Cargo door window parts compatibility?
Postby Tremelune [OP] » November 11th 2008, 12:27am
My sliding cargo door window got smashed on Halloween, and I'm trying to source another one. I ended up riveting a steel plate in there to keep out varmints, but the blind spot is annoying. I've put an ad out in the "Wanted" section, but I'd like to broaden the search.
Does anyone know what model years have this same window? I would prefer tinted, but I don't care. I had no luck at the junkyards in the area (NYC). Is there an easy way to figure out the part number? It's a 1996 Astro, non-extended.
Tremelune
Years of Membership: Tremelune has been a member for 12 full yearsTremelune has been a member for 12 full yearsTremelune has been a member for 12 full yearsTremelune has been a member for 12 full yearsTremelune has been a member for 12 full yearsTremelune has been a member for 12 full yearsTremelune has been a member for 12 full yearsTremelune has been a member for 12 full yearsTremelune has been a member for 12 full yearsTremelune has been a member for 12 full yearsTremelune has been a member for 12 full yearsTremelune has been a member for 12 full years
Topics: 24
  • Power Window Motor Spins, Window Won't Move
    by BillyJoBob » January 24th 2021, 8:54pm in Exterior
    January 26th 2021, 2:17am
  • Sliding door window not tight to seal
    by AstroOafAdventurerAstroOafAdventurer is online! » December 15th 2020, 4:22am in Exterior
    January 14th 2021, 9:42pm
    7
    66
    March 1st 2021, 4:57am
Re: Cargo door window parts compatibility?
Postby Tremelune [OP] » November 11th 2008, 12:40am
Hell, I'd replace the whole door, but my main goal is low costs.
Tremelune
Topics: 24
Postby 'cudapaul » November 11th 2008, 5:31am
Anything from a 96 and up should work OK. They changed the design of the door roller supports in 96 and doors made previously to that can be made to work but it will take some rework of the guides and attachments.
As far as the glass there are two categories and three types. Privacy glass used prior to 93/94 was slightly lighter and different in tint, along with clear glass (lighty tinted, same as driver's door). Then there is glass that is the "pop-out" type, it has hinge plates at the top and latches at the bottom, the other is the fixed glass which is typical in cargo vans and is glued in. You can use the pop-out type (which will probably be easier to find) in a cargo van, just make sure that you get all of the hardware when you buy the glass, assuming that you pick it up from the wreckers.
'cudapaul
Years of Membership: 'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years'cudapaul has been a member for 13 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby Tremelune [OP] » November 17th 2008, 9:32pm
The window is like the one above the word "Fire" (this isn't my car):
Tremelune
Topics: 24
Postby spongebob218 » November 19th 2008, 12:44pm
I have a door without a window if you are interested. Who needs windows anyway?
You ain't nothin' unless you have green plugs.
spongebob218
Years of Membership: spongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full years
Postby Tremelune [OP] » December 5th 2008, 10:36pm
I didn't think I'd need a window, but it is a pretty fair blind spot. Mostly inconvenient.
Tremelune
Topics: 24
Return to Exterior
It is currently March 1st 2021, 4:57am
Exterior Forum
in Exterior
Time: 4:18am
in Exterior
Date: Feb 27 '21
Time: 8:28pm
in Exterior
Date: Feb 24 '21
Time: 7:48pm
SheldonYoung
in Exterior
Date: Feb 24 '21
Time: 12:23am
Attached by: Allergictostabwounds
in Exterior
Date: Feb 16 '21
Time: 10:10pm
Users browsing this forum: moxtronmoxtron is online!, Yandex [Bot] and 20 guests
