barn door "door checks"; also sliding door sticking
Postby Coaster [OP] » February 27th 2013, 12:51am
95 astro barn doors. door checks are there and hooked up, and appear functional but wont hold the doors open even in zero wind. something is just worn out about them.
i've been waiting for some time to take them out and see if i can fix them, or am i better of replacing them with new parts?
yesterday i spent a few hours taking the sliding door apart and repairing the outside handle (which was horribly loose). the sliding door also seems to be sticking to the weatherstripping for some reason that i cant figure out, been thinking of putting some silcone spray on the ruber or something, any ideas?
I LIVE IN NORTH DAKOTA
Coaster
Years of Membership: Coaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full years
Topics: 114
Extra Info: 4.3 cargo 2wd
  • 98 astro cargo rear barn door stuck
    by StillSmiling » January 22nd 2021, 5:09am in Exterior
    January 23rd 2021, 6:24pm
  • Sliding Door
    by rlhogg » October 11th 2020, 1:37am in Exterior
    October 14th 2020, 12:01pm
    7
    21
    March 6th 2021, 3:43am
Re: barn door "door checks"; also sliding door sticking
Postby chevymaher » February 27th 2013, 12:56am
One of my barn doors loose as a goose. One is Steve austin man barely alive. I keep 2 little pieces of 2X4 to put in the door for loading. Works perfect holding them open.
There is a little pain in the rear part you will never find that is worn out. That holds the door open.
Postby RECox286 » February 27th 2013, 1:03am
I use a piece of 1/2" pvc conduit, cut to a length that will hold the doors open, and inserted just aft of the overhead
latches. The "lanyards" that GM uses for the doors of all their vans, uh, er, ah, suck.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby icebrrg3rd » February 27th 2013, 3:23pm
I did find a set at the junkyard that still work good, as long as you're on fairly level ground and the wind isn't too strong. I do use the 2x4 method just as a backup to prevent the door from shutting. Yeah, they aren't that well designed nor long lasting.
-Andrew
icebrrg3rd
Topics: 50
Alias (AKA): Andrew
Van Model Year: 1991
Postby Ragenme » February 27th 2013, 3:48pm
I have the same issue. I have the kids hold the door while I unload. I just know one day they aren't going to be there to hold open anymore. Guess I should get some wood out of the shop!
ragenme If you can't fix it with a hammer then its probably a electrical problem!
Ragenme
Years of Membership: Ragenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full years
Topics: 16
Images: 23
Alias (AKA): Ragenme
Extra Info: SLX 4.3 V6 RWD
Postby RECox286 » February 27th 2013, 6:36pm
BTW, If you haven't noticed, all of our brothers and sisters who own Astro/Safari and G body vans have an unmistakable
trade mark (similar to a tattoo). That would be a very sore black and blue spot on their back from forgetting to park the
truck in a nose uphill position when getting something out of the back of the truck. Wanna learn the secrete handshake ???
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby RECox286 » February 27th 2013, 9:07pm
In re: sliding door.
Use shop air to clean as much dirt and other accumulated gunk out of the workings, then I use a garden hose to finish the job
in the lower and middle tracks. When dry, and with the help of shop air to get the job done, it is time for fresh lubricant.
I like the spray cans of CRC or the like to wet down the rollers, latches and door handles b/c it will dry, leaving a semi
lubricated surface that won't attract as much dirt as a white grease will. Clean, and lubricated parts is the rabbit in the
hat as far as all the hinges, latches and handles are concerned, including the bonnet, fuel door, rear doors, slider and
front passenger doors. At least it seems that the (crumby) door handles last a lot longer if everything gets a treatment
along with oil/filter change and greasejob intervals. (5k mi or so.) Sticking gasket: Remove the gasket from its' sheet
metal, but do not unhook it from the bottom roller of the sliding door. Carefully wash the entire length of the gasket
and the mating surfaces of the sliding door with warm water with something gentle like diswashing liquid. (just enough
to make a soapy solution. Allow everything to dry, and treat the gasket with a product that is gentle
to foam rubber, ie; plain GOJO (no grit), Armor All, or silicone spray. Reinstall the gasket when done, and try the door.
If there is still a problem, then the rear middle bracket is not springing out forcefully enough, and there may be an alignment
problem or other worn parts as the cause.
Good hunting
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby GMGuy » March 10th 2014, 5:03pm
I might add best thing to use on door seals to keep them fresh....Glycerin.....its what GM actually recommends in for use as well
GMGuy
Years of Membership: GMGuy has been a member for 7 full yearsGMGuy has been a member for 7 full yearsGMGuy has been a member for 7 full yearsGMGuy has been a member for 7 full yearsGMGuy has been a member for 7 full yearsGMGuy has been a member for 7 full yearsGMGuy has been a member for 7 full years
Van Model Year: 2001
Extra Info: SLE RWD Barn Doors
Postby Coaster [OP] » March 10th 2014, 7:28pm
thanks. where do i get glycerin?
i have a more pressing issue right now in that the lower drivers door hinge is failed. i need to replace the door which is badly tweaked. hopefully this summer i can get to all these things
Coaster
Topics: 114
Postby Coaster [OP] » September 28th 2014, 4:39am
i bought a lift strut and did some experimenting with the barn door. i got sick of the door hitting me when i unloaded. this project is in its infancy so bear with me, the video has the strut clamped inside the door and the clamp falls off at the end of the vid.
but IT WORKS
https://www.youtube.com/watch?feature=p ... a05dnH9zGI
Coaster
Topics: 114
Postby Lumpy » September 28th 2014, 1:58pm
Coaster wrote:i bought a lift strut and did some experimenting with the barn door. i got sick of the door hitting me when i unloaded. this project is in its infancy so bear with me, the video has the strut clamped inside the door and the clamp falls off at the end of the vid.
but IT WORKS
Blobs of black with some blue stuff.
Postby Coaster [OP] » September 28th 2014, 10:41pm
worked on it some more today
i have more work to do but it works.
i may need to adjust where this ball pivot lives. seems like it needs to move away from the body about 1/2"
attached to the door frame
tried to get a better vid, but its not great. i like the door now!!
https://www.youtube.com/watch?feature=p ... QhrBS9S5o8
Coaster
Topics: 114
Postby paulbot » September 30th 2014, 2:49am
My back doors wore out some years ago, went to the dealer and bought a set of everything for the catches, both doors, for $117. Still working, too.
55273 2000 Safari Cargo RWD 235K
paulbot
Years of Membership: paulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full yearspaulbot has been a member for 10 full years
Topics: 13
Images: 16
Extra Info: Cargo
Postby The DrummerThe Drummer is online! » September 30th 2014, 5:17am
kleen slip from kleen-flo is very good on weatherstriping , prevents sticking and drying etc , works very good to keep from sticking under hailing and when it rains and then temp drops below zero ,i apply it a few times during the winter , and yep whomever designed the piece o crap thats suppose to keep them doors open deserves a good slap behind the head :whack: :rockon:
''USE THE TORQUE LUKE ''
and beware of trees ,them nasty wooden things are evil .
Years of Membership: The Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full years
Topics: 16
Images: 42
Extra Info: SLT 4.3 AWD
Return to Exterior
It is currently March 6th 2021, 3:43am
Exterior Forum
Olivier02
in Exterior
Date: Mar 02 '21
Time: 2:48am
in Exterior
Comments: 14
Date: Feb 28 '21
Time: 4:18am
AstroOafAdventurer
in Exterior
Comments: 14
Date: Feb 27 '21
Time: 8:28pm
sixsixsixsix is online!
in Exterior
Date: Feb 24 '21
Time: 7:48pm
SheldonYoung
in Exterior
Date: Feb 24 '21
Time: 12:23am
Users browsing this forum: Yandex [Bot] and 9 guests
