Power locks dont work
Postby Iulik [OP] » October 12th 2015, 2:42am
Hi guys, its been a while, i have a problem that i cant seem to figure out, today my power locks stopped working and i cant unlock my rear hatch, when i press the unlock button (up) on the doors and when unlocking with the key from the back i can hear a clicking noise on the relays inside, but nothing happens, and if i press the lock button (down) nothing happens also , i tried looking on the forums but i couldn't find anything, if anyone has an idea i would be grateful
Iulik
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Iulik has been a member for 6 full yearsIulik has been a member for 6 full yearsIulik has been a member for 6 full yearsIulik has been a member for 6 full yearsIulik has been a member for 6 full yearsIulik has been a member for 6 full years
Images: 11
Extra Info: Southern Comfort RWD
  • Manual Mirror to Replace a Power Mirror?
    by GodIsBed » October 7th 2020, 1:10am in Exterior
    Last post by GodIsBed View the latest post
    October 24th 2020, 5:01am
  • Power Window Motor Spins, Window Won't Move
    by BillyJoBob » January 24th 2021, 8:54pm in Exterior
    January 26th 2021, 2:17am
    March 1st 2021, 2:06am
Re: Power doors dont work
Postby AstroWill » October 12th 2015, 2:57am
"Power doors dont work"
I get a little jealous every time I see the newer vans with power sliding doors.
Iulik wrote:Hi guys, its been a while, i have a problem that i cant seem to figure out, today my power locks stopped working and i cant unlock my rear hatch, when i press the unlock button (up) on the doors and when unlocking with the key from the back i can hear a clicking noise on the relays inside, but nothing happens, and if i press the lock button (down) nothing happens also , i tried looking on the forums but i couldn't find anything, if anyone has an idea i would be grateful
Check the fuse for that circuit, it's the same circuit as your power outlets/cigarette lighter.
Images: 472
Re: Power locks dont work
Postby Iulik [OP] » October 12th 2015, 3:03am
I am sorry, changed the title ^^ i forgot to say that the cigarette lighter works, the fuse is good, and as far as i can figure out if the fuse would be bad the relays would not click when pushing the button
Iulik
Fueling (1/2 tank)
Fueling (1/2 tank)
Images: 11
Postby AstroWill » October 12th 2015, 3:15am
Then I would try pushing in on the corners of the door where the latch actually is, try doing this while pushing the open button on the door.
Yea, they are the same circuit on the Astro, was another vehicle I was thinking of, if your door locks work then it's the same fuse to open the rear hatch.
Images: 472
Postby Iulik [OP] » October 12th 2015, 3:27am
I am sorry, i might have expressed myself wrong, the power locks on the doors and on the rear hatch are on the same circuit i guess, when i try to push the unlock button on the door, i can hear the relays clicking but the doors do not unlock, or lock, and because the unlocking does not work my rear hatch also does not unlock, so i cant open it, when unlocking the hatch with the key from the back it would unlock my doors too, but now all i hear are the relays clicking and nothing happens, it has something to do with the power locking system i believe, and since i use my van for work i really really need the rear doors to open....
Iulik
Fueling (1/2 tank)
Fueling (1/2 tank)
Images: 11
Postby AstroWill » October 12th 2015, 3:45am
In that case, if pressing on the lower corners of the hatch(where the hatch latches are) while pushing the button in to open the hatch, then you might have to take the inside apart to diagnose/lube the connections. You might be able to get some lube into the actual latches from the outside, not sure how effective it would be though. This is a normal PM thing that I like to do every few oil changes, lubing the latches that is.
Images: 472
Postby Lumpy » October 12th 2015, 3:38pm
Are you doing this with engine on or off?
What's your battery voltage?
Could be a crankshaft position sensor.
Postby Coaster » October 12th 2015, 3:48pm
sounds like low voltage to me. possible battery issues, or corrosion somewhere. fusible links etc. i've had really bizarre stuff happen with fusible links going bad; passing voltage and current but not enough to run things correctly
I LIVE IN NORTH DAKOTA
Coaster
Years of Membership: Coaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full years
Topics: 114
Extra Info: 4.3 cargo 2wd
Postby Iulik [OP] » October 13th 2015, 3:57am
Doing with engine on, off , going 80mph, same thing, i can only hear the relays go click click and thats it, tried another battery, same thing, im thinking its probaby a bad cable somewhere , does the van have a relay in the rear for the hatch? because i cant hear anything from back there
Iulik
Fueling (1/2 tank)
Fueling (1/2 tank)
Images: 11
Postby sixsix » October 13th 2015, 4:21am
VERY odd that this would "start this problem right out of nowhere".
Maybe more than just coincidence ...
Mike
So only CAL, ILL & NY Elects
Firing on 6 Cylinders (L5)
Topics: 38
Images: 1320
Postby Lumpy » October 13th 2015, 5:37am
Black helicopters? NSA satellites? Google? They put chips in all the crankshaft position sensors.
Return to Exterior
It is currently March 1st 2021, 2:06am
Exterior Forum
in Exterior
Time: 4:18am
AstroOafAdventurer
in Exterior
Date: Feb 27 '21
Time: 8:28pm
in Exterior
Date: Feb 24 '21
Time: 7:48pm
SheldonYoung
in Exterior
Date: Feb 24 '21
Time: 12:23am
Attached by: Allergictostabwounds
in Exterior
Date: Feb 16 '21
Time: 10:10pm
