Sliding door lock actuator
Postby dnwong [OP] » January 10th 2015, 7:56pm
My sliding has a problem completely unlocking when the whether get cold. If fact it moves the lock mechanism 85% of the way and then I have to reach in from the passenger front opening to manually complete the door open.
Is that indicative of a weak solinoid? Works fine when weather is warmer.
What is part number for that actuator? Is it the same as the ones used in the front doors?
1995 Chev Astro Conversion.
dnwong
Years of Membership: dnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full yearsdnwong has been a member for 11 full years
Topics: 30
  • Sliding Door
    by rlhogg » October 11th 2020, 1:37am in Exterior
    October 14th 2020, 12:01pm
  • different bracket on sliding door middle rollers
    by vangogo » November 4th 2020, 4:32am in Exterior
    Last post by vangogo View the latest post
    November 12th 2020, 12:36am
    February 28th 2021, 1:55pm
Re: Sliding door lock actuator
Postby dionysis » January 10th 2015, 8:05pm
I agree that the cold does have an effect and slows the solenoid as well as the rest of the lock mechanism is it has not been lubricated. Had the same issue with another vehicle. Lubed everything and was back in business. I did end up replacing the solenoid anyway since the panel was off. Part would be approx 40 dollars for an aftermarket parts store for a parts store brand.
Let us know if it works.
"Do or do not, there is no Try" - Yoda
dionysis
Years of Membership: dionysis has been a member for 6 full yearsdionysis has been a member for 6 full yearsdionysis has been a member for 6 full yearsdionysis has been a member for 6 full yearsdionysis has been a member for 6 full yearsdionysis has been a member for 6 full years
Images: 10
Postby dnwong [OP] » January 10th 2015, 9:09pm
I tried to lube everything earlier in the season hoping to have fixed the problem. But still getting stuck. Either I missed the crucial part or I need a new solenoild.
dnwong
Topics: 30
Postby Big_kid » January 10th 2015, 10:00pm
Make sure the contacts are clean and bright too.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 342
Extra Info: 2WD 5.7 V8
Postby smokinjoe » January 11th 2015, 3:25am
I have always had this same problem. Would a laps have the solenoid? Are they symetrical in all doors? Maybe rockauto would have it cheaper?
Oh, is this the part that should fix it? http://www.ebay.com/itm/New-Door-Lock-A ... 4342wt_940
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
Postby RECox286 » January 11th 2015, 6:00am
I don't know the reason they call it a "solenoid" because it isn't. It is actually a reversable dc motor (check out
the picture and you will see a metalic cover on the middle right side. That is the where the motor parts are
located. Any way, believe it or not, you can take the assembly apart enough to clean out the goo and dirt
that accumulates over the years inside the case. Just be careful taking the case apart, it's plastic. If you
break it, you were going to replace it anyway...I guess.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby smokinjoe » January 11th 2015, 4:54pm
So unkie Bob, I recently had the sliding door panel off (some of it anyway). Where is this offending plastic motor located. I had to remove the window mount to dig in there. Does that sound right?
Is the fleabay link I put up there correct if I trash something?
smokinjoe
Topics: 268
Extra Info: RWD
Postby RECox286 » January 11th 2015, 7:50pm
THE actuator will be at the end of the rod connected to the (lever) red/black plastic door lock used
to manually lock/unlock the sliding door latch.
I do believe that all the motor/actuators are alike.
You will have to remove the lower door trim panel for access.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby smokinjoe » January 12th 2015, 3:35am
So once I am in at it what is the crud to clean out? Inside the unit itself?
smokinjoe
Topics: 268
Extra Info: RWD
Postby RECox286 » January 12th 2015, 4:35am
Any dirt that you find, the caked grease from factory installation, clean out and lubricate
the motor bearings, lubricate the actuator mechanism. Put it back together and reinstall
with a nut and bolt. I usually spray the innerds and motor (as well as I can) with either
starting fluid, brake clean, or electronics cleaner, depending on what is on the shelf to hand.
After the soaking, a sho..........t of shop air for good measure.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby Meterpig » January 12th 2015, 7:05am
Thanks for posting up about your lock issue. Mine manifested this issue over the weekend. I couldn't get the door open for anything so ended up removing the right front seat to enter and exit the rear. The kids thought that was funny....but it's sort of odd. Actually, I kind of like it...but you know...the seat has to go back in soon. I will go ahead and rebuild the motor shortly.
Meterpig
Years of Membership: Meterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full yearsMeterpig has been a member for 6 full years
Topics: 63
Alias (AKA): meterpig
Extra Info: Not a minivan
Postby RECox286 » January 13th 2015, 12:09am
Don't be intimidated by the darned thing, just take your time and you will be
fine. Hardest part, really, is getting to it, so it's not in the door, but in yer hand.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Return to Exterior
It is currently February 28th 2021, 1:55pm
Exterior Forum
in Exterior
Date: Today
Time: 4:18am
AstroOafAdventurerAstroOafAdventurer is online!
in Exterior
Time: 8:28pm
in Exterior
Date: Feb 24 '21
Time: 7:48pm
SheldonYoung
in Exterior
Date: Feb 24 '21
Time: 12:23am
Attached by: Allergictostabwounds
in Exterior
Date: Feb 16 '21
Time: 10:10pm
