How to fix large gap between rear cargo barn doors?
Postby SeekingAstro [OP] » June 9th 2021, 7:32pm
There is a large gap in between my rear cargo doors, in the middle of the doors. There is no gap along the hinges, only in the center where the two doors come together. The driver's rear door has a large gap, and because of where this door sits, it causes a gap on the passenger side door as well. I will try to adjust the striker on the inside of the driver rear door to adjust where the passenger rear door sits, but until I can get the driver's rear door to sit right, that is kind of a waste of time. I have tried adjusting the top and bottom strikers on the driver's rear door, but there is little actual adjustment possible. Also, I have removed the top and bottom strikers completely, and the doors are still not coming together far enough in the center, there is a big gap. There is no adjustment on the hinge side. How can I make these doors close normally, like they should, without these gaps?
SeekingAstro
Topics: 7
Extra Info: Cargo
  • 98 astro cargo rear barn door stuck
    by StillSmiling » January 22nd 2021, 5:09am in Exterior
    January 23rd 2021, 6:24pm
  • 86 Barn Doors on 2005
    by DDuncan604 » June 2nd 2021, 11:10pm in Exterior
    Last post by deafman View the latest post
    June 6th 2021, 6:23am
    June 25th 2021, 11:05am
Re: How to fix large gap between rear cargo barn doors?
Postby WoodButcher » June 9th 2021, 7:38pm
You need to bend or twist the doors and hinges to adjust doors on an astro.
Put a 2x4" at the bottom on the bumper so the door can't close and push on the top w/ your hands. Back up to a wall so you have something to push against.
Little bites at a time!
WoodButcher
Firing on 6 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby chevymaher » June 9th 2021, 7:45pm
First adjust them to pull it in tight. Looks like it is half open to me.
Topics: 91
Postby SeekingAstro [OP] » June 9th 2021, 7:50pm
WoodButcher wrote:You need to bend or twist the doors and hinges to adjust doors on an astro.
Thanks, I'll give this a try! I don't suppose there are any videos of anyone doing this?
SeekingAstro
Topics: 7
Extra Info: Cargo
Postby SeekingAstro [OP] » June 9th 2021, 7:51pm
chevymaher wrote:First adjust them to pull it in tight. Looks like it is half open to me.
I have made all possible adjustments that I can see, and that's as far as it closes, even slamming it as hard as possible. And yeah, it still looks half open... that's the problem!
SeekingAstro
Topics: 7
Extra Info: Cargo
Postby chevymaher » June 9th 2021, 8:23pm
There is a catch at the top and bottom on the first door that shuts.
Topics: 91
Postby WoodButcher » June 10th 2021, 3:48pm
No videos I've ever seen, but I have not looked. Be the one, take a vid and post it up. Be sure to hold the camera on the diagonal, sixsix (Mike) loves watching vids and pics while standing on his head,,, :rockon:
I've adjusted every drivers door of the three vans that I've had but never took pictures. You need to look carefully at where the strikers are, possibly the door frame got bent or tweaked to affect where they set. Also confirm it isn't the hinges binding before you take to bending the doors.
I'd bet an untied load shifted or some thing foolish like that.
WoodButcher
Topics: 30
Images: 514
Alias (AKA): Bruce
Postby MI_Ghost » June 10th 2021, 7:20pm
More likely someone unhooked the stops and let the door swing against the taillight. In which case the door side hinge was tweaked slightly. Try placing something hard in the open hinge so that the hinge pinches down on it when trying to close the door.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
https://www.astrosafari.com/gallery/sea ... r_id=66010
MI_Ghost
Firing on 4 Cylinders (L2)
Topics: 9
Images: 124
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby 97cargocrawler » June 11th 2021, 4:29pm
I was gonna suggest this but I guess y'all got it covered.
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Return to Exterior
It is currently June 25th 2021, 11:05am
Exterior Forum
Attached by: Birdshake
Birdshake
in Exterior
Date: Jun 21 '21
Time: 9:52pm
tinworm
in Exterior
Comments: 22
Date: Jun 13 '21
Time: 9:56pm
tinworm
in Exterior
Comments: 22
Date: Jun 13 '21
Time: 12:38pm
Attached by: 97cargocrawler
97cargocrawler
in Exterior
Date: Jun 11 '21
Time: 4:29pm
in Exterior
Date: Jun 11 '21
Time: 1:26pm
Users browsing this forum: Google [Bot] and 6 guests
