The repainting of astro355
Postby astro355 [OP] » January 14th 2010, 12:45am
I decided a while ago that I was going to repaint my van. I figured that I would start small and learn the tricks of the trade, so to speak.
The first damaged area to be repair. It had an accident with a lawn mower meaning the pushing mower was "pushed" into the van. Left a deep scrape straight to the metal.
The area has been thoroughly cleaned and taped.
Another angle of the area to be repainted.
The scratched area after it was wet-sanded with 400 grit.
Another picture of the sanded area. You can see the rings in this one.
Next the primer was sprayed on. I sprayed on several thin coats to build up the primer. I used a template to help control the hard paint lines which is why you can see an outline.
I used 600 grit to wet-sand the primer area followed up with a 1500 wet sand to remove all of the 600 grit marks.
Jet Black is the paint I will be using for the van. Here is after a couple coats of that paint.
The clear coat is next. As you can see in this picture, the jet black is different than factory black. The difference shows a lot more than it does in person. Last thing to do is buff it out. The spot is dust floating in the air.
Another angle of the finished product. As Munken mentioned to me, the Standox paint I'm using does leave an orange peel effect. Look at the reflection of the light on the quarter panel. Just part of the learning I suppose. Again, the spot is dust floating in the air.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
  • Galvanized Paint repainting process.
    by silasthemac » May 6th 2020, 5:29am in Exterior
    Last post by Astro Pop View the latest post
    May 6th 2020, 11:09pm
    32
    October 29th 2020, 3:09am
Re: New first paint related repair
Postby astroturf » January 14th 2010, 12:49am
Progress. Can not wait to see the finished product.
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Mr_Bowtie » January 14th 2010, 3:11am
Way better then I can do......... :clap: All jet black will look killer!
'96 Dodge 2500 Ramwagon Van
'68 VW Bug 1600cc
'00 Grand Prix GT
Mr_Bowtie
Topics: 74
Images: 29
Van Model Year: 1985
Extra Info: 350 with 700r4
Postby Jasen » January 14th 2010, 3:23am
Looks good.
If you put on a little extra clear coat. you can sand it pretty hard once it's cured and get out a lot of the orange peel.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby astro355 [OP] » January 14th 2010, 3:34am
Jasen wrote:Looks good.
Yup, that's what I did. After looking at it an hour ago, I can sort of see the repair area under the paint. Anybody have an idea of what I did/didn't do to cause that?
astro355
Postby Jasen » January 14th 2010, 3:47am
Maybe you didn't feather it out far enough.
200k
Ultra gauge
Topics: 260
Images: 101
Postby astro355 [OP] » January 14th 2010, 9:46am
Jasen wrote:Maybe you didn't feather it out far enough.
I suppose. You don't see the area of the primer, you see the area of the sanding rings. Maybe the primer was too light or I sanded too much away?
astro355
Postby Jasen » January 15th 2010, 2:30am
That's what I've run into in my early years at playing with body work. The primer looked good, but when the paint went on is when things started showing up.
Did you hand sand or block sand?
200k
Ultra gauge
Topics: 260
Images: 101
Postby offroad safari » January 15th 2010, 3:25am
i've learned painting is definately an art and i need more practice.
'90 AWD Shorty Safari
4" Overland Lift + countless mods
"It's a Safari thing.... Jeep people couldn't understand"
offroad safari
Years of Membership: offroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full yearsoffroad safari has been a member for 11 full years
Topics: 19
Alias (AKA): Witman40
Extra Info: AWD Shorty
Postby webcat » January 15th 2010, 5:06am
Mayby you did'nt sand it enough with the finer sandpapers ?
I'm thinking if you sanded the hell out of it with the finer sand papers and sanded well beyond the little area to keep the panel looking straight would'nt it be impossible for it to show up through your paint and you probally would'nt even need primer , i normally dont use primer because i had a bad experience where it made my paint a little lighter in color , i was thinking if i ever used primer again i would prime the entire panel .
All the vehicles i did'nt use primer on came out perfect .
i would like to see what a Pro like Munken has to tell us as i'm just a backyard painter like you guys.
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby astro355 [OP] » January 15th 2010, 10:40am
webcat wrote:Mayby you did'nt sand it enough with the finer sandpapers ?
Using the primer is supposed to save you sanding time by filling the work area. Just as the same reason why I'm wet-sanding instead of dry sanding. I'm sure that the fact that I don't have a block sander is the reason why the sanding area shown threw, as Jasen mentioned.
astro355
Postby evil_motors » January 15th 2010, 3:25pm
i probably would have used a small bit of body filler and used that to sand down instead of the primer.
1992 GMC Safari XT , Rhinolined interior, Fatmat walls and celing, Racing seats, Satin Black Dash, Taplock, Clear Corners, Check out my continuing thread with all my mods and lots of pictures.
https://www.astrosafari.com/viewtopic.php?f=9&t=3769
evil_motors
Years of Membership: evil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full yearsevil_motors has been a member for 11 full years
Topics: 26
Extra Info: XT RWD
Postby toddb » January 15th 2010, 8:04pm
Problem of not using primer is that paint generally does not adhere to bare metal well.
1997 Safari 2WD 3:73 locking. 300,000 km - almost full load.
2000 Safari AWD 3:73 locking. 275,000 km - Full load.
toddb
Years of Membership: toddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full years
Postby astro355 [OP] » January 19th 2010, 12:31am
I have moved on to the hood.
Pic of the hood before painting. Its really not straight.
Additional pic of the hood before painting. Again, not straight at all.
Its cleaned and prepped for sanding. You can see even more dents.
After the initial sanding. Just a lot of highs and lows.
After the first filler is added. I'm not crazy about filler but I'm really not crazy about dents and such.
After the first layer of primer. But unfortunately not the last coat of primer.
astro355
Re: The repainting of astro355
Postby astroturf » January 19th 2010, 12:41am
That project is coming along nicely.
astroturf
Topics: 112
Postby Jasen » January 19th 2010, 4:29am
Block sand my friend ;)
A little bondo isn't a bad thing. A 1 gal can for one dent on the other hand :lol:
Hey, you could learn to do lead filler.
200k
Ultra gauge
Topics: 260
Images: 101
Postby astro355 [OP] » January 19th 2010, 4:45pm
Jasen wrote:Block sand my friend ;)
Yes, I'm block sanding. I learned my lesson. :roll:
Although I didn't think I can make that hood perfectly straight. Its pretty rough.
astro355
Postby Jasen » January 20th 2010, 1:59am
Chevy hoods have always been trouble. They just always seem to be thin and take damage easily even on cars that don't have the rake of the vans.
You've got an older rig, no worries, I'm sure it'll look better then those stone dent's you had.
I'm watching these rattle can posts pretty closely. I've got a big bubble that cracked on my slider a couple years ago. It showed up shortly after getting side swiped.
I'm going to give it a rattle can repair this spring, as well as the drivers 1/4 panel below the belt, a parking lot present.
200k
Ultra gauge
Topics: 260
Images: 101
Postby astro355 [OP] » January 20th 2010, 9:06am
Rattle can? No rattle cans here, I bought this stuff a while ago:
astro355
Postby tedanderson » January 20th 2010, 11:11pm
Jasen wrote:I'm watching these rattle can posts pretty closely.
I think you have him confused with the other guy.
tedanderson
Firing on 8 Cylinders (L3)
Topics: 76
Alias (AKA): 2Big4aMiniVan
Return to Exterior
It is currently October 29th 2020, 3:09am
Exterior Forum
Attached by: WinnieVan
WinnieVan
in Exterior
Time: 9:09pm
WinnieVan
in Exterior
Time: 8:43pm
in Exterior
Comments: 19
Date: Oct 27 '20
Time: 3:37pm
Attached by: AlpineVan
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 7:12pm
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 6:58pm
