power door locks stick on driver's door and rear door.
Postby g0t0pless [OP] » February 22nd 2010, 5:39am
What is the easy way to correct a sticky power door lock? It'll lock just fine. Nice and strong think when it locks. But unlocking is another story. I can hit the unlock button 100 times, and it barely budges. I end up having to use the key to unlock the doors.
g0t0pless
Years of Membership: g0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full yearsg0t0pless has been a member for 10 full years
Topics: 50
  • Manual Mirror to Replace a Power Mirror?
    by GodIsBed » October 7th 2020, 1:10am in Exterior
    Last post by GodIsBed View the latest post
    October 24th 2020, 5:01am
  • Power Window Motor Spins, Window Won't Move
    by BillyJoBob » January 24th 2021, 8:54pm in Exterior
    January 26th 2021, 2:17am
    7
    47
    January 28th 2021, 6:16am
Re: power door locks stick on driver's door and rear door.
Postby Jasen » February 22nd 2010, 5:42am
Could be a bent rod or just dirty or broken rod connections, old grease that has gotten hard.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Astroplane » February 22nd 2010, 5:57am
PB Blaster works well. Start by spraying into lock latch while door is open.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full yearsAstroplane has been a member for 11 full years
Extra Info: LT RWD
Postby webcat » February 22nd 2010, 6:09am
Astroplane wrote:PB Blaster works well. Start by spraying into lock latch while door is open.
Do you have to grease it afterwords?
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby Astroplane » February 22nd 2010, 6:29am
I usually put a dab of heavy grease on the door handle lever/hinge pins but not until I get the entire system working smoothly. The door lock solenoid usually frees up OK after the bath.
Astroplane
Blue Status (L2)
Blue Status (L2)
Extra Info: LT RWD
Postby Bread Van » March 29th 2010, 9:54pm
I would find a dry lube spray to relube the linkages after you are done cleaning. That way you don't have to worry about dirty, dried, cold pivot points in the future...clean and lubed is the way to go!
Bread Van
Years of Membership: Bread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full years
Topics: 36
Alias (AKA): mapper
Extra Info: AWD 2 inch lift
Return to Exterior
It is currently January 28th 2021, 6:16am
Exterior Forum
VincentVanGo_M
in Exterior
Date: Jan 17 '21
Time: 1:19am
rorgeastro
in Exterior
Date: Jan 05 '21
Time: 3:32am
rorgeastro
in Exterior
Date: Jan 04 '21
Time: 3:37am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 7:41am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 12:20am
