Leaking rainwater into the interior!
Postby 0dysseus [OP] » March 7th 2014, 4:02pm
Hi Guys and Gals, I'm new to this blog, I'm also new to Astro Vans in that I just bought one last month (a 98 RWD, extended cab). I love this van and i bought in less-than-ideal condition but it was still a steal for $1600 w/100k miles. So far I've replaced the shocks, battery housing, spark plugs and wires, a few hoses, changed the oil etc. I want to customize the interior, the floor matting is soaking wet and nasty and so I tore it out, however, this leads to the more important question of where the water is coming from. In addition to disgusting floor matting, the rear passenger side of the headliner is soaking wet (as it had rained last night) and now i must fix this problem because I got this van for the purpose of having to travel alot for my job, and wanting to avoid sleeping in motels, and so i will customize my space here. Though I can't do jack in the interior until I get this problem taken care of. I completely lack instruction and knowledge for this problem and I want to seek, diagnose, and destroy the problem so I can move on in transforming the van into a camper. As far as I can tell, there are two regions for water entry: 1) the rear passenger side of the headliner, all along the passenger side, but not extending to the sliding door (behind it, rather). 2) the rear door, passenger side, has a window that is slightly ajar (an easy fix? adhesive foam and a clamp?) It seems that only a minimal amount of water can come in through the rear window, so I am mostly concerned with where and how to begin with the roof leak.
0dysseus
Years of Membership: 0dysseus has been a member for 7 full years0dysseus has been a member for 7 full years0dysseus has been a member for 7 full years0dysseus has been a member for 7 full years0dysseus has been a member for 7 full years0dysseus has been a member for 7 full years0dysseus has been a member for 7 full years
Extra Info: 4.3 V6 RWD
Re: Leaking rainwater into the interior!
Postby WoodButcher » March 8th 2014, 3:28am
Got a roof rack?
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby 0dysseus [OP] » March 12th 2014, 3:59pm
Hi. No, I don't have a roofrack, however I pulled one off of a 97 Astro in junkyard and I'll be putting it on my 98 today- I figured it would be a good job to do while I have the headliner down, so I can have access in applying silicone sealant to wherever needed. I suspect its leaking from the weatherstripping on the passenger side, since it is old and the underlying sealant that was likely applied while manufactured has now lost its integrity and has many apparent cracks and fissures.
0dysseus
Postby Silverhawk » March 12th 2014, 4:04pm
When you get the headliner out have someone use a garden hose and spray water on the roof. You should be able to tell where the water is getting in.
Silverhawk
Years of Membership: Silverhawk has been a member for 7 full yearsSilverhawk has been a member for 7 full yearsSilverhawk has been a member for 7 full yearsSilverhawk has been a member for 7 full yearsSilverhawk has been a member for 7 full yearsSilverhawk has been a member for 7 full yearsSilverhawk has been a member for 7 full years
Topics: 25
Images: 13
Postby kennysmoke » March 12th 2014, 4:32pm
I had that problem on my '97... ended up being a bad seal on the upper corner of the windshield traveling back...
"Live Free Or Die" Image
kennysmoke
Blue Status (L2)
Blue Status (L2)
Topics: 68
Images: 7
Alias (AKA): kennysmoke
Extra Info: AWD Tow Pakage
Return to Exterior
It is currently March 7th 2021, 6:08am
Exterior Forum
Olivier02
in Exterior
Date: Mar 02 '21
Time: 2:48am
in Exterior
Comments: 14
Date: Feb 28 '21
Time: 4:18am
AstroOafAdventurer
in Exterior
Comments: 14
Date: Feb 27 '21
Time: 8:28pm
in Exterior
Date: Feb 24 '21
Time: 7:48pm
SheldonYoung
in Exterior
Date: Feb 24 '21
Time: 12:23am
