by b00duh [OP] » February 24th 2016, 6:04pm
by CopperFiremist
» February 24th 2016, 6:44pm
by b00duh [OP] » February 24th 2016, 6:47pm
by CopperFiremist
» February 24th 2016, 7:03pm
by chevymaher » February 24th 2016, 7:27pm
b00duh wrote:I was thinking of going that route as well, but I was worried about the awd rear end mating with the rwd drivetrain. From what I've read, I would need to swap those as well since I was thinking of putting an lsd in the rear.
by markmitch » February 24th 2016, 7:34pm
by b00duh [OP] » February 25th 2016, 4:24pm
by 97cargocrawler » February 25th 2016, 5:20pm
by Astrofarian » February 25th 2016, 6:41pm
by markmitch » February 25th 2016, 7:28pm
by b00duh [OP] » February 25th 2016, 7:41pm
97cargocrawler wrote:Why swap sub-frames? Swapping bodies sounds easier and more fun.
Astrofarian wrote:LSD? Even here in Manitoba, that stuff's illegal no matter WHERE you're sitting. I checked (30 years ago, mind you lol)
Gen 1 vans are pretty cheap....is it worthwhile to do what you're thinking of? The van, NOT the LSD!!
-Mike-
by markmitch » February 25th 2016, 10:00pm
by b00duh [OP] » February 25th 2016, 10:47pm
markmitch wrote:actually you will most likely need to swap the pcm and possibly the wring harness too, depending on the years cause the AWD is computer controlled isn't it?
by kennysmoke » February 26th 2016, 12:51am
b00duh wrote:97cargocrawler wrote:Why swap sub-frames? Swapping bodies sounds easier and more fun.
That's what I was thinking with this project. Disconnect anything connected to the body of the van, lift it off with my work forklift, then swap frames with the drivetrain all connected. Button it all back up and hope for the best. Lol.Astrofarian wrote:LSD? Even here in Manitoba, that stuff's illegal no matter WHERE you're sitting. I checked (30 years ago, mind you lol)
-Mike-
I agree, they are cheap but a lot of them I've seen are rusted out. Is it worth it financially? Nope, just like any other vehicle project I've owned it just isn't. Cars are the worst things to sink money into. Lol. But is it enjoyable to do? Absolutely.
I figure, the awd is already toast so to replace or rebuild that is already a couple hundred to a couple thousand. But, with the body in decent shape I can do the body work and swap out the rusted out body on the rwd and call it a day. Sure, I lose the awd but a limited slip in the rear end will somewhat make up for it. Plus, I don't have to worry about the torsion bars in the front, which for some reason freaks me out that they will snap at some point while I'm driving. Lol.
by b00duh [OP] » March 21st 2016, 3:55pm
by Lumpy » March 21st 2016, 4:13pm
b00duh wrote:
... or am I having to deal with the headache of having to change things...
by b00duh [OP] » March 21st 2016, 4:59pm
by redfury » March 21st 2016, 5:01pm
by b00duh [OP] » March 21st 2016, 5:05pm
redfury wrote:You might have to swap the link from the steering column to the gearbox, but it does have some play in it...you may not have to worry about it. It's going to have to be disconnected from both vans anyway though, so I'd just take them both off and measure each...use the one that makes the most sense. Don't forget to mark the location so you don't have a crooked steering wheel.
It is currently March 1st 2021, 7:10am
Exterior Forum |
Previous topic Next topic |
Sponsors |
