Headlight cleaning and/or replacing
Postby AstroOafAdventurer [OP] » August 29th 2020, 6:37pm
So I was told on my pre-purchase inspection my headlights would fail inspection.
Do they clear up easily enough, or should I replace them?
I have 1000, 1500, & 2000 grit sandpaper to knock the haze off, but just as well I'd like to replace them with some modern higher candle power headlights.
What have you guys done, and what would you recommend?
I'd like an HID/LED/projector setup, but I've only seen one brand and seems hit or miss.
97 Astro Conversion Van 62k 64k miles
AstroOafAdventurer
Topics: 31
Alias (AKA): Thorsteenster
  • LED Headlight Replacement-Safari
    by BobbyD » September 5th 2020, 10:08pm in Exterior
    Last post by joeg View the latest post
    September 16th 2020, 10:02pm
  • New headlight housing/HIDs/Fog lights
    by JayWS6 » November 3rd 2020, 7:13am in Exterior
    Last post by MmusicmanMmusicman is online! View the latest post
    November 3rd 2020, 1:42pm
    100
    November 30th 2020, 2:18am
Re: Headlight cleaning and/or replacing
Postby M_a_t_t » August 29th 2020, 7:38pm
Do you have sealed beams?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby dramey » August 29th 2020, 8:27pm
Hella makes a sealed beam replacement that takes an H4 bulb. I used a 55/100 bulb that is regular brightness on low beam and almost twice as bright on high beam. Best headlights I have ever used.
dramey
Firing on 7 Cylinders (L1)
Extra Info: AWD Cargo Van
Postby sixsixsixsix is online! » August 30th 2020, 12:41am
or as " dc " would say:
dcsleeper wrote:Didja search?
here let me help you with that answer. NO
If you're not willing to search, I'm not willing to post links
There are decades of posts here, give it some kind of effort, eh?
haha... and I'm gonna quote him till he tells me to stop ...
Well, after all... what would Banacek say ?... “May be hard to believe... President Trump should rest easy and concede what was in fact a foregone conclusion: Another OLD MAN won with only about 50% of the Change Believers/Fools showing up."
Firing on 4 Cylinders (L5)
Topics: 38
Images: 1303
Postby AstroOafAdventurer [OP] » August 30th 2020, 5:16am
I don't have the sealed beams, wish I did for the ease of upgrading.
New headlight assemblies are pretty cheap, much cheaper than anything I've owned before.
Cheap enough I may just buy a pair and try a DIY projectors in place of the high beams
https://www.theretrofitsource.com/bixen ... quantity=1
AstroOafAdventurer
Topics: 31
Postby M_a_t_t » August 30th 2020, 7:44pm
Do you have aftermarket lights? Both my vans are Denso lights and are very clear. I haven't had the 04 long, but the 95 I've had for 6 years now. Just curious if they might be originals and aftermarket ones have yellowing issues.
1995 Mercury Tracer
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby albrow100 » August 30th 2020, 8:11pm
I recently bought a set of eBay headlights. split them open and did a Morimoto mini H1 bi-xenon hid projector retrofit. It was a giant pain in the but but the light output is great
I’ve been meaning to make a post about it...
But the main issue I had was the projector depth is longer than the composite lens so it look some fabrication for it to work
Also the factory lens are “fluted”. So they will disrupt the projector beam.
You have to get euro style clear lens
albrow100
Topics: 30
Images: 18
Extra Info: awd
Postby dchan51360 » August 30th 2020, 9:10pm
So the OP is asking about passing an inspection.. Depending on what state and what things they are checking for, Changing the headlights to an aftermarket may not be allowed. Just FYI... Composite systems are a bit harder to deal with but there are lots of OE fit units. Be aware of LED bulbs that are not SAE/DOT certified. they tend to be real horrible with the projection and cut off of glare. I did find however that GM actually used Glide lenses as well as their own GM brand. (bought both from various sources) I found the throw pattern on the Glide version was better than the GM stamped lenses (the Glide lens came in the GM labeled box, and the housing on the back actually had the GM part number in the casting with the "Glide" labeled lens)
So first thing for the OP is to verify if the safety inspection will be looking for modifications.
Then the second question is how much they are willing to spend or if they really want an OE look with a brighter controlled output.
dchan51360
Postby dchan51360 » August 30th 2020, 9:14pm
according to the morimoto website these mini H1 projectors are NOT street legal so if you are trying to pass inspection, you may need to do something else. I won't advocate for you to do anything illegal but you can make your own choices.
dchan51360
Postby dchan51360 » August 30th 2020, 9:36pm
and from Vermont State vehicle inspection checklist.
Check lights for cracks, leaks, insufficient repairs Yes No
Check for unauthorized after-market lighting Yes No
https://dmv.vermont.gov/sites/dmv/files ... _Guide.pdf
dchan51360
Postby AstroOafAdventurer [OP] » October 23rd 2020, 3:31am
Hey, so I saw a few posts, it appears to be easy to swap to the Safari grill. I find this highly interesting.
However, how is it swapping from composite to sealed beam headlights?
I found a decent pair of Lumen LED sealed beams that are DOT/SAE on CarID.
https://www.carid.com/1997-chevy-astro- ... 62728.html
I tried searching but all results are from sealed beam to composite.
I'm digging this grill
AstroOafAdventurer
Topics: 31
Postby AstroWill » October 23rd 2020, 8:55pm
AstroOafAdventurer wrote:on CarID
(cringe)
Images: 443
Postby sixsixsixsix is online! » October 25th 2020, 11:17pm
They include a Video Game - Cool if so. . . ?
Topics: 38
Images: 1303
Postby AstroOafAdventurer [OP] » October 26th 2020, 2:25am
(cringe)
Is CariD a no-no vendor? I've never bought from them nor heard anything good or bad about em.
Dang, guess I have to get an XBox...
Good upgrade for the Nintendo 64 that came with the van!
:ugeek:
AstroOafAdventurer
Topics: 31
Postby dcsleeper » October 26th 2020, 12:51pm
I had the H4 conversion sealed (not) beam headlights in my watchlist for months. One of those "some day" things.
Then I compared the price of them to the THREE sets of aux lighting I've bought for less recently. And took them off my watch list.
Profile | Edit signature
Lumpy wrote:You can weld a cheese sandwich to a shower head and add a blind side bracket for a baboon circumcision tool holder if you want to...
dcsleeper
Topics: 18
Images: 59
Alias (AKA): DC
Postby AstroWill » October 26th 2020, 7:15pm
(cringe)
In my personal opinion, yes, there are a few posts floating around about them. I avoid them at all costs now.
Images: 443
Postby AstroOafAdventurer [OP] » October 27th 2020, 5:36am
AstroWill wrote:In my personal opinion, yes, there are a few posts floating around about them. I avoid them at all costs now.
Huh, yeah, and the specific headlight only appears to be available from them. A lumen CariD exclusive or something maybe.
Funky looking headlight but I dig the halo as DRLs.
Thanks for the heads up
AstroOafAdventurer
Topics: 31
Postby AstroWill » October 27th 2020, 2:37pm
103042
:rofl:
Images: 443
Postby stent » October 27th 2020, 3:55pm
AstroOafAdventurer wrote:Hey, so I saw a few posts, it appears to be easy to swap to the Safari grill. I find this highly interesting.
i don't know if your sheetmetal panel behind the grill is punched for the sealed beam mounts & grill - it would take a junkyard trip to investigate.
i did change from an astro to safari sealed beam grill and the screw holes for mounting them are the same.
also did a billet grill insert that looks nice, i got the insert on eBay, don't have the listing, it was a couple of years ago.
Hella makes DOT grade headlights that fit the sealed beam buckets - i like them, the low beam is wider to the sides, and you can use the high wattage bulbs mentioned above by dramey.
Images: 188
Extra Info: rwd cargo
Postby sixsixsixsix is online! » October 28th 2020, 1:20am
Well, certainly cleaned that front end up.
Nice!!
Topics: 38
Images: 1303
Return to Exterior
It is currently November 30th 2020, 2:18am
Exterior Forum
Tanino
in Exterior
Time: 11:30am
kevinfin
in Exterior
Date: Nov 24 '20
Time: 10:20pm
foxfirefoxfire is online!
in Exterior
Comments: 43
Date: Nov 23 '20
Time: 9:30pm
in Exterior
Comments: 43
Date: Nov 18 '20
Time: 9:04pm
in Exterior
Comments: 43
Date: Nov 15 '20
Time: 2:33am
