Shim new hinge to fix driver's door alignment?
Postby baytonemus [OP] » May 13th 2014, 5:48pm
The lower hinge on my driver's door was broken, so I pulled the door, removed the old hinge, and installed the GM bolt-on replacement hinge. The door is sagging a bit, however, so I'm trying to come up with a solution to realign it. There is some wiggle room provided by the oversized bolt holes in the new hinge, but it seems to me that I'm going to need to put a shim behind the new hinge.
I've never done any door adjustments, so I'd appreciate knowing if I'm on the right track or if I might be creating another set of problems by shimming. Thanks.
2000 GMC Safari SLE - AWD
baytonemus
Years of Membership: baytonemus has been a member for 8 full yearsbaytonemus has been a member for 8 full yearsbaytonemus has been a member for 8 full yearsbaytonemus has been a member for 8 full yearsbaytonemus has been a member for 8 full yearsbaytonemus has been a member for 8 full yearsbaytonemus has been a member for 8 full yearsbaytonemus has been a member for 8 full years
Topics: 9
  • Safari Driver door year compatibility
    by demersn » June 2nd 2020, 12:35am in Exterior
    June 7th 2020, 9:22pm
  • How do I get rid of an extra door?
    by Sklar » May 6th 2020, 9:49pm in Exterior
    Last post by 90safari View the latest post
    May 6th 2020, 10:54pm
    9
    82
    October 25th 2020, 5:26am
Re: Shim new hinge to fix driver's door alignment?
Postby RECox286 » May 13th 2014, 7:14pm
Try this:
Open the door enough to be able to slide a 2x4x2' between the doorwell and the door bottom on the latch side. Slide another
piece of 1x scrap lumber on top of the 2x4 to pad the door bottom. Once you have the "lever and pad" all in alignment, carefully
lift the door forcing the hinges to bend the sheetmetal. (somewhat more forcefully, if at first you don't succede) Check the
alignment of the door to the body and how the latch aligns with the bolt as you close the door. Don't over stress the sheet metal.
You may want to check the top hinge for worn bushings and pin by opening the door, grabbing the bottom of the door and raising
the latch side of the door and letting it drop (an easy rocking motion) as you watch the top hinge for looseness. Repair the top
hinge if necessary before trying to "lever" the door into alignment. As you will note, Chevy didn't make door hardware to outlast the
rest of the truck, but we still love the beasts in spite of their faults !
Keep on Truck'n
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby chevymaher » May 14th 2014, 12:25am
Washers between the lower hinge and door. I used to do it to camaros works like a champ.
Postby Big_kid » May 14th 2014, 1:47am
Ugh... camaro hinges. thanks for THAT flashback! (but I once found an almost new set in a firebird at a junk yard)
Firing on 6 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby chevymaher » May 14th 2014, 1:51am
Big_kid wrote:Ugh... camaro hinges. thanks for THAT flashback! (but I once found an almost new set in a firebird at a junk yard)
yep longest door ever made besides the old monte's. And women seemed to think they were a chair when it was open.
Postby Astrofarian » May 15th 2014, 1:05am
And how about the snort & grunt session that followed the first (and hopefully ONLY time) you unbolted one of these doors by yourself @ 12:30 a.m. and tried to GENTLY ease it onto the creeper without dropping it? :rofl: :banana: :rofl:
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby chevymaher » May 15th 2014, 1:10am
2 jackstands under it when you unbolt it.
Postby baytonemus [OP] » May 15th 2014, 4:04pm
If you shim with washers there is obviously a gap created where water and debris can collect. Would you normally seal the edges then? Also, with the hinge kind of floating in that way and maybe flexing a bit, will the sealant stay in place?
baytonemus
Topics: 9
Postby Casey » May 17th 2014, 3:33pm
baytonemus wrote: There is some wiggle room provided by the oversized bolt holes in the new hinge, but it seems to me that I'm going to need to put a shim behind the new hinge.
There should be enough room in the factory hinge holes to allow for proper adjustment, provided the front fender, door, and body were never tweaked in an accident. The in-out adjustment is made on the door half of the hinge, so I would suggest slightly enlarging the adjustment holes instead if adding a shim(!). You want the hinge halves bolted tightly to the body structure and/or door shell, and using a shim is going to make the bolt the load bearer in that situation. :naughty:
Door adjusting is neither fun nor easy, so get a friend to help. If you can rent (or have) and engine hoist, put it to good use to support the door while you make the adjustments.
Casey
Years of Membership: Casey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full yearsCasey has been a member for 11 full years
Topics: 24
Extra Info: 4.3L LT 5-speed
Return to Exterior
It is currently October 25th 2020, 5:26am
Exterior Forum
Attached by: AlpineVan
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 7:12pm
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 6:58pm
AstroOafAdventurer
in Exterior
Comments: 0
Date: Oct 21 '20
Time: 8:16pm
Tanino
in Exterior
Date: Oct 18 '20
Time: 5:34pm
Olivier02
in Exterior
Date: Oct 11 '20
Time: 8:40pm
