Replacing the door handles
Postby herbal_gardens [OP] » March 5th 2009, 12:51am
New ones just arrived today (driver side broke off a month ago and the passenger side is almost there as well),I pulled the pannel off the drivers door today, unplugged all the electrical, and looked inside.....How do they expect someone with big clumbsy hands like mine to be able to reach inside the door and remove the old one? Is there some magic trick to this or am I over looking something blaitently obvious?
Still scratching my head, looking for the cure for the itch.
Christopher
herbal_gardens
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: herbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full yearsherbal_gardens has been a member for 12 full years
Topics: 21
  • '99 Safari "Quality" Door Handles?
    by FGravity » May 15th 2020, 6:28pm in Exterior
    August 5th 2020, 11:58pm
  • Headlight cleaning and/or replacing
    by AstroOafAdventurer » August 29th 2020, 6:37pm in Exterior
    Today, 12:51pm
    7
    72
    October 26th 2020, 5:43pm
Re: Replacing the door handles
Postby astro355 » March 5th 2009, 1:03am
There should be some holes in the door that give you access to the nuts that hold the door handle in place. There will be grommets in the holes. At least its that way on my 89.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby Positive P » March 5th 2009, 2:18am
It's a 10mm if it's factory.
Those little clips are tricky, if you've never seen them before. All you need to do is slide it forward. When reinstalling, it's easiest to put the clips back in place, locked. Then just push the rod through the hole. It'll go in.
Also, for those of you looking for replacements in the salvage yard, I have Lumina MPV/Silhouette handles on my van. DRVR, PASS, and side's fit. The rear door still has to be Astro/Safari.
Positive P
Years of Membership: Positive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full yearsPositive P has been a member for 11 full years
Topics: 47
Alias (AKA): The Tongue-Fu Master
Van Model Year: 1990
Extra Info: 4.3L
Postby fede » March 5th 2009, 3:24am
I know i have big hands too and its hard to get at, not to mention that your working blind. But its not too hard. And a 10mm ratcheting wrench helps alot for taking off the bolts. Good luck!
91 Astro LT
fede
Years of Membership: fede has been a member for 12 full yearsfede has been a member for 12 full yearsfede has been a member for 12 full yearsfede has been a member for 12 full yearsfede has been a member for 12 full yearsfede has been a member for 12 full yearsfede has been a member for 12 full yearsfede has been a member for 12 full yearsfede has been a member for 12 full yearsfede has been a member for 12 full yearsfede has been a member for 12 full yearsfede has been a member for 12 full years
Topics: 68
Postby herbal_gardens [OP] » March 7th 2009, 6:11pm
Thanks for all the input, yea not too complicated, after I took the time and studdied it lol, removed the gromet and it was easier than anticipated....(thanks again)
herbal_gardens
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 21
Postby jiggad69 » March 10th 2009, 6:04am
try reinstalling the top nut!!!!!!!! sometimes i just want to line up every engineer on the planet who built vehicles and kick them all in the nuts as hard as possible!!!!
jiggad69
Years of Membership: jiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full yearsjiggad69 has been a member for 12 full years
Images: 2
Alias (AKA): d man
Postby Cliff5550 » April 5th 2009, 4:10pm
Replacing the handle on my 1989 Safari conversion van was something I couldn't do but a mechanic friend was able to "work blind" for about and hour and a half and finally fit the new outside handle on. One big problem is the window track hides much of the work area, and the window track, unlike a lot of them, can't be removed by screws, nuts and bolts because it's welded in place. Sucks. I have to replace the one on the back door but I'm deciding now if I want to even bother. Is the rear door handle any easier? At least there shouldn't be a window track.
Oh yeh, HI. New here. Just bought the 89 Safari conversion and I've already picked up a few tips here and there on the site.
Cliff5550
Years of Membership: Cliff5550 has been a member for 11 full yearsCliff5550 has been a member for 11 full yearsCliff5550 has been a member for 11 full yearsCliff5550 has been a member for 11 full yearsCliff5550 has been a member for 11 full yearsCliff5550 has been a member for 11 full yearsCliff5550 has been a member for 11 full yearsCliff5550 has been a member for 11 full yearsCliff5550 has been a member for 11 full yearsCliff5550 has been a member for 11 full yearsCliff5550 has been a member for 11 full years
Postby astro355 » April 5th 2009, 8:13pm
Yes, the rear door handles are easier. Which one are you replacing on the rear?
astro355
Postby Cliff5550 » April 7th 2009, 12:57pm
Just have the one handle on the right rear. I've bought the handle but not sure I would gain much by opening the door. My '89 has a GranVille conversion and the bed/sofa are so close and low at the back there's not really any need for the doors to open. Actually, I think I'm just stalling for warmer weather. It's still awful cold here in Central Illinois.
Cliff5550
Postby Positive P » April 9th 2009, 1:28am
Cliff5550 wrote:Just have the one handle on the right rear. I've bought the handle but not sure I would gain much by opening the door. My '89 has a GranVille conversion and the bed/sofa are so close and low at the back there's not really any need for the doors to open. Actually, I think I'm just stalling for warmer weather. It's still awful cold here in Central Illinois.
Really? It's still cold up there?
We just had a week of cold mornings, days in the 80's. Soorry to hear that.
Positive P
Topics: 47
Extra Info: 4.3L
Postby toddb » April 16th 2009, 5:58pm
I've replaced these stupid door handles numerous times. One of the few complaints I have with these vans. This time I tried something different. A true farmers fix. What has happened to me every time they break is first the handle cracks. next the lever that does the actual opening breaks off.
So, my handle cracked - I got some wide and thin screws #8 and screwed them into the door holding the cracked handle firmly in place, then I had to grind them even thinner as the handle was bottoming out on the screws. problem solved and took 5 minutes of my time and cost nothing. Repair has lasted for 4 months now.
1997 Safari 2WD 3:73 locking. 300,000 km - almost full load.
2000 Safari AWD 3:73 locking. 275,000 km - Full load.
toddb
Years of Membership: toddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full years
Postby rev_les » May 16th 2009, 5:46am
I just did the drivers handle on my '95..taking the latch off helps with getting the top nut on, but I agree with jiggad69.... this is some of the dumbest engineering I've seen yet..... maybe they dug the idea out of Ford's dumpster, :lol:
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Postby stoneground1 » May 16th 2009, 6:35am
Hey Positive P. What year were the Lumina MPV/Silhouette? The local U-Pull-It doesn't have a single handle on any Astro/Safari.
I've got a 92' Ext. Maybe i can find the Lumina MPV/Silhouette. Thanks.
In Life it's all about Choices!!!!
stoneground1
Years of Membership: stoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full yearsstoneground1 has been a member for 12 full years
Topics: 29
Postby rev_les » May 16th 2009, 6:50am
NEW aftermarket ones are only like 12 bux with shipping....
NRA Lifetime Member
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 39
Alias (AKA): Les
Postby Mr_Bowtie » May 16th 2009, 2:37pm
I got this friend who knows a guy that just replaced his driver's door handle, but left the top nut off cause he gave up on it. The handle is working just fine and doesn't move or anything(I've been told :lol: ). You guys see a problem with using just the one bottom nut to hold the door handle in place? :banana:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby rev_les » May 16th 2009, 10:14pm
well, one could comment about your friend's friend only having one nut, lol :rofl:.......................................on the door handle, i mean
NRA Lifetime Member
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 39
Alias (AKA): Les
Postby Mr_Bowtie » May 19th 2009, 2:13am
My friend's friend just got burned! :banghead:
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Postby steve1606 » May 19th 2009, 3:30am
man even up in Canada the snowss gone and its basically 20+(celsius that is)
92 Safari 4.3 V6
steve1606
Years of Membership: steve1606 has been a member for 11 full yearssteve1606 has been a member for 11 full yearssteve1606 has been a member for 11 full yearssteve1606 has been a member for 11 full yearssteve1606 has been a member for 11 full yearssteve1606 has been a member for 11 full yearssteve1606 has been a member for 11 full yearssteve1606 has been a member for 11 full yearssteve1606 has been a member for 11 full yearssteve1606 has been a member for 11 full yearssteve1606 has been a member for 11 full years
Postby rev_les » May 19th 2009, 5:43am
When I did mine the other night, I was making up new words trying to get that top one on. even taking the latch out, getting all the rods hooked back up with anything bigger than a spider monkeys hands is next to impossible. I ended up using the long snap on needle nose with the angled tip, a 1/4" drive extension, a door panel clip popper, 1/4 pint of my blood, 3 or 4 sq" of skin...
NRA Lifetime Member
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Topics: 39
Alias (AKA): Les
Postby toddb » May 19th 2009, 5:50pm
rev_les wrote:When I did mine the other night, I was making up new words trying to get that top one on. even taking the latch out, getting all the rods hooked back up with anything bigger than a spider monkeys hands is next to impossible. I ended up using the long snap on needle nose with the angled tip, a 1/4" drive extension, a door panel clip popper, 1/4 pint of my blood, 3 or 4 sq" of skin...
Too funny. Also the one about kicking engineers in the nuts.
Thats why I did the farmers repair (explained five or six posts up). Still going strong.
toddb
Return to Exterior
It is currently October 26th 2020, 5:43pm
Exterior Forum
Attached by: AlpineVan
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 7:12pm
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 6:58pm
AstroOafAdventurer
in Exterior
Comments: 0
Date: Oct 21 '20
Time: 8:16pm
Tanino
in Exterior
Date: Oct 18 '20
Time: 5:34pm
Olivier02
in Exterior
Date: Oct 11 '20
Time: 8:40pm
Users browsing this forum: drameydramey is online!, foxfirefoxfire is online! and 14 guests
