Replacement Lock
Replacement Lock
Postby Wolphin [OP] » June 15th 2009, 3:55am
I locked myself out of my Astro today, when I was out in the mountians :banghead: (The sliding side door decided it wanted to lock, even though I wanted it unlocked!)
A kind person gave me a flathead screwdriver, with which I was able to smash and crack the rear door's lock enough to turn it without the key, to unlock the door - nobody had a coathanger to use to unlock my door :(
All in all, I need to find somewhere that would have the replacement lock, and what's the chances of getting it keyed to my existing keys?
Wolphin
Years of Membership: Wolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full yearsWolphin has been a member for 13 full years
Alias (AKA): Wolphin
Extra Info: 4.3 L V6 AWD
  • the bar and the catch for the lock system...
    by GPSTwood » October 1st 2020, 12:43am in Exterior
    October 1st 2020, 2:33am
  • LED Headlight Replacement-Safari
    by BobbyD » September 5th 2020, 10:08pm in Exterior
    Last post by joeg View the latest post
    September 16th 2020, 10:02pm
    34
    March 4th 2021, 11:05am
Re: Replacement Lock
Postby ghostrider1061 » June 15th 2009, 6:41am
i myself would go to my local g m dealer.there they should be able to fix you up witha new lock and put the combo in so you can use your old keys. :2:
ghostrider1061
Years of Membership: ghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full yearsghostrider1061 has been a member for 11 full years
Topics: 17
Alias (AKA): d j
Extra Info: 4.3L v-6 rwd
Postby Matrixx » June 15th 2009, 6:46am
Hi Wolphin
For a new lock, maybe try rockauto.com
For a used lock, try the auto wreckers
Either way, you will need to have it keyed by a locksmith or a dealership. I did that once, and I was lucky to have a coat hanger near by. I now have a back up key and I keep it in my wallet at all times, never happened since, but I'm ready if it does. Food for thought.:)
Matrixx
Postby rev_les » June 15th 2009, 6:00pm
I hooked this thing called a "taplock" onto mine. I tap a code on the glass and it unlocks the doors. I put it on when I lived in south Florida because when I was diving I just locked everything up that I couldn't take underwater with me.
NRA Lifetime Member
2'nd amendment supporter
'13 Jeep Patriot
'87 Monte Carlo SS
'79 Avco 32' RV
rev_les
Firing on 2 Cylinders (L3)
Years of Membership: rev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full yearsrev_les has been a member for 12 full years
Topics: 39
Alias (AKA): Les
Extra Info: LS 4.3 RWD
Return to Exterior
It is currently March 4th 2021, 11:05am
Exterior Forum
Olivier02
in Exterior
Date: Mar 02 '21
Time: 2:48am
in Exterior
Date: Feb 28 '21
Time: 4:18am
AstroOafAdventurer
in Exterior
Date: Feb 27 '21
Time: 8:28pm
in Exterior
Date: Feb 24 '21
Time: 7:48pm
SheldonYoung
in Exterior
Date: Feb 24 '21
Time: 12:23am
