Door lock cylinder popped out, how do I keep it in?
Postby DownByTheRiver [OP] » October 11th 2013, 11:25pm
Someone smashed a side window and used a screwdriver to half-way pop out the door lock cylinder on the driver's side door.
I can still use my key to open the door, but after driving for a while the cylinder starts to vibrate enough to almost fall out.
Should I use some type of super glue, or is there a special way to fix it?
DownByTheRiver
Years of Membership: DownByTheRiver has been a member for 9 full yearsDownByTheRiver has been a member for 9 full yearsDownByTheRiver has been a member for 9 full yearsDownByTheRiver has been a member for 9 full yearsDownByTheRiver has been a member for 9 full yearsDownByTheRiver has been a member for 9 full yearsDownByTheRiver has been a member for 9 full yearsDownByTheRiver has been a member for 9 full yearsDownByTheRiver has been a member for 9 full years
Extra Info: 4.3L V6 AWD 165K
  • Rivnuts or Bolt, washers, lock-tight with nuts
    by bradaskins » June 4th 2020, 12:19am in Exterior
    June 8th 2020, 10:59pm
  • the bar and the catch for the lock system...
    by GPSTwood » October 1st 2020, 12:43am in Exterior
    October 1st 2020, 2:33am
    16
    December 1st 2020, 12:51pm
Re: Door lock cylinder popped out, how do I keep it in?
Postby Drummernaut » October 11th 2013, 11:33pm
There is a retainer that keeps the lock in the door. It may have fallen off or got damaged and may have fallen inside on the bottom of the door.
It should look like #31 in this diagram:
http://www.genmotorinfo.com/Picture.aspx?Make=Chevrolet&Model=Astro&Year=1999&SubModel=AWD&SectionID=16&SectionDesc=CAB%20AND%20BODY%20PARTS,%20WIPERS,%20MIRRORS,%20DOORS,%20TRIM,%20SEAT%20BELTS&PicDesc=DOOR+HARDWARE%2fSIDE+FRONT+-+LM+&pid=051004TM16-464
You will have to remove the interior panel to access it. Trying to use any glue will just make more of a mess and may do damaged to the inside parts or the window track.
1999 Astro LT AWD
MODS: Electric fan, Transmission cooler/fan, AWD engaged LED
Drummernaut
Years of Membership: Drummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full yearsDrummernaut has been a member for 9 full years
Topics: 9
Alias (AKA): Drummer From Hell
Extra Info: LT V6 AWD
Postby machinehead » October 11th 2013, 11:47pm
The clip described can be purchased at any automotive parts store or any lock shop that deals with auto. door locks.
machinehead
Years of Membership: machinehead has been a member for 9 full yearsmachinehead has been a member for 9 full yearsmachinehead has been a member for 9 full yearsmachinehead has been a member for 9 full yearsmachinehead has been a member for 9 full yearsmachinehead has been a member for 9 full yearsmachinehead has been a member for 9 full yearsmachinehead has been a member for 9 full yearsmachinehead has been a member for 9 full years
Postby RECox286 » October 12th 2013, 1:30am
Trick is, you have to access the inside of the door.
Good hunting
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby machinehead » October 18th 2013, 1:34am
Access the inside of the door by removing the inside door panel .
Info. for all is available on the net ., just type in your questions .?
machinehead
Return to Exterior
It is currently December 1st 2020, 12:51pm
Exterior Forum
Tanino
in Exterior
Date: Nov 29 '20
Time: 11:30am
kevinfin
in Exterior
Date: Nov 24 '20
Time: 10:20pm
foxfire
in Exterior
Comments: 43
Date: Nov 23 '20
Time: 9:30pm
in Exterior
Comments: 43
Date: Nov 18 '20
Time: 9:04pm
foxfire
in Exterior
Comments: 43
Date: Nov 15 '20
Time: 2:33am
