AWD swap for Astro-based RV?
Postby Ball [OP] » June 9th 2016, 12:24am
OK, so this idea is out of left field, but here it goes.
There is an old (87) Astro-based RV for sale semi-locally. It's stripped and needs a lot of work, but it runs and is advertised as only having 66k miles.
I happen to own a '94 AWD Astro with a blown engine. I can also pick one up locally for cheap. The one I own is in another state so it's probably easier just to buy another one. Both options have a 'W' engine.
I have replaced the tranny on my AWD which necessitated taking apart the front suspension, but of course not the sub-chassis. I have access to a monster air tool to take the sub-chassis bolts off.
Questions:
1) What AWD Astro front-ends would be compatible with the '87 rear-end? I know AWD came out in 1990, but I don't know if any modifications to the rear chassis were made.
2) Assuming these are compatible parts, how difficult would it be to marry them?
In my mind even though the RV engine only has 66k, it's probably a TBI engine (Z?) and while I DO have access to an engine lift I see no reason to swap them (maybe you have different thoughts). Basically, I see the process as unbolting the sub-chassis, lifting (tipping) both Astros back, rolling the AWD front-end under the RV, bolting it back, having the drive shaft shortened, and probably swapping the rear axle since the ratios probably won't match.
How insane is this thought experiment? I'll need to know soon as I'll have access to the shop and I've already sourced a donor van which will only set me back $500.
Ball
Years of Membership: Ball has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full yearsBall has been a member for 10 full years
Topics: 5
Extra Info: vin W
  • 1989- RS to 4x4 swap list
    by markmitch » September 12th 2020, 4:27pm in Projects/Builds
    October 15th 2020, 1:15am
  • 2004 AWD Base Astro - DCsleeper
    by dcsleeper » May 20th 2020, 12:31am in Projects/Builds
    October 7th 2020, 3:40pm
    76
    October 29th 2020, 5:41pm
Re: AWD swap for Astro-based RV?
Postby chevymaher » June 9th 2016, 2:14am
It will work bolt right up. Just the way your talking about doing it.
Get the computer out of the one the motor came from. Or switch intakes and sensors. The older computer is the better one in my opinion. Chips plug in. In case you ever want to do some tuning in the future. TBI's are much more reliable as well.
Postby Rockridge » June 9th 2016, 2:27am
These vans are great, just like when I'm working on old American bicycles, just move the parts around..... This sounds like a cool project
Rockridge
Firing on 8 Cylinders (L1)
Years of Membership: Rockridge has been a member for 4 full yearsRockridge has been a member for 4 full yearsRockridge has been a member for 4 full yearsRockridge has been a member for 4 full years
Topics: 46
Alias (AKA): Walker
Postby icebrrg3rd » June 9th 2016, 4:56pm
Just an FYI, I think in '93 the transmission became computer operated, '92 and earlier were simpler as in non-electronic, used kick-down cable. Just in case you start swapping your '94 stuff into the '87. And '87 might be a cable driven speedometer instead of electronic like '88+. I'm not definite on these dates, but they're close, something to watch out for.
-Andrew
91 Chevy Astro 5L 5-speed, Ford 9" 261k mi
02 Chrysler Sebring Conv. 2.7L 5-speed 213k mi
10 Chrysler Town & Country 3.8L 180k mi
icebrrg3rd
Firing on 5 Cylinders (L3)
Topics: 49
Alias (AKA): Andrew
Van Model Year: 1991
Postby 97cargocrawler » June 10th 2016, 9:29am
Be sure to snap a pic using that monster air tool!
97cargocrawler
Topics: 42
Alias (AKA): KING OF OVERKILL
Return to Projects/Builds
It is currently October 29th 2020, 5:41pm
Projects/Builds Forum
in Projects/Builds
Comments: 81
Date: Oct 27 '20
Time: 4:57am
in Projects/Builds
Comments: 383
Date: Oct 26 '20
Time: 9:28pm
rozmpatterson
in Projects/Builds
Date: Oct 26 '20
Time: 6:51pm
Attached by: augidog
augidog
in Projects/Builds
Comments: 211
Date: Oct 26 '20
Time: 5:26pm
Sailing_Faith
in Projects/Builds
Comments: 24
Date: Oct 25 '20
Time: 8:33pm
