'90 Safari Door Handle Replacement, Grease?
Postby 98cirider [OP] » October 16th 2009, 5:46pm
A couple years ago I replaced the drivers exterior door handle on my '90 Safari. Well, the passenger exterior door handle decided to give up the ghost. I have replacement ready to go. Before I do the replacement, is there any special grease or lubricant I should work into all the moving parts of the new handle before installing it?
Thanks,
David
Broken handle, still actually works.
New Handle, bought from 1A Auto.
1990 GMC Safari SL 4.3L, Z engine, (Original owner)
As of August 1, 2011: 237,050 miles
Purchased new from dealer with Explorer Conversion Package
98cirider
Years of Membership: 98cirider has been a member for 11 full years98cirider has been a member for 11 full years98cirider has been a member for 11 full years98cirider has been a member for 11 full years98cirider has been a member for 11 full years98cirider has been a member for 11 full years98cirider has been a member for 11 full years98cirider has been a member for 11 full years98cirider has been a member for 11 full years98cirider has been a member for 11 full years98cirider has been a member for 11 full years
Topics: 23
Alias (AKA): David
Extra Info: 4.3L RWD Shorty
Re: '90 Safari Door Handle Replacement, Grease?
Postby stoneground1 » October 16th 2009, 6:30pm
98cirider,
These are basically plug and play. I've replaced front drivers and rear door handles. You could lube it up if you want
but not really needed. If you have a U-Pull-It around you i'd go out there and try and find a few clips from like a
96'-?. The clips they have on the 85'-95's are a pain to work with. Talking about where the link connects to the
handle. Wish i had a pic handy to show you. The ones from the 96'-? are plastic but they are so much easier to use!
How much did you get the new handle for?
In Life it's all about Choices!!!!
stoneground1
Years of Membership: stoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full yearsstoneground1 has been a member for 13 full years
Topics: 29
Postby Mr_Bowtie » October 16th 2009, 6:46pm
I installed one so far on my Astro without any grease and its been fine. I have to do the driver's side one on my Safari pretty soon too. :banghead:
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Years of Membership: Mr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full yearsMr_Bowtie has been a member for 12 full years
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby 98cirider [OP] » October 16th 2009, 7:46pm
stoneground1 wrote:98cirider,
From 1A Auto, it was $24.90 delivered. I felt comfortable with the price. I have not even tried to find a wreakyard here in the Phoenix area. I know there is a strip several miles long in the southern part of the city, but I have not ventured over there.
David
98cirider
Topics: 23
Alias (AKA): David
Postby Munken » October 17th 2009, 2:11pm
I agree with stoneground1 about "plug and play", but I would lubricate the mechanism with ball bearing grease to keep out water and dirt.I think it pays in the long run. :thumbup:
"Nothing is impossible, the impossible just takes a little longer"
Munken
Firing on 5 Cylinders (L2)
Years of Membership: Munken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full yearsMunken has been a member for 11 full years
Topics: 69
Alias (AKA): Munken the lunatic
Extra Info: LT 4.3L V6 RWD
Postby sturoc » November 12th 2013, 10:02pm
Reviving this, due to not seeing any info on '89 Astro door handles with regards to the rod clips.
i am at the point where all I have to do is get that small rod off the door handle linkage so I can pull out the broken handle and replace.
But I see there is some type of clip that captures the link rod end to hold it in place.
How the heck does that come off ?
I can barely get a needle nose pliers in there but gets no good grip on the clip and not even sure if it does just pull off.
The whole job has been a bit a battle and am starting to wonder how it will all go back together?
Will have to do the same for the pass door as well. ugh.
'89 Astro Van cargo, 4.3 tbi, Auto trans rwd
sturoc
Years of Membership: sturoc has been a member for 10 full yearssturoc has been a member for 10 full yearssturoc has been a member for 10 full yearssturoc has been a member for 10 full yearssturoc has been a member for 10 full yearssturoc has been a member for 10 full yearssturoc has been a member for 10 full yearssturoc has been a member for 10 full yearssturoc has been a member for 10 full yearssturoc has been a member for 10 full years
Topics: 20
Extra Info: Cargo 4.3 Auto rwd
Postby RECox286 » November 12th 2013, 10:38pm
Outside door handles can be manipulated so that you can disconnect the pull rod from outside of the mounting hole.
Simply remove the two hold down nuts that retain the handle to the door, and pull/twist/extend until the guts come
thru the hole. Now it is much easier to remove the assy from the pull rod.
Good hunting
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby sturoc » November 12th 2013, 11:11pm
Nice tip worked great and the hold clip is just that , a slide on clip.
Earlier I popped off the window crank 'c' clip with some creative a positioning of a screwdriver
The cranks were on really good so don't think its mandatory to replace that clip.
Starting on Pass door now gonna be alot quicker
Next to order the new door handle assys
thanks
sturoc
Topics: 20
Postby RECox286 » November 13th 2013, 5:24am
One other trick: Drill a hole like the one for the lower nut in the door skin, on top of the latch.
Use a 1/4" drive 10mm swivel socket and long extension to get the upper nut. When you're done,
add a rubber plug like the one below the latch to finish off the installation, and next time you won't
have to take the door trim panel off to get the handle replaced. Works great, especially if you use
a heavy hand when opening the doors. I like to keep the hinges, latches, key tumblers, and handles
lubricated with a shot of WD40 at each oil change interval. Haven't had to change any of those types
of hardware for a long, long time.
Keep truck'n
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Return to Exterior
It is currently April 23rd 2021, 11:30am
Exterior Forum
Attached by: GaryMacGuyver
GaryMacGuyver
in Exterior
Comments: 0
Date: Apr 17 '21
Time: 10:37pm
Attached by: Godron629
Godron629
in Exterior
Comments: 20
Date: Apr 05 '21
Time: 4:46pm
in Exterior
Date: Apr 02 '21
Time: 4:50pm
Bigforkg
in Exterior
Comments: 0
Date: Mar 26 '21
Time: 1:05am
Tanino
in Exterior
Date: Mar 23 '21
Time: 11:51am
Users browsing this forum: Yandex [Bot] and 7 guests
