by crowdsurferx [OP] » January 9th 2015, 4:23am
by chevymaher
» January 9th 2015, 4:39am
by crowdsurferx [OP] » January 10th 2015, 2:19am
by 1998kingbong » January 10th 2015, 2:25am
by chevymaher
» January 10th 2015, 2:30am
crowdsurferx wrote:Are you sure about that?
http://www.chevroletonlineparts.com/?p=catalog&mode=search&search_in=all&search_str=door%20shell
It cost around $1000 plus shipping, very very pricey
by crowdsurferx [OP] » January 10th 2015, 2:40am
1998kingbong wrote:worth a try, see if someone on craigslist will trade with you. Same year and color, you do the work... I would have done it. I hate not having that window.
by dawayne cotton » January 18th 2015, 5:08am
by Meterpig » January 18th 2015, 7:24am
by Sailing_Faith » January 18th 2015, 9:00am
by sadglad » January 18th 2015, 9:13am
by Roger Ramjet » January 18th 2015, 5:19pm
by icebrrg3rd » January 19th 2015, 9:25pm
by Roger Ramjet » January 19th 2015, 10:40pm
icebrrg3rd wrote:Sadglad, thanks for those very informative pics! I'm glad when I replaced my slider, I lucked out and got a matching one latch-wise. I'm tucking that info & those pics away for future reference.
-Andrew
by crowdsurferx [OP] » February 10th 2015, 2:48am
dawayne cotton wrote:hello crowdsurferx,
I live in southern Il, if your interested I have one you could have off of a 1994 cargo used the drivetrain, going to scrap the rest.
DaWayne Cotton
Meterpig wrote:You know...if you are at all handy...Rivets and sheet steel should work just fine...right? Maybe even figure out something so that you can revert to the old way on sale?
Sailing_Faith wrote:Having driven without a clear view out that starboard quarter, I would NEVER do without that window! There are simply too many times you need to merge at an angle where no mirror will let you see traffic.
In my truck with a camper without windows I used to have to make a series of turns just to avoid a couple such intersections!
Roger Ramjet wrote:Before driving or calling a bunch of wrecking yards , check out car-part.com it will search practically all wrecking yards in North America ..
for example http://www.car-part.com fill out the parts search
sadglad wrote:There are two types of sliding doors. maximus7001 says here https://www.astrosafari.com/viewtopic.php?f=11&t=53466#p463081 that the change happened mid year 1997. The main difference is the location of the latch. Also, the earlier version had the bracket welded to the door. The later version is a bolt on. I bought a 1997 junkyard door for my 2002 and realized after that it is not a bolt on swap. I'm not saying it can't be done, just that it's not straightforward. I have not gotten around to it. My idea is to somehow transplant an old style latch post onto my newer van with some kind of baking plate to hold the post solid. Lucky I got mine on half price day at the pick and pull.
Somewhere in this site is information about the remove and replace procedure for the welded bracket version. Standard procedure was to drill out the welds and bolt on the new door with a backing plate from a dealer. Likely that plate is no longer available.
I also seem to remember there is some difference in the upper bracket but I can't remember details.
Reference here viewtopic.php?f=11&t=15040
and here viewtopic.php?f=11&t=53466
My cargo van came from the factory with no window on the slider door. The van went to a upfitter (Adrian Steel) who installed a bulkhead and window. They cut a hole in the door and installed a window. Quite a hack job too. It is smaller than the factory window. Looks kind of lame.
It is currently January 23rd 2021, 2:04am
Exterior Forum |
Previous topic Next topic |
Sponsors |
Users browsing this forum: Google Adsense [Bot] and 15 guests
