Door Roller Replacement?
Postby WinnieVan [OP] » October 28th 2020, 8:45pm
My passenger-side door door roller bushing is wallowed out and needs to be replaced... I'm planning to do the door bushings too, but I imagine this door roller being destroyed isn't helping:
Here's the passenger side:
Here's driver's side for comparison:
It doesn't appear this part is available from GM or online for the Astro... closest I've found is Dorman 38433:
https://www.amazon.com/gp/product/B000C ... UTF8&psc=1
Seems the pin is pushed in from the bottom and then "splayed" out to keep it in place.
Assuming the diameter is similar, it appears the Dorman part could be basically a good fit, but might involve a bit of finagling if the e-clip is in the wrong place.
Anyone else ran into or solved this issue?
WinnieVan
Firing on 2 Cylinders (L3)
Years of Membership: WinnieVan has been a member for 3 full yearsWinnieVan has been a member for 3 full yearsWinnieVan has been a member for 3 full years
Topics: 63
Images: 27
  • LED Headlight Replacement-Safari
    by BobbyD » September 5th 2020, 10:08pm in Exterior
    Last post by joeg View the latest post
    September 16th 2020, 10:02pm
  • Remove License Plate / Rear Door Handle
    by Ladytron » July 10th 2020, 4:11pm in Exterior
    July 10th 2020, 10:32pm
    9
    75
    December 4th 2020, 6:43pm
Re: Door Roller Replacement?
Postby WinnieVan [OP] » October 28th 2020, 9:06pm
Phew -- found a very knowledgable parts guy and he pulled some part numbers for me...
Appears this is a 3 piece unit -- one large pin that goes in from the bottom, a small pin that goes in from the top and a roller...
Large pin -- GM 14030534
Small pin -- GM 20262500
door pin top.jpg (2.69 KiB) Viewed 233 times
Door Check Link Roller -- GM 20058035
I'll pull the spring off and see if I can pull the upper pin and roller -- otherwise, might have sawzall it up and replace the whole assembly. Not gonna be cheap, these parts are spendy from GM direct.
So I'll check if Dorman part works... would be more cost effective but only if it doesn't require a ton of customization to work.
WinnieVan
Topics: 63
Images: 27
Postby AstroWill » October 29th 2020, 4:01am
From the reviews:
Just what I needed. If you have a grinder and a Dremel these will fix a 1994 S10. They don't make these for my truck so I ground off the end to fit then used Dremel to cut e clip slot ended up being the perfect solution because the only thing I could find for a S10 was a whole hinge that bolts on and mine was welded so not happening. The key is to grind off just enough to fit in the holes and cut off about 1 inch. If you own the car they are for I'm sure they would be even better. Even though I don't I'm still very happy because my truck is fixed and was very affordable to do compared to having a shop reweld the whole hinge back on.
I would be willing to bet it's going to be pretty simple modification like for the S-10. Would be awesome if it works out!
Images: 443
Postby WinnieVan [OP] » October 29th 2020, 5:12am
I was able to pop off the small pin and the door roller without disrupting the large pin -- so I canceled my Dorman part order!
Wasn't too bad -- about $17 out the door at my local Chevrolet dealer -- more than I wanted to spend, but easy peasy to replace.
WinnieVan
Topics: 63
Images: 27
Postby AstroWill » October 29th 2020, 2:10pm
Awesome! That is a LOT less work.
Images: 443
Postby markmitch » October 29th 2020, 3:44pm
Great ! thanks for posting that, I may just order the parts to have in my "Just is case Box"
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
Postby WinnieVan [OP] » November 3rd 2020, 12:10pm
Yeah no worries -- I think it is a rare failure -- but the 3rd parts guy I called knew exactly what I was looking for -- the other 2 were like -- yah that isn't listed.
Waiting on some time and door pins to fix the door for good! I'll add some photos of here once it's done.
In the meantime, if anyone else is facing this -- the roller came off with just finger pressure since it was so fuxxor'd. I got the small "bullet-shaped" pin out by putting a dull chisel on the head of the pin and punching upwards... be careful -- you don't want to shear off the head because then you won't be able to hit it. Lots of PB blaster helped too--- I imagine heating the lower pin would make it easier too -- but everything is painted, so you'd probably end up burning off the paint.
Worst case scenario -- you could easily cut the pin in half and then drive it out -- the large pin actually installs from the top and is then staked into place. I imagine if you cut it in half -- you could easily remove the bottom half of the large pin and then hammer upward on the top half to drive it out.
WinnieVan
Topics: 63
Images: 27
Return to Exterior
It is currently December 4th 2020, 6:43pm
Exterior Forum
Tanino
in Exterior
Date: Nov 29 '20
Time: 11:30am
kevinfin
in Exterior
Date: Nov 24 '20
Time: 10:20pm
foxfire
in Exterior
Comments: 43
Date: Nov 23 '20
Time: 9:30pm
in Exterior
Comments: 43
Date: Nov 18 '20
Time: 9:04pm
foxfire
in Exterior
Comments: 43
Date: Nov 15 '20
Time: 2:33am
Users browsing this forum: icebrrg3rdicebrrg3rd is online! and 13 guests
