Cam's AWD Astro Camper Build
Postby costman13 [OP] » August 7th 2018, 1:33am
Hey all!
I've realized that I don't have a proper build thread going here on AS.
My Van
Here is a link to the the 2+1 Lift thread -
https://www.astrosafari.com/viewtopic.php?f=40&t=132313
Here is a link to my Expedition Portal thread -
https://www.expeditionportal.com/forum/ ... ld.194098/
and here are some photos -
When I first bought it in March
Just before the lift
Just after the lift
Lift Complete!
More to come...
Cam
Cam Östman
costman13
Fueling (7/8 tank)
Fueling (7/8 tank)
Years of Membership: costman13 has been a member for 3 full yearscostman13 has been a member for 3 full yearscostman13 has been a member for 3 full years
Alias (AKA): Cam
Extra Info: LS 4x4 - np233c
  • 2000 Astro LS RWD Camper Build
    by AstroMung » March 7th 2021, 6:39pm in Projects/Builds
    March 8th 2021, 2:44pm
  • 2002 Astro AWD 4inch Lift Camper Conversion
    by Minist3r » November 28th 2020, 6:10pm in Projects/Builds
    Last post by SportsBoy View the latest post
    November 29th 2020, 4:08am
    May 16th 2021, 7:13am
Re: Cam's AWD Astro Camper Build
Postby costman13 [OP] » August 7th 2018, 1:44am
I am pretty focused on this van being a very functional camper build.
Here are some camper progress photos -
Stripped the interior, used noico sound deadener everywhere and insulated with 3m Thinsulate and a closed cell, foil back insulation (on the floor).
Added tongue and groove on the ceiling.
"Framed" in the windows to make it easier / cleaner to build to.
Added some small & bright flush mount LED lighting (4 of them).
Added subfloor & vinyl flooring.
Primed and painted the tongue and groove walls.
Started the cabinets!
That's it for now.
I am hoping to have the cabinets finished up this weekend.
Cam.
Cam Östman
costman13
Fueling (7/8 tank)
Fueling (7/8 tank)
Alias (AKA): Cam
Postby WinnieVan » August 7th 2018, 1:51am
Very nice work man! Would love more details about the headliner!!
WinnieVan
Firing on 3 Cylinders (L3)
Years of Membership: WinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full years
Topics: 64
Images: 27
Postby costman13 [OP] » August 7th 2018, 1:58am
It's 5/16" pine tongue and groove from The Home Depot. Pretty inexpensive and super easy to work with.
I used self tapping sheet metal screws to attach 4 1x2" nailers to the existing "ribs" on the ceiling. I then screwed into those using some small self tapping wood screws.
I pre-stained all the wood prior to installation.
Cam Östman
costman13
Fueling (7/8 tank)
Fueling (7/8 tank)
Alias (AKA): Cam
Postby WimpTech » August 7th 2018, 2:01am
Lookin real good!
WimpTech
Firing on 4 Cylinders (L5)
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby costman13 [OP] » August 7th 2018, 2:07am
Wimpazz wrote:Lookin real good!
Thanks Wimpazz!
Cam Östman
costman13
Fueling (7/8 tank)
Fueling (7/8 tank)
Alias (AKA): Cam
Postby WinnieVan » August 7th 2018, 5:40am
Very good idea -- just so I'm clear you drilled the 2x1s into the metal that is still protruding in the picture below? (i.e. the ones where the dude's fingers are?)
Can you shoot some detail photos of how you dealt with the area around the slider?
I've always liked the wooden ceiling look. Even the wife looked over while I was browsing and said "ooohh".
WinnieVan
Topics: 64
Images: 27
Postby 90safari » August 7th 2018, 6:10am
Agreed, more ceiling pics. I've got a headliner job in my future, and I'd like to get rid of the cloth and fiberglass look.
867378671386681
90safari
Firing on 1 Cylinder (L2)
Topics: 5
Images: 160
Van Model Year: 1990
Extra Info: plus an 88 Astro
Postby costman13 [OP] » August 7th 2018, 4:35pm
WinnieVan wrote:Very good idea -- just so I'm clear you drilled the 2x1s into the metal that is still protruding in the picture below? (i.e. the ones where the dude's fingers are?)
Exactly.
I used self tapping sheetmetal screws to go into the thin braces that drop down from the main roof.
I'll see what I can do without removing all the trim at the slider. It's quite simple. I started on the drivers side and went until I has to notch around the slider track. I made sure to cut out a few slots in the tongue and groove so the trim will still "click" in.
Cam Östman
costman13
Fueling (7/8 tank)
Fueling (7/8 tank)
Alias (AKA): Cam
Postby Don1806 » August 7th 2018, 5:59pm
My van is the same color as yours, but with the cladding the same color as the body. Now that I've seen yours with the lift and larger tires, I'm itching to do mine. It won't be for a while if I do it, and it still has to fit in the garage after because the desert heat kills all of my plastic components if the van is left outside. I guess after 19 years with me, the van deserves a makeover.
I love what you're doing with your van.
99 Astro LT - Orginal Owner.
Don1806
Years of Membership: Don1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full yearsDon1806 has been a member for 10 full years
Topics: 18
Images: 2
Alias (AKA): Don
Extra Info: AWD 170K
Postby nosxjeep » August 7th 2018, 7:14pm
I believe that dude might be Jed:
https://www.youtube.com/channel/UCGu5fP ... Q/featured
nosxjeep
Years of Membership: nosxjeep has been a member for 4 full yearsnosxjeep has been a member for 4 full yearsnosxjeep has been a member for 4 full yearsnosxjeep has been a member for 4 full years
Images: 21
Alias (AKA): NoS
Extra Info: LS AWD 3+1 30s
Postby Astro Pop » August 7th 2018, 8:18pm
nosxjeep. I just checked out the youtube videos from your posting. I found this one that I think should be at the top of the Camperized Astro/Safari thread. Lots o good thoughts. Thanks for the tip.
https://www.youtube.com/watch?v=TWb0fBcqvuc
Astro Pop
Years of Membership: Astro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full yearsAstro Pop has been a member for 9 full years
Topics: 41
Images: 9
Alias (AKA): Xfirepop
Van Model Year: 1996
Extra Info: AWD - 5 inch lift
Postby WinnieVan » August 7th 2018, 8:25pm
costman13 wrote:I'll see what I can do without removing all the trim at the slider. It's quite simple. I started on the drivers side and went until I has to notch around the slider track. I made sure to cut out a few slots in the tongue and groove so the trim will still "click" in.
Very nice -- even just pictures of that area with the trim clicked in would be nice. I was mostly wondering if you could maintain the trim in that area after adding the wood, so you've already answered my question.
WinnieVan
Topics: 64
Images: 27
Postby nosxjeep » August 8th 2018, 3:42pm
Astro Pop wrote:Thanks for the tip.
Sure thing!
I follow Into The Mystery channel as he ran an Astro camper for a couple years I think, though now he's into an Express.
He has some good ideas and builds, but nothing quite as nice as what Cam is up to here. Cam's just looks CLEAN!
Nice work!
nosxjeep
Images: 21
Alias (AKA): NoS
Postby costman13 [OP] » August 11th 2018, 2:51am
Here are a few photos of the slider area. No real magic happening here. Just some careful cutting and notching to make as clean of a fit as I could generate. Feel free to ask any questions. I can also pull that trim if you'd find it helpful.
Cam
Cam Östman
costman13
Fueling (7/8 tank)
Fueling (7/8 tank)
Alias (AKA): Cam
Postby WinnieVan » August 11th 2018, 5:04am
Great craftsmanship! One of the best roof/siding mods I've seen.
:clap:
WinnieVan
Topics: 64
Images: 27
Postby Alainzen » August 11th 2018, 5:27am
First post here!
Cam, your build is really inspiring, great job! I bought the same van / color / AWD and now, I feel like tearing that interior apart! :banghead:
Alainzen
Years of Membership: Alainzen has been a member for 2 full yearsAlainzen has been a member for 2 full years
Images: 2
Postby costman13 [OP] » August 11th 2018, 6:51am
Thanks Winnie!
The Cabinets should be in by tomorrow. I may even be able to get started on the bed platform / bench seat this weekend.
We'll see!
Cam
Cam Östman
costman13
Fueling (7/8 tank)
Fueling (7/8 tank)
Alias (AKA): Cam
Postby WinnieVan » August 11th 2018, 5:38pm
Nice! Excited to see some more shots. Take a few of the whole transformation from the back! Will be nice to see it all fit together.
WinnieVan
Topics: 64
Images: 27
Postby 90safari » August 11th 2018, 10:07pm
costman13 wrote:Here are a few photos of the slider area. No real magic happening here. Just some careful cutting and notching to make as clean of a fit as I could generate. Feel free to ask any questions. I can also pull that trim if you'd find it helpful.
Cam
Man that looks beautiful. Very nice work.I agree with with Winnie, definitely shoot some of the transformation.
867378671386681
90safari
Topics: 5
Images: 160
Return to Projects/Builds
It is currently May 16th 2021, 7:13am
Projects/Builds Forum
Attached by: LumaWJ
LumaWJ
in Projects/Builds
Comments: 58
Time: 6:32pm
Attached by: LumaWJ
LumaWJ
in Projects/Builds
Comments: 58
Date: May 14 '21
Time: 7:48am
backinabox
in Projects/Builds
Comments: 53
Date: May 14 '21
Time: 1:59am
Attached by: Brewtus
Brewtus
in Projects/Builds
Comments: 109
Date: May 13 '21
Time: 10:48pm
Attached by: LumaWJ
LumaWJ
in Projects/Builds
Comments: 58
Date: May 12 '21
Time: 8:29pm
