Broken Hood Release Cable
Postby dobaroy [OP] » December 7th 2015, 1:32am
Broken hood release cable 99 Astro . . . any ideas how we can release the hood as there is no response when we pull the hood release cable. Thanks
dobaroy
Years of Membership: dobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full yearsdobaroy has been a member for 8 full years
Topics: 12
Extra Info: 4.3 AWD
Re: Broken Hood Release Cable
Postby markmitch » December 7th 2015, 1:35am
try to get at the cable through the grill or from underneath. You may have to break or cut the grill unless someone else knows a way. but before you do that ask a body shop if they can open it , it may be cheaper then buying a new grill.
Firing on 5 Cylinders (L6)
Topics: 599
Images: 20
Extra Info: RS V8
Postby AstroWill » December 7th 2015, 1:56am
It's quite easy, get a socket(thin wall is best) and a longer extension and take out the two bolts that hold the latch. You can slide the socket between the hood and grill, use some tape or something so you don't scratch your paint/grill.
viewtopic.php?f=11&t=84257&start=20#p823658
In 2016 ~66mil voted for Clinton, ~63mil voted for Trump and ~100mil(eligible) didn't vote Make a difference - register+vote!
Topics: 106
Images: 438
Postby astroman97 » December 7th 2015, 2:19am
AstroWill wrote:It's quite easy, get a socket(thin wall is best) and a longer extension and take out the two bolts that hold the latch. You can slide the socket between the hood and grill, use some tape or something so you don't scratch your paint/grill.
Good tip (inert thumbs up smiley)
astroman97
Years of Membership: astroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full yearsastroman97 has been a member for 9 full years
Topics: 78
Images: 2
Extra Info: Also 97 both 2wd
Postby dobaroy [OP] » December 7th 2015, 2:45pm
Thanks for the replies, we are going to try the unbolting trick.
dobaroy
Topics: 12
Extra Info: 4.3 AWD
Postby RECox286 » December 8th 2015, 10:09pm
Look at the opening (slot between the hood and lower structure) to make sure that a socket will fit.
On some trucks you can't get a socket in there, and in that case you may try, like I had to, a long 12
point offset (combination) wrench to get to the lower bolts that hold the latch to the lower structure.
Good hunting
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby dobaroy [OP] » December 9th 2015, 1:05am
Thanks Uncle Bob, we haven't been able to get at it today.
dobaroy
Topics: 12
Extra Info: 4.3 AWD
Return to Exterior
It is currently October 1st 2020, 4:34am
Exterior Forum
in Exterior
Date: Today
Time: 2:05am
Rockridge
in Exterior
Date: Today
Time: 1:26am
Tanino
in Exterior
Time: 1:34am
Attached by: Birdshake
Birdshake
in Exterior
Date: Sep 28 '20
Time: 11:40pm
doogaloo
in Exterior
Date: Sep 28 '20
Time: 12:19pm
