dutch door spare holder-my design
Postby markmitchmarkmitch is online! [OP] » August 23rd 2020, 10:02pm
My van is a 89 and originally had barn doors, I was given a 94 Astro with engine problems so I stripped it of what I wanted including the dutch doors assembly. I had a spare tire carrier like the one shown on the web link:
https://www.ebay.com/p/1228272465?iid=1 ... K2EALw_wcB
I decided to try to make it work on my new to me dutch doors first I bought two of these hinges shown here:
https://www.etrailer.com/Trailer-Door-H ... 904-Z.html
I cut the center section from the barn door carrier I call this the center it is the u shaped section the wheel bolts to.
I then after many tries and measuring welded the hinge to the center I decided I wanted the tire carrier to hinge so I could basically tip it away from the body at the top so I could still open the hatch. After getting it to do what I wanted I realized the hinge would hit the door when moved so I had to add some type of spacer to the bottom of the hinge where it bolts through the door. I also took some 1/8 inch steel plate and added it to the inside of the door for the hinge to bolt through and I tack welded it in place as well as another piece at the top of the inside of the door for the pin to bolt through. I then found a hood pin from my box of scrap to use for the top but I had to add a cut down brake spring and a bushing so it was tight when closed so it would not rattle. Thanks for reading, Mark
Firing on 7 Cylinders (L6)
Topics: 623
Images: 20
Extra Info: RS V8 AWD
  • Dutch door handle part number?
    by Coyotecamper » September 7th 2020, 4:53am in Exterior
    Last post by Coyotecamper View the latest post
    September 7th 2020, 8:15pm
  • SteelRubber Dutch Door Seal Install
    by AstroOafAdventurer » October 21st 2020, 8:47pm in Exterior
    Last post by AstroOafAdventurer View the latest post
    9
    56
    January 22nd 2021, 4:54pm
Re: dutch door spare holder-my design
Postby Big_kid » August 24th 2020, 2:50am
Genius!
Firing on 7 Cylinders (L7)
Topics: 185
Images: 337
Extra Info: 2WD 5.7 V8
Postby markmitchmarkmitch is online! [OP] » August 24th 2020, 3:59am
Thank you, works great with the hidden hatch release button too.
Topics: 623
Images: 20
Return to Exterior
It is currently January 22nd 2021, 4:54pm
Exterior Forum
VincentVanGo_M
in Exterior
Date: Jan 17 '21
Time: 1:19am
rorgeastro
in Exterior
Date: Jan 05 '21
Time: 3:32am
rorgeastro
in Exterior
Date: Jan 04 '21
Time: 3:37am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 7:41am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 12:20am
