Yet another headlight conversion
Postby andrew678122 [OP] » March 26th 2016, 1:56am
Hey there,
I have a 2005 Astro cargo van with the sealed beams I have decided to do the conversion to composite headlights. In fact I have it all done... I think. But I have a few questions:
1. I wired the composites to the existing 9003 H4 connectors, but I was expecting both high and low beams to be on when selecting high beam. I don't get that, is something wrong?
2. Can I wire it up so both are on when High beam is selected? High and low beam have different bulbs so I don't see where it would cause any problems... though my electric bill is gonna go sky-high...
Thanks...
678122
andrew678122
Years of Membership: andrew678122 has been a member for 7 full yearsandrew678122 has been a member for 7 full yearsandrew678122 has been a member for 7 full yearsandrew678122 has been a member for 7 full yearsandrew678122 has been a member for 7 full yearsandrew678122 has been a member for 7 full yearsandrew678122 has been a member for 7 full years
Topics: 28
Images: 16
Alias (AKA): 678122
Extra Info: cargo van AWD
  • Another door handle question.
    by sonnystile13 » May 23rd 2021, 2:12pm in Exterior
    Last post by Devonian View the latest post
    May 24th 2021, 1:04pm
  • Astro conversion windows
    by Raydirt89 » May 25th 2021, 9:21pm in Exterior
    Last post by icebrrg3rd View the latest post
    May 26th 2021, 8:39pm
    62
    August 5th 2021, 2:21am
Re: Yet another headlight conversion
Postby astroracer » March 26th 2016, 2:17am
The High and low beams are separate, even in the sealed beam bulbs. The low beams go off when the high beams are on. What you want to do requires a relay to be wired between the two circuits. It's called a "high 4" kit and is available most anywhere. Just Google "high 4 relay kit" and yo will see what I am talking about.
Mark
1994 Astro with an LT1 350 (Ron Burgundy)
2004 Astro
2000 Monte Carlo SS
1994 Formula V8 Firebird
1956 Chevy Station Wagon
astroracer
Firing on 7 Cylinders (L1)
Years of Membership: astroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full yearsastroracer has been a member for 11 full years
Topics: 13
Images: 2
Alias (AKA): astroracer
Van Model Year: 1988
Extra Info: Major renovation
Postby Coaster » March 26th 2016, 2:33am
are the composites really any better than the sealed headlites?
I LIVE IN NORTH DAKOTA
Coaster
Years of Membership: Coaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full yearsCoaster has been a member for 8 full years
Topics: 114
Extra Info: 4.3 cargo 2wd
Postby Davo2530 » March 26th 2016, 2:40am
I Am trying to remember back to when I did this similar conversion on my 97 s10 but I don't think that the hi and low beams are both one normally in a single light when the high beams are activated. I had to install some one way current flow resistors to have all my lights on at once but I had also converted to HID lights both high and low beam. Take a volt meter or test light and see if you have current in both sides of the 9003 connector.
Davo2530
Years of Membership: Davo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full yearsDavo2530 has been a member for 5 full years
Topics: 20
Alias (AKA): Dave
Van Model Year: 2002
Extra Info: 186kmiles
Postby Davo2530 » March 26th 2016, 2:44am
astroracer wrote:The High and low beams are separate, even in the sealed beam bulbs. The low beams go off when the high beams are on. What you want to do requires a relay to be wired between the two circuits. It's called a "high 4" kit and is available most anywhere. Just Google "high 4 relay kit" and yo will see what I am talking about.
Mark
Yup there it is and it was between the relays that I had to put the resistors to keep the high current from passing back into the headlight switch because of the high current required by the HIDs.
Davo2530
Topics: 20
Alias (AKA): Dave
Postby andrew678122 [OP] » March 26th 2016, 2:48am
Coaster wrote:are the composites really any better than the sealed headlites?
I have always complained about the sealed beams on my 2005 cargo van, there just isn't enough light. That said, I'm not sure the composites are any better, but at least I can change the bulbs if I want more light. There's not too much that can be done with the sealed beams. I upgraded the sealed beams to halogens for a marked improvement, but you can only go so far...
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby andrew678122 [OP] » March 26th 2016, 2:52am
Mark
Yup I found those kits, that's what I want to do. But I've been thinking about it and I believe I can add a diode to my after-market relay kit which will do what I want.
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby Davo2530 » March 26th 2016, 3:01am
I have true white HIDs in all my vehicles and have never been disappointed, they are very illuminating and I hardly ever need high beams. Very easy to install and no maintenance necessary.
Davo2530
Topics: 20
Alias (AKA): Dave
Postby Coaster » March 26th 2016, 3:10am
i've had the composites on other vehicles (not astro) and have found the sealed beams in the astro to be a lot better in my experience. i've never driven an astro with the composites though so i really dont know
Coaster
Topics: 114
Postby markmitch » March 26th 2016, 3:35am
I understand as we age our sensitivity to light changes but when I am driving at night and some one has there high beams on and does not click it to low I wish I had a 50 cal machine gun in my grill. That just pisses me right off. But I just switch mine back to high and keep driving. So please remember you have high beams on and be courteous to others.
Firing on 1 Cylinder (L7)
Topics: 642
Images: 21
Extra Info: RS V8 AWD
Postby andrew678122 [OP] » March 26th 2016, 5:05am
Oh man what a difference! I just got back from an hour ride, some country roads, some of which was down a gravel road, and some in the burbs. My van seems like the headlights are twice as bright, better focused, putting more of the light where it's needed. Both low and high beams are much-much better! That $85 it cost me for the grill, both headlights with bulbs, and the corner reflectors, was money well spent!
I would recommend that anyone who feels their sealed beam headlights are not that good, just go down to their pick-and-pull, get the parts, and do it!
I'll post a picture of my baby tomorrow...
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby Coaster » March 26th 2016, 5:20am
interesting. i'm not being sarcastic or anything, but did you ever aim your lites before the change?
i have the sealed beams and they are the best headlites i have had in over a decade of vehicles. that said the express with sealed beams we have at work is horrible.
Coaster
Topics: 114
Postby andrew678122 [OP] » March 26th 2016, 6:02am
Coaster wrote:interesting. i'm not being sarcastic or anything, but did you ever aim your lites before the change?
Yeah, I did the aiming, face a white wall, measure up from the ground, get the center spot correct, I tried it many times but it was never any good. I also put on one of the relay kits with its own power lead and fuse, it helped some but not enough. I'm still using that relay kit with the composite lights. The problem with sealed beams is that they are old technology, 60 or 70 or 80 years old! The only change I have seen in them was when they put the halogen bulb inside the sealed beam, everything else was pretty much the same, especially the reflector, it was designed before they had computers!
Nah I am sold on the composite headlights, I just wish I had done it years ago...
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby andrew678122 [OP] » March 26th 2016, 6:05am
markmitch wrote:I understand as we age our sensitivity to light changes but when I am driving at night and some one has there high beams on and does not click it to low I wish I had a 50 cal machine gun in my grill. That just pisses me right off. But I just switch mine back to high and keep driving. So please remember you have high beams on and be courteous to others.
Yeah, dimming your headlights is common courtesy, some people seem forget the 'courtesy' part...
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby andrew678122 [OP] » March 26th 2016, 4:26pm
Here's my baby:
I still have to de-yellow the corner reflectors and parking lights. I also painted both the grill and the bumper satin black (Krylon maxx)...
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby chevymaher » March 26th 2016, 4:54pm
andrew678122 wrote:Here's my baby:
Looking great.
Topics: 91
Postby andrew678122 [OP] » March 26th 2016, 10:36pm
Looking great.
Thanks chevymaher!
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby andrew678122 [OP] » March 28th 2016, 9:50pm
My headlight conversion is officially done. I now get all 4 headlights on in high beam (it took 1 diode from RadioShack (yes, we have a functioning RadioShack in El Paso!) and a minor wiring change on my headlight relay kit), and everything else works as the factory intended (well almost)!
678122
andrew678122
Topics: 28
Images: 16
Alias (AKA): 678122
Postby Godron629 » April 5th 2021, 4:50pm
Sorry to necro, since all the threads on this are filled with missing images - figured I'd drop some pics.
Hit a deer on a weekend, did the swap.
Simple, but remember 1) to connect your grounds 2) don't try to install the grill upside down (it won't line up...) (ask me how I know :whack:)
If you're going to the junkyard, you need:
- 10 mm socket for lights
- 7 mm socket for grill
- Phillips screwdriver for marker lights and maybe grill
- Side cutters for harnesses
Cost me $30 for the lights and $40 for the grill. Also got a hood for $80 and 2 leather safari seats for $100.
Godron629
Extra Info: Cargo 4.3L V6 RWD
Postby sixsix » April 5th 2021, 5:54pm
haha... necro thread - thought we were having candy discs... LOL
Love the "Hairy Action Shot" - and to see you got that sorted Well - Nice !!
"1 Nautilus died, BLM spawned, Antifa runs amok
- CRT & unions have taken schools by storm
THEN:
Not a single "Black" "Leader" condemns Black Crime
- White Supremacists get blamed for it all - they sure do get around"
Firing on 1 Cylinder (L6)
Years of Membership: sixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full years
Topics: 39
Images: 1411
Return to Exterior
It is currently August 5th 2021, 2:21am
Exterior Forum
joeg
in Exterior
Comments: 18
Date: Jul 29 '21
Time: 10:02pm
Olivier02
in Exterior
Date: Jul 28 '21
Time: 10:36pm
Attached by: Godron629
Godron629
in Exterior
Date: Jul 23 '21
Time: 2:16am
nwmod39
in Exterior
Date: Jul 17 '21
Time: 5:05am
Rockridge
in Exterior
Date: Jul 15 '21
Time: 11:06pm
Users browsing this forum: No registered users and 25 guests
