Replaced door handle, door still wont open
Postby Tiny [OP] » April 2nd 2010, 12:08am
When I got my 2001 cargo the rear door latch was snapped off. I ordered a new handle from partsgeeks.com and it arrived yesterday. I went out today crawled in the back and pulled the rear interior panel off and started to fiddle with the latch till the door popped open. Quick easy fix unbolt old handle bolt on new one, close door. Try to open it... wont open, take key from pocket and unlock door to be sure its not just locked. Discover rear door lock doesn't match my key, use climb back inside and unlock rear door from interior hinge, and open door.
With the door open I took a screw driver to simulate striker pin and latch the door. Handle does actuate the rod but not as far as it needs to in order to unlatch the door. Am I missing an adjustment somewhere? Doe I need to try and straighten the rod just a bit to try and take up some of the slack for the handle, Did I somehow order the wrong part even though it all bolts up fine?
2001 Chavy Astro Cargo
1987 Pontiac Fiero GT Getrag 5spd
1988 Pontiac Fiero SE Isuzu 5spd *Parts car*
1984 Yamaha Venture Royale
Tiny
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: Tiny has been a member for 10 full yearsTiny has been a member for 10 full yearsTiny has been a member for 10 full yearsTiny has been a member for 10 full yearsTiny has been a member for 10 full yearsTiny has been a member for 10 full yearsTiny has been a member for 10 full yearsTiny has been a member for 10 full yearsTiny has been a member for 10 full yearsTiny has been a member for 10 full years
Topics: 13
Extra Info: Cargo RWD
  • sliding door wont open
    by DaHonu » August 10th 2020, 6:05pm in Exterior
    Last post by DaHonu View the latest post
    August 11th 2020, 9:28pm
  • Rear bottom door wont open
    by Diablo_deth » January 2nd 2021, 7:42am in Exterior
    January 2nd 2021, 8:23am
    January 16th 2021, 10:21am
Re: Replaced door handle, door still wont open
Postby 1992RS » April 2nd 2010, 1:41am
My first guess would be that a rod got bent somewhere and needs to be adjusted or replaced maybe some one on here has a pic that could guide you in the right direction
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Years of Membership: 1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years1992RS has been a member for 11 full years
Topics: 38
Alias (AKA): tony
Extra Info: RS 4.3v rwd
Postby Tiny [OP] » April 2nd 2010, 3:30am
1992RS wrote:My first guess would be that a rod got bent somewhere and needs to be adjusted or replaced maybe some one on here has a pic that could guide you in the right direction
Had thought about bending it but didn't want to until I got some advice on here.
Tiny
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 13
Postby 1992RS » April 2nd 2010, 3:42am
SO, with the door panel off if you pull on the rod it opens the door easily?? but with the handle the rod just doesnt have enough travel?? if so I would say something is out of adjustement I.E. a bent bar or one that is not bent enough. or maybe the latch needs to be lubed have you tried lubing the latching mechanism I would try that first then if it doesnt work then try looking into other issues
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby Tiny [OP] » April 2nd 2010, 4:23am
1992RS wrote:SO, with the door panel off if you pull on the rod it opens the door easily?? but with the handle the rod just doesnt have enough travel?? if so I would say something is out of adjustement I.E. a bent bar or one that is not bent enough. or maybe the latch needs to be lubed have you tried lubing the latching mechanism I would try that first then if it doesnt work then try looking into other issues
Latch moves like butter from the inside and the handle doesn't get bound or anything it just runs out of travel before the latch opens. gonna tweak the rod a lil straighter. I think that should solve that.
Tiny
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 13
Postby 1992RS » April 2nd 2010, 4:49am
so wouldnt you need to bend the bar a lil more to increase the travel caused by the handle moving?
1992 Astro RS
174,000 miles
Rebuilt top end
stock tranny
1992RS
Topics: 38
Alias (AKA): tony
Postby Bread Van » April 8th 2010, 10:36pm
Do you have power locks. My power lock failed in the "locked" position, causing a similar problem. On the rear door ,the lock mechanism isn't real obvious. I had to stare at it a number of times before I saw the little piece that I could manually flip. I'm talking about the lower dutch door, barn doors may be different.
Bread Van
Years of Membership: Bread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full yearsBread Van has been a member for 10 full years
Topics: 36
Alias (AKA): mapper
Extra Info: AWD 2 inch lift
Postby zerotool » August 17th 2018, 4:00am
pulling the handle to the full travel and the door latch still will not click open is caused by a failed circlip and or bent linkage rod. So , you need a document clip in the gallery photos. You need a 3/4" size.Squeeze the handles on the clip and fit it around the rod. I used long pliers or long surgery tongs. That will take up the slack that causes the long travel when trying to open the door. the fix stays fixed. you also might need to straighten the bent rod. See my other post. Old post , new fix, for continuing problem........ :ty: :ty:
3/4" office supply clip
zerotool
Years of Membership: zerotool has been a member for 6 full yearszerotool has been a member for 6 full yearszerotool has been a member for 6 full yearszerotool has been a member for 6 full yearszerotool has been a member for 6 full yearszerotool has been a member for 6 full years
Topics: 25
Images: 12
Alias (AKA): DFW
Extra Info: 184000mi RWD cargo
Postby Leeann_93 » August 17th 2018, 9:53pm
And this thread is over 8 years old.
ONE post is sufficient. You don't need to spam every thread you find.
Fixing drivers door handle inside latch rods linkage
Postby zerotool » October 12th 2019, 1:13am
when the door clicks open only after the handle travels to the last 1/32" , then you need a 1/2" document clip and likely a zip plastic wire tie to bind the 2 linkage rods together to secure the latch rod into the nylon hole, to stop the popping out problem. Photo shows the document clip clipped onto the latch rod and the 2 parallel rods are held together by a zip tie (left rod behind webbing and right rod next to spring and not too tight). You can avoid buying and installing a new door handle. i cut out a larger hole with a Dremel Rotary tool to make servicing the linkages easy. When it gets hard to open the door, some people pull too hard on the door handle and bhttps://www.astrosafari.com/posting.ph ... p=1528650# :ty: break it.
Document clip on door latch rod
zerotool
Topics: 25
Images: 12
Alias (AKA): DFW
Postby AstroWill » October 12th 2019, 8:52pm
That poor door.
Images: 452
Postby sixsix » October 14th 2019, 8:01pm
X2
Was someone holding a gun on you ... kept you from Removing The Inner Door Panel ?
Very interesting fix - when all you have are office supplies and a SAWZALL...
Maybe go with a new Latch Mechanism. Do they still make it?
Here's where I pulled our Driver's side Door apart, including Motor, Lock and Latch w/ all the Rods n' crap.
I pulled the Latch for fun, wondering how it worked. Everyone else was sluggish, slowing or stopped altogether.
https://www.astrosafari.com/viewtopic.p ... 4#p1479004
Mike
Well, after all... what would Banacek say ?... Anyone that condones the actions of the American People during the Storming of the Capitol are as complicit as the Assholes themselves.
But no way does this let the Democrats or the MSM off the Hook.
Firing on 5 Cylinders (L5)
Topics: 38
Images: 1316
Return to Exterior
It is currently January 16th 2021, 10:21am
Exterior Forum
rorgeastro
in Exterior
Date: Jan 05 '21
Time: 3:32am
rorgeastro
in Exterior
Date: Jan 04 '21
Time: 3:37am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 7:41am
Diablo_deth
in Exterior
Date: Jan 02 '21
Time: 12:20am
sumtingbig
in Exterior
Date: Dec 25 '20
Time: 10:03pm
