I'm plagued with an issue..
My driver's door has been acting up - Not unlocking and locking, though the actuator does move, the original one (when unhooked revealed it wasn't moving up and down to it's limits, and I assumed that was the only issue.. Ordered a new lock actuator, and after removing the rivots and installing, it now has excellent travel. Still isn't unlocking/locking the door however, unless I hit it like 10 times and occasionally I get lucky.
This is the problem, I believe:
Note the bare metal.. I believe from pics I've seen on google, there was originally a plastic 'ball' of some type that sat between the two black bars that move the rod. As you will note, I tried to use a hose taped up and positioning it on the bare metal area where it was rubbing - After a few uses it ended up shifting enough to the long part of the rod that it doesn't work anymore - I slid it intentionally further down the rod, just so you all could see what I tried - Too hard to explain that..
Is there a part, piece or anything that might clip together that we can put on there which would stay in place? I can't think of a thing to try other than what I already did. Driving me crazy..
Thanks in advance!!
