Replacing Door Window Channel WEATHERSTRIP
Postby Vanjoe [OP] » May 7th 2014, 5:56pm
I need to replace this part yesterday but I can't figure out how to do it! The weatherstrip sits inside of the channel that is item #2 in the link below. Has anyone been thru this? Mine are split and falling apart and I am tinting windows and pulled it off and pulled one at a JY. It seems it needs to just slide down in, on the rear side of the door first and also slip over the glass.
I can't be the first person to do this. Any tricks?
#2 in this image - body hardware, front door, glass & hardware, weatherstrip Left
98 Sterling Hi-top Conversion
Former
90 Astro conversion
91 ext Astro I added 350/4bl .TOTALED..my fault
88 Astro conversion 177k-270k,threw rod.
85 Astro mint body ,totaled 9 days later Paid $1k, insurance gave me $2k
86 Astro 147k-242k, sold running!
Vanjoe
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Vanjoe has been a member for 10 full yearsVanjoe has been a member for 10 full yearsVanjoe has been a member for 10 full yearsVanjoe has been a member for 10 full yearsVanjoe has been a member for 10 full yearsVanjoe has been a member for 10 full yearsVanjoe has been a member for 10 full yearsVanjoe has been a member for 10 full yearsVanjoe has been a member for 10 full yearsVanjoe has been a member for 10 full years
Topics: 7
Alias (AKA): Joe
Extra Info: Sterling Convers
  • Power Window Motor Spins, Window Won't Move
    by BillyJoBob » January 24th 2021, 8:54pm in Exterior
    January 26th 2021, 2:17am
  • Sliding door window not tight to seal
    by AstroOafAdventurer » December 15th 2020, 4:22am in Exterior
    January 14th 2021, 9:42pm
    83
    April 20th 2021, 5:01pm
Re: Replacing Door Window Channel WEATHERSTRIP
Postby gavio » May 7th 2014, 6:28pm
I haven't done it on an Astro, but been through it plenty of times....
Start by lubing the outside of the molding and the inside of the channel - I use a little cooking oil
With the window down, slide the molding down in the track as far as you can
insert the molding into the track further up the channel (above the top edge of the window)
Roll the window up about halfway while holding the molding so it doesn't come up with it
Then roll the window down while pushing the molding down simultaneously
The window will help you by grabbing the fuzzy inner part of the molding
But it probably won't go down all the way, soooo.....
Repeat until you are bugeyed
It helps if your tongue is held on the left side of your mouth
Now you're done
gavio
Years of Membership: gavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full yearsgavio has been a member for 8 full years
Topics: 77
Images: 4
Postby Vanjoe [OP] » May 7th 2014, 6:31pm
Nice! Use the power window to help. I never would have thought to do that. For lube, I figured soapy water. THANK YOU!
Former
90 Astro conversion
Vanjoe
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 7
Alias (AKA): Joe
Postby gavio » May 7th 2014, 6:40pm
Good luck
gavio
Topics: 77
Images: 4
Postby smokinjoe » May 7th 2014, 7:22pm
Soapy water or windex works. When I did mine I couldnt believe how quiet the ride got.
No dis-assembly of the door is needed.
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 271
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
Postby Vanjoe [OP] » May 10th 2014, 8:10pm
The idea of using the window helped! I raised the window up from bottom and that helped get the weatherstrip started. And installing it from the outside helped with the curve of the channel. LOTS of soapy water and it went in easy. Just used a rubber mallet to seat the corners.
Former
90 Astro conversion
Vanjoe
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 7
Alias (AKA): Joe
Postby gavio » May 10th 2014, 9:20pm
Nice! Glad to hear it worked out....
gavio
Topics: 77
Images: 4
Return to Exterior
It is currently April 20th 2021, 5:01pm
Exterior Forum
Attached by: GaryMacGuyver
GaryMacGuyver
in Exterior
Comments: 0
Date: Apr 17 '21
Time: 10:37pm
Attached by: Godron629
Godron629
in Exterior
Comments: 20
Date: Apr 05 '21
Time: 4:46pm
in Exterior
Date: Apr 02 '21
Time: 4:50pm
Bigforkg
in Exterior
Comments: 0
Date: Mar 26 '21
Time: 1:05am
Tanino
in Exterior
Date: Mar 23 '21
Time: 11:51am
