No, the bull bar was not a factory option. The P.O. installed it as the guy before him rear ended someone.
It was almost a dead square hit but with rust on the core support broke them both.
I'll weld that and I have the grill, hood, bumper and cover from my '97 to swap on.
I'll use other goodies like the ladder rack and interior walls and ceiling. (1/4" ply with FRP laminate) I'll grab some other parts before I call the wreckers.
My first day wrenching on the Wench.
I'm starting with the front end and that core support. I just moved into this house and can't find a thing I need. It took me all day to get 2, 1/8" plates welded under the core support.
I haven't gotten to the "face" inverted t shape yet, just the plate that is on the bottom. I loosened the middle and jacked the body from the top of the core support. The pass side capture nut was toast so I made a new one. I had a couple new body mounts handy so those got used. I needed juice for the plasma to cut the 1/8" steel so I had to make a 220v extension cord.
I'm amazed I found those body-mounts and 220v plug in amongst the piles of unpacked boxes...
While that was going on I gave my wife some lessons on the riding mower so she could cut the lawn, moved the gutter drains, edged with the push mower and after she finished I spent a 1/2 hour cleaning what she missed.
2, 4" x 18" pieces of steel and I'm exhausted,,, getting old I guess.
While I have the grill off I'm thinking to replace the condenser, I think it has been holed. Is there a way to test other than putting in the stuff with dye? there is a leak. P.O. put in 2 cans and there is no pressure at the Schrader valve.
