uh oh. Door handles don't work...
Postby JaxSPL [OP] » February 26th 2010, 11:37pm
This morning I had to leave the van at a different place than usual so I could borrow the big truck (moving box truck) form work. Well, when I was able to get back to the van I couldn't get in from the driver side. I also can't open the door from the inside handle. I'm not sure how I am going to get the door open as the panels are 3" thicker than normal due to my speaker panels. I need to get them off to pull the rod to open the door. Really think I'm going to break something in the process.
On another note. Passenger side door is working great with the handles. I can't use the key to lock/unlock it though. When I put the handle on I couldn't get the clip that hold the rod to the lock mechanism on. The window track was in the way. What is the easiest way to do this?
Since the passenger door was locked, thank god my slider door worked and I didn't complete the subwoofer wall. I had enough room between the partial sub wall and B pillar to get the passenger door unlocked. Then had to climb through to the driver side. That was easy since I have no passenger seat (van is not meant for passengers yet).
So, how do I open the driver door without tearing everything up?
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full years
Topics: 45
Images: 9
Extra Info: 4.3L V6 SPL
  • '99 Safari "Quality" Door Handles?
    by FGravity » May 15th 2020, 6:28pm in Exterior
    August 5th 2020, 11:58pm
  • How do I get rid of an extra door?
    by Sklar » May 6th 2020, 9:49pm in Exterior
    Last post by 90safari View the latest post
    May 6th 2020, 10:54pm
    62
    October 25th 2020, 5:46am
Re: uh oh. Door handles don't work...
Postby Jasen » February 27th 2010, 1:44am
Sounds like the rod fell off, but you might still be able to get it with a slim jim. Role the window down, wedge the window out of the way, flash light and slim jim.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby Astroplane » February 27th 2010, 6:40am
JaxSPL wrote:This morning I had to leave the van at a different place than usual
They tried to get in and failed?
JaxSPL wrote:What is the easiest way to do this?
Very cramped quarters. Mini bent long needlenose pliers, etc.
JaxSPL wrote:So, how do I open the driver door without tearing everything up?
Like Jasen said. If that doesn't work, put the window back up and take off armrest, covers,etc. to get more access from inside.
Astroplane
Blue Status (L2)
Blue Status (L2)
Years of Membership: Astroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full yearsAstroplane has been a member for 10 full years
Extra Info: LT RWD
Postby JaxSPL [OP] » February 27th 2010, 2:19pm
This actually sounds easy enough. Thanks guys. I'm fixing to go to the parts store and get some new clips for the rods. Might have to invest in some long needle nose pliers also since I don't own a pair, that I know of. I'll be doing the, "I think I can, I think I can", all darn day until I get it done.. hehe
JaxSPL
Topics: 45
Images: 9
Postby JaxSPL [OP] » February 27th 2010, 7:08pm
Done with it. One of the rod locks came off. I was able to open door from the inside, unlike yesterday where no handles were working. 5 minutes worth of work and now everything is back the way it should be. I am, however, going to have to change the door pin bushings. Door is sagging a little. No biggie there though.
Thanks for the help
JaxSPL
Topics: 45
Images: 9
Postby astroturf » February 27th 2010, 8:22pm
JaxSPL wrote:Done with it. One of the rod locks came off. I was able to open door from the inside, unlike yesterday where no handles were working. 5 minutes worth of work and now everything is back the way it should be. I am, however, going to have to change the door pin bushings. Door is sagging a little. No biggie there though.
Thanks for the help
Good to hear. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby Jasen » February 28th 2010, 12:23am
:thumbup:
200k
Ultra gauge
Topics: 260
Images: 101
Return to Exterior
It is currently October 25th 2020, 5:46am
Exterior Forum
Attached by: AlpineVan
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 7:12pm
AlpineVan
in Exterior
Date: Oct 23 '20
Time: 6:58pm
AstroOafAdventurerAstroOafAdventurer is online!
in Exterior
Comments: 0
Date: Oct 21 '20
Time: 8:16pm
Tanino
in Exterior
Date: Oct 18 '20
Time: 5:34pm
Olivier02
in Exterior
Date: Oct 11 '20
Time: 8:40pm
Users browsing this forum: Yandex [Bot] and 9 guests
