Automatic window to manual window crank
Postby alex81492 [OP] » July 3rd 2010, 3:51am
Ok so the passenger side window doesn't roll down at all and the drivers side rolls down slowly and sometimes i cant get it to go back to the top for day. I know its those motors it has in the windows but I don't have much money so i want to put manual window cranks in both of them. Is this possible or not ill probably go to the junk yard and look for an old astro that has window cranks and take the system. My van is a 1995 astro will i be able to put the window crank system from older first generation astros?
alex81492
Years of Membership: alex81492 has been a member for 10 full yearsalex81492 has been a member for 10 full yearsalex81492 has been a member for 10 full yearsalex81492 has been a member for 10 full yearsalex81492 has been a member for 10 full yearsalex81492 has been a member for 10 full yearsalex81492 has been a member for 10 full yearsalex81492 has been a member for 10 full yearsalex81492 has been a member for 10 full yearsalex81492 has been a member for 10 full years
Extra Info: v6 RWD
  • Manual Mirror to Replace a Power Mirror?
    by GodIsBed » October 7th 2020, 1:10am in Exterior
    Last post by GodIsBed View the latest post
    October 24th 2020, 5:01am
  • Window track rebuild
    by smokinjoe » June 18th 2020, 5:17am in Exterior
    Last post by smokinjoe View the latest post
    June 27th 2020, 5:25am
    December 4th 2020, 8:21am
Re: Automatic window to manual window crank
Postby astroturf » July 3rd 2010, 4:09am
alex81492 wrote:Ok so the passenger side window doesn't roll down at all and the drivers side rolls down slowly and sometimes i cant get it to go back to the top for day. I know its those motors it has in the windows but I don't have much money so i want to put manual window cranks in both of them. Is this possible or not ill probably go to the junk yard and look for an old astro that has window cranks and take the system. My van is a 1995 astro will i be able to put the window crank system from older first generation astros?
I doubt you'll be able to use anything besides the 95 stuff. It was a transition year for the vans. I could be wrong though.
Have you inspected the wiring found in the door jam area yet? That is generally where it breaks.
Keep us posted and good luck. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby alex81492 [OP] » July 3rd 2010, 4:15am
so you think its possible to take the window motor out and make it a manual crank?
alex81492
Extra Info: v6 RWD
Postby astroturf » July 3rd 2010, 4:34am
I would think that that would be possible. They built them both ways on the Assembly Line.
I would like for you to look at the wire harness between the door and the body first. It won't take long and could be a lot easier fix that the manual crank swap.
Others may chime in who have done it before though so stay tuned.
Jim
astroturf
Topics: 112
Postby alex81492 [OP] » July 3rd 2010, 4:46am
Jim
what is it that i got to look for in the wire harness im not realy smart with cars im only 17
alex81492
Extra Info: v6 RWD
Postby webcat » July 3rd 2010, 4:53am
:rofl:
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby webcat » July 3rd 2010, 4:57am
Sorry , i about died laughing .
If we were smart we would'nt be working on cars.
webcat
Topics: 253
Postby LEVE » July 3rd 2010, 4:58am
Well, it's time to become that way. Being 17 ain't an excuse for ignorance, it's a great time to learn. The fact that you're willing to ask proves that.
You're looking for a break in the wiring harness that goes from the door to the main harness under the dash, or a bad ground.
Do you have a manual on the van?
LEVE
Years of Membership: LEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full yearsLEVE has been a member for 10 full years
Topics: 18
Extra Info: AWD 4.3L-W
Postby astroturf » July 3rd 2010, 4:58am
Start here: viewtopic.php?f=76&t=7048&start=0&hilit=broken+wire#p63527
And read this one too: viewtopic.php?f=76&t=4172&start=0&hilit=broken+wire#p28259 It has pix of what you may be up against.
Hope this helps, Jim
astroturf
Topics: 112
Postby astro355 » July 3rd 2010, 7:03am
The manual window regulators will work. Changing them over will be pretty self-explanatory. The regulator assembly is held in place with rivets that have to be drilled out. You will have some 10 mm bolts that need to be removed so you can slide the regulator guides out of the window track.
Photo courtesy of astrojoe lt1
The regulator for the window is the black "x" in the middle of the picture.
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby chevy57bert » July 3rd 2010, 10:11am
webcat wrote:Sorry , i about died laughing .
:rofl: :rofl: :rofl: We would drive it......... :mrgreen:
Follow Jim (astroturf) leads Alex..
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
chevy57bert
Section Moderator
Section Moderator
Firing on 7 Cylinders (L3)
Years of Membership: chevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full yearschevy57bert has been a member for 11 full years
Topics: 69
Images: 68
Alias (AKA): Bertjuh
Extra Info: Ext 4.3L rwd
Postby astroturf » July 3rd 2010, 1:08pm
I like the matching hats...
astroturf
Topics: 112
Return to Exterior
It is currently December 4th 2020, 8:21am
Exterior Forum
Tanino
in Exterior
Date: Nov 29 '20
Time: 11:30am
kevinfin
in Exterior
Date: Nov 24 '20
Time: 10:20pm
foxfire
in Exterior
Comments: 43
Date: Nov 23 '20
Time: 9:30pm
in Exterior
Comments: 43
Date: Nov 18 '20
Time: 9:04pm
foxfire
in Exterior
Comments: 43
Date: Nov 15 '20
Time: 2:33am
cron
