rear of sliding door is locked and prevent the door closing
Postby tinworm [OP] » November 4th 2010, 2:45am
have an issue on a 1994 astro van. The van is something I just bought, so I am trying to get it to a position where it can be moved, but currently the sliding door does not close at all. The door latch on the rear part of the door is closed in the lock position, and nothing seems to get it undone.
Is there a way or trick to pry this latch open so I can close the door? what could be broken to have it jammed in this position?
tinworm
Years of Membership: tinworm has been a member for 10 full yearstinworm has been a member for 10 full yearstinworm has been a member for 10 full yearstinworm has been a member for 10 full yearstinworm has been a member for 10 full yearstinworm has been a member for 10 full yearstinworm has been a member for 10 full yearstinworm has been a member for 10 full yearstinworm has been a member for 10 full yearstinworm has been a member for 10 full years
Topics: 65
  • Sliding Door Parts
    by junkylogic » August 4th 2020, 11:02pm in Exterior
    Last post by gavio View the latest post
    August 5th 2020, 2:37pm
  • sliding door wont open
    by DaHonu » August 10th 2020, 6:05pm in Exterior
    Last post by DaHonu View the latest post
    August 11th 2020, 9:28pm
    7
    12
    December 1st 2020, 3:24pm
Re: rear of sliding door is locked and prevent the door clos
Postby 'cudapaul » November 4th 2010, 4:18am
Real simple, if it is as you describe.
Put a round rod or other object (think screwdriver) into the hole in the door latch where the latch finger goes into the assembly. While holding the door, have some one pull on the exterior handle, like they were opening the door (make sure that the door is unlocked). At the same time, pull the round rod, while still in the latch hole, towards the inside of the van. That should open the latch assembly so that when the door is closed it can latch on the striker.
The problem is that the latch mechanism gets dirty and the finger somehows gets closed as the door is being opened. When you go to close the door, since the finger is already closed, the latch won't accept the strike pin. You just need to reopen the latch mechanism.
'cudapaul
Years of Membership: 'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years'cudapaul has been a member for 12 full years
Alias (AKA): 'cudapaul
Extra Info: LT AWD
Postby RECox286 » November 4th 2010, 4:28am
If the handle won't unlock the latch, then either the rod from the handle to the latch has come undone, or the handle or latch is broken. That would seem to be the only ailments that would cause the latch to not work.
The only way to find out is to dissassemble the interior trim of the door. It's not all that difficult, but take your time, because you do not want to break any of the attaching pieces. New push fasteners and other various pieces of hardware are available in the HELP section at most auto parts stores, especially the larger discount chains like Pep Boys, Advance, Auto Zone, Napa, etc.
If you don't have a small selection of body trim removal tools, it would probably be a good idea to treat yourself and get a few at this time. You will have a use for such tools in the future if you plan on keeping your truck for the long haul.
Good luck
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby tinworm [OP] » November 4th 2010, 2:15pm
thanks for the replies, I am going to try and figure it out on friday or so and will post back
tinworm
Topics: 65
Postby toddb » November 4th 2010, 6:46pm
Umm, I think he means that the door is locked open. If that is your problem there is a catch on the bottom back, usually you can push it in with your finger - you might have to push the door more open as it binds if there is any forward pressure on it at all. I hope that makes sense.
1997 Safari 2WD 3:73 locking. 300,000 km - almost full load.
2000 Safari AWD 3:73 locking. 275,000 km - Full load.
toddb
Years of Membership: toddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full yearstoddb has been a member for 12 full years
Postby tex star detail » December 2nd 2010, 3:54am
And was the problem solved?????????????????????????????
2000 GMC Safari Cargo
1999 Chevy Astro Cargo- SOLD Also
1995 GMC Safari Cargo- SOLD!
tex star detail
Years of Membership: tex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full yearstex star detail has been a member for 12 full years
Topics: 70
Extra Info: RWD Cargo
Return to Exterior
It is currently December 1st 2020, 3:24pm
Exterior Forum
Tanino
in Exterior
Date: Nov 29 '20
Time: 11:30am
kevinfin
in Exterior
Date: Nov 24 '20
Time: 10:20pm
foxfire
in Exterior
Comments: 43
Date: Nov 23 '20
Time: 9:30pm
in Exterior
Comments: 43
Date: Nov 18 '20
Time: 9:04pm
foxfire
in Exterior
Comments: 43
Date: Nov 15 '20
Time: 2:33am
Users browsing this forum: Yandex [Bot] and 6 guests
