Driver side door handle wobbling/loose
Postby miniVan [OP] » January 28th 2015, 5:52pm
Hi everyone,
Recently I noticed that the outside driver's door handle started wobbling, meaning that even if I were to use the slightest force to tug or push on the door handle, it would flop around back and forth about half way, before I need to pull harder to open the door (Before there was full tension when I would grab the handle to open the door, now it feels like there is only a small zone of tension in the handle at the outer most limit of pulling the door handle). The outside driver's door handle is not tightly flush against the body of the van anymore like the other door handles are, and the handle on it's own flops back and forth as if it is loose. I'm not sure what is going on here, it looks like the handle is screwed on properly and I think it might be a mechanical thing inside. The door locks and unlocks fine, but I am concerned if one day I won't be able to open the door from outside. Has anyone else experienced something like this?
Thanks.
97 GMC Safari.
miniVan
Years of Membership: miniVan has been a member for 11 full yearsminiVan has been a member for 11 full yearsminiVan has been a member for 11 full yearsminiVan has been a member for 11 full yearsminiVan has been a member for 11 full yearsminiVan has been a member for 11 full yearsminiVan has been a member for 11 full yearsminiVan has been a member for 11 full yearsminiVan has been a member for 11 full yearsminiVan has been a member for 11 full yearsminiVan has been a member for 11 full years
Topics: 47
  • Dutch door handle part number?
    by Coyotecamper » September 7th 2020, 4:53am in Exterior
    Last post by Coyotecamper View the latest post
    September 7th 2020, 8:15pm
  • 2000 Astro Exterior Door Handle Assembly etc
    by ASTROMATT0630 » February 24th 2021, 4:06pm in Exterior
    Last post by ASTROMATT0630 View the latest post
    March 1st 2021, 1:11pm
    14
    March 4th 2021, 11:22am
Re: Driver side door handle wobbling/loose
Postby RECox286 » January 28th 2015, 7:19pm
There are two studs and washer-nuts (10mm socket) that hold the handle tight.
to the door skin. It's not uncommon for them to loosen up and exhibit the signs
you describe. If you remove the round plastic cover just below the latch, you will
be able to see the nut that needs to be tightened. Unfortunately, the factory puts
in the handle first, then the latch, which means if you have to get to the top hold down
nut, either the latch needs to be removed, OR you will have to drill an inspection hole
above the latch and tighten the bugger with a swivel socket and extension (1/4" socket
set b/c there won't be too much room to manuver). After you are done, you can find a
plastic cover plug like they use at the factory. This is what some of the guys are doing
when it is handle replacement time, rather than take the inside door panel off the door.
Good hunting.
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby jaywoo65 » January 28th 2015, 7:38pm
You'll need something like this to get to the top bolt, and even then it's not terribly easy.
1999 AWD Astro - under construction
"She may not look like much kid but she's got it where it counts"
jaywoo65
Years of Membership: jaywoo65 has been a member for 6 full yearsjaywoo65 has been a member for 6 full yearsjaywoo65 has been a member for 6 full yearsjaywoo65 has been a member for 6 full yearsjaywoo65 has been a member for 6 full yearsjaywoo65 has been a member for 6 full years
Topics: 12
Extra Info: AWD baby
Postby The Drummer » January 28th 2015, 8:12pm
Is it easely accessible with the inside door panel removed? mine does the same thing and i will have to remove the trim anyway .
''USE THE TORQUE LUKE ''
and beware of trees ,them nasty wooden things are evil .
The Drummer
Years of Membership: The Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full yearsThe Drummer has been a member for 9 full years
Topics: 16
Images: 42
Extra Info: SLT 4.3 AWD
Postby RECox286 » January 28th 2015, 11:36pm
If you make the hole in the right spot, and use a one quater inch socket set with a short swivel 10mm and a long
extension, you won't have any trouble at all. There is no way to get a straight socket on the nut and expect it to
turn. The trick is to totally miss the latch making the hole. BTW: drilling is a lot easier than trying to work in the
area you get access to by removing the door panel trim. The hole in the picture should have been closer to the
outside of the door, and a bit higher for optimum access and to accept the new rubber plug w/o interference.
Try it, you'll like it !
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Postby jaywoo65 » January 28th 2015, 11:38pm
The hole actually should have been a little lower. The camera is looking down into the hole towards the nut. Another 3/4" towards the outside of the door would have been good.
jaywoo65
Topics: 12
Postby Astrofarian » January 29th 2015, 12:07am
The spring on the handle has either broken or come unhooked. That'll make your handle wobbly/loose.
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Return to Exterior
It is currently March 4th 2021, 11:22am
Exterior Forum
Olivier02
in Exterior
Date: Mar 02 '21
Time: 2:48am
in Exterior
Date: Feb 28 '21
Time: 4:18am
AstroOafAdventurer
in Exterior
Date: Feb 27 '21
Time: 8:28pm
in Exterior
Date: Feb 24 '21
Time: 7:48pm
SheldonYoung
in Exterior
Date: Feb 24 '21
Time: 12:23am
