Attaching 28 ' ladder to luggage rack
Postby paintdrying [OP] » April 21st 2012, 3:57pm
I have that standard luggage rack and I am looking for ideas to get the ladder strapped down fairly quickly. And sometimes I want to try and look it too slow down people from trying to steal it. I have been using bungy cords but I am having trouble finding a brand that is strong enough. Also maybe I need to find the right length cord but it is a real pain straping and unstraping a dozen or so times a day.
If astros had the rain guards this would be a lot easier. i tore the headliner out because it serves no purpose for me. So I have access from the inside. Any ideas.
paintdrying
Topics: 94
Extra Info: 108 000
  • 2003 ladder rack
    by calvinater » September 23rd 2020, 1:22pm in Exterior
    Last post by stent View the latest post
    September 30th 2020, 7:21pm
  • Roof Rack Build Question
    by TPP » September 1st 2020, 3:28am in Exterior
    Last post by 97cargocrawler View the latest post
    September 1st 2020, 4:35am
    36
    January 19th 2021, 8:40am
Re: Attaching 28 ' ladder to luggage rack
Postby Jasen » April 21st 2012, 4:53pm
Ratchet straps. Pull the ratchet off and feed the strap through the eye of the hook and around the cross member of the rack close to the ladder so it pretty well stays put, maybe zip it to keep it from slipping around. A short length of chain and a pad lock or one of those cable locks, better yet, 2 bicycle cable locks, there a lot shorter then the ones you get a HD, and put then in plain sight.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Wagon Master » April 21st 2012, 5:34pm
A 28 foot ladder?
Man, you must have some SERIOUS lift on that rig!
Most folks only go a few inches...
Wagon Master
Years of Membership: Wagon Master has been a member for 9 full yearsWagon Master has been a member for 9 full yearsWagon Master has been a member for 9 full yearsWagon Master has been a member for 9 full yearsWagon Master has been a member for 9 full yearsWagon Master has been a member for 9 full yearsWagon Master has been a member for 9 full yearsWagon Master has been a member for 9 full yearsWagon Master has been a member for 9 full years
Topics: 10
Extra Info: SLT AWD Loaded
Postby Lumpy » April 22nd 2012, 3:31pm
Wagon Master wrote:
A 28 foot ladder?
x2.
Your ladder is 28' collapsed? My entire van is just under 15' long. Your ladder would extend 6-7' beyond the front AND rear.
Postby paintdrying [OP] » April 22nd 2012, 6:56pm
I believe it would be 14 foot collapsed. There is a little pulley/rope set up and the ladder extends. They are just called 28 foot ladders. Any bungi suggestions
paintdrying
Topics: 94
Extra Info: 108 000
Postby Lumpy » April 22nd 2012, 9:54pm
How about those heavy rubber straps with end hooks that truckers use to tie down their tarps? I find them on the street all the time. I presume that means they fell off the storage part of the truck and not off the active-in use part.
But if the ladder is pretty heavy, as it seems it must be, I too would look toward ratchet straps. I've carried antennas and tower sections, on the roof rack, tied down to the front and rear bumper. There are some really great, locking ladder racks on a lot of Astros that I've seen in contractor use. Including the kind that tilt one end of the ladder down to you when you release it.
But I guess that's not a bungee answer, sorry.
Postby Jasen » April 22nd 2012, 10:10pm
The big black rubber bungees will work, but I would have at least one solid tie down like a cable or chain at the back. Those rubber bungees don't like the sun so much. I'd hate to see you slam on the brakes one day to avoid some idiot and launch your ladder through is back window and head, even if he had it coming.
Keep in mind, the state holds you responsible far anything the come off or out of your rig, and the fines have been going up quite a lot here anyway. Been to many people killed by things like ladders, tools, tires, 2x4's etc. falling off trucks.
200k
Ultra gauge
Topics: 260
Images: 101
Postby paintdrying [OP] » April 23rd 2012, 2:34am
The no rain guard thing on the astros is the problem. My last van had a professional rack. The racks for the astros are hard to find. If you need to buy any adapters they are usually fairly expensive. I am using the ratchet straps, I have one in the middle. Never had the rachet straps with those hooks on the end, I do not really like them but I will see.
paintdrying
Topics: 94
Extra Info: 108 000
Postby codad9000 » April 23rd 2012, 3:33am
I install cable as a subcontractor in Florida and we have to carry a 28 foot extension ladder along with a 6 foot step ladder. Both are fiberglass, so might be a little heavier than your aluminum. I use 2 tie straps on each one, the kind with hooks and yellow nylon straps. I usually use a big bicycle lock going through both ladders and the luggage racks. I have to take my ladders off 5 or 10 times a day, just depending. I can take a pic or two for you if you are interested in how it comes together...
Christopher
codad9000
Years of Membership: codad9000 has been a member for 9 full yearscodad9000 has been a member for 9 full yearscodad9000 has been a member for 9 full yearscodad9000 has been a member for 9 full yearscodad9000 has been a member for 9 full yearscodad9000 has been a member for 9 full yearscodad9000 has been a member for 9 full yearscodad9000 has been a member for 9 full yearscodad9000 has been a member for 9 full years
Extra Info: Mark III V6 RWD
Return to Exterior
It is currently January 19th 2021, 8:40am
Exterior Forum
VincentVanGo_M
in Exterior
Date: Jan 17 '21
Time: 1:19am
rorgeastro
in Exterior
Date: Jan 05 '21
Time: 3:32am
rorgeastro
in Exterior
Date: Jan 04 '21
Time: 3:37am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 7:41am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 12:20am
