
Comments: 21
Date: Sep 21 '20
Time: 3:15am
Tanino
in Exterior
Comments: 21
Date: Sep 20 '20
Time: 11:44am
SoccerMom4x4
in Exterior
Comments: 21
Date: Sep 17 '20
Time: 3:25am
