Multipurpose project
Postby 6door74 [OP] » November 26th 2019, 10:29pm
Hello all,
Figured I'd create a build thread since this will be my first real "build". I'll be trying to do some customization plus tackling things like paint and body that I've never done. There will be some things that I pay to have done because I'm well aware of my limitations. I just picked up this 2004 AWD Safari. It has 225k miles so I know major repairs like the engine are probably not far away. I do need it to give me at least a few months trouble free so my wife won't scold me for buying a lemon though. :mrgreen: .
The plan for it is a lift, paint (monstaliner or similar), wheels & tires, 4hi/lo via transfer case swap, some audio/video components, and of course some maintenance items. The purpose of the van is a part time daily driver for me which is also capable of beach driving and going off the beaten path with adventure companies that host things like that. Something along the lines of a camper van so we wouldn't have to sleep in a tent on those adventuress and because my daughter likes to go camping. I MIGHT allow her to use it :lol: It will also be somewhat of a road trip vehicle. When I can't or don't want to take my Ford Flex, but don't need the full size V10 E350 van either.
Now you understand why I've titled the thread as multipurpose project. I'll get around to naming the van eventually. Let the fun begin......
2018 Jeep Compass Latitude 4x4
2014 Ford Flex Limited
2006 Ford E350 XLT V10
2004 GMC Safari AWD
1991 Nissan D21
1984 Chevy Monte Carlo
1974 Pontiac Catalina
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: 6door74 has been a member for 2 full years6door74 has been a member for 2 full years
Topics: 5
  • Project VANDAMN!!!
    by VANDAYUM » January 15th 2021, 6:30pm in Projects/Builds
    January 15th 2021, 7:40pm
    44
    March 9th 2021, 11:41am
Re: Multipurpose project
Postby 6door74 [OP] » November 26th 2019, 10:54pm
I was going to flush the radiator today but i think it will go to a shop. Is this the dexcool sludge that I've read about?
One thing I want to do is eliminate rust as best I can and keep this project on the road. Since i didn't do the flush before work, I decided to remove the hitch so I can clean it up along with the area and ideally put POR everywhere I can. Well, the hitch plus whole rear bumper ended up coming off! That wasn't planned but I couldn't get the bolts that fasten the hitch and bumper together off.
Look at how much dirt was caked in the bumper
So now it's off and I'll be getting up under here and trying to clean up what I can. I wonder if I should get the needed parts for the lift now? I'm guessing that clearance will give me more room to clean up more areas while I'm under there. The actual bumper will need to be replaced. You can imagine how rotted it is with all that dirt that was caked in it.
I'm still unsure of wheels. In the interest of $$$, I'd like to use these wheels off my old Nissan pickup that I'm about to sell off. They are the same bolt pattern and I'd see if I could get some hubcentric rings. Since I plan to do the lift and put some good size tires, i don't know if using 18" wheels is feasible. I haven't been able to find any pictures of anyone with them.
That's all I could get done today before work. Gotta figure out that radiator situation ASAP.
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Postby 6door74 [OP] » November 27th 2019, 6:12pm
Decided to start trying my hand at the rust. I'm looking at using Chassis Saver over POR 15. Does anyone have any input on those two? Also, for these paint over rust solutions, I'm trying to figure out how clean it has to be before applying.
Here on the hitch, I've been using the wire wheel. As you can see it's cleaner and smoother at the bottom. The top will never get that smooth but it is clean enough for a rust converter to be applied successfully? I don't want to get impatient when more needs to be done. But i also don't want to keep at something that's impossible and not even necessary either!
I need to rent a pressure washer so I can get rid of all the dirt and see exactly what I'm left to deal with. I used the hose for now and started to work from the back forwards. Figured I'd make my mistakes back here and get better as I go forward. Here's a before and after. Battery on the drill died so I'm on pause right now. I will definitely need to get another battery and some more wire wheels.
Back to rust converter question. Do this cargo area even need the wire wheel or can the rust paint go right over it as is once the dirt is clean?
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Postby markmitch » November 27th 2019, 6:26pm
I would use the wire wheel on it cause if you leave any loose rust there it will allow moisture into the metal again. If possible get a bucket sand blaster and a compressor and blast it. I had an extra gril cleaning metal brush laying around and used that too. Also old toothbrushes can be used in there too for corners and such.
This may help too: https://www.amazon.com/dp/B001CRETZW?ta ... comp_srdg2
Firing on 8 Cylinders (L6)
Topics: 626
Images: 21
Extra Info: RS V8 AWD
Postby Leeann_93 » November 27th 2019, 11:00pm
You have to remove any loose rust for any of the rust converters to work properly.
Postby 6door74 [OP] » November 27th 2019, 11:24pm
Leeann_93 wrote:You have to remove any loose rust for any of the rust converters to work properly.
Looking at the picture of the hitch by the top 2 holes, that's not considered loose right? So i can put whichever product I choose right over it then? The area by the bottom hole is clearly much cleaner and was less corroded.
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Postby Leeann_93 » November 27th 2019, 11:31pm
f you can't blow it off or wipe it off with a rag, it's not loose.
Postby 6door74 [OP] » November 27th 2019, 11:33pm
Got it! Thanks
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Postby tungtide » November 28th 2019, 1:52am
Most people here seem to like the por 15 I used a product by kleen strip. It's mostly phosphoric acid that converts rust. I then used a rust preventative primer called rust destroyer. ( red iron oxide ) After that I went flat black alkyd. So far happy but my project has never left the shop. ( yet ) Good to see you adding a few years of life to the van. I built my own bumper so if you are ever in Kentucky I have a stock bumper I will let you have. I wont hassle shipping it but, it's free if you are ever in the neighborhood.
Ken
tungtide
Topics: 27
Images: 22
Alias (AKA): tungtide
Van Model Year: 2002
Postby 6door74 [OP] » November 28th 2019, 6:53am
tungtide wrote:Most people here seem to like the por 15 I used a product by kleen strip. It's mostly phosphoric acid that converts rust. I then used a rust preventative primer called rust destroyer. ( red iron oxide ) After that I went flat black alkyd. So far happy but my project has never left the shop. ( yet ) Good to see you adding a few years of life to the van. I built my own bumper so if you are ever in Kentucky I have a stock bumper I will let you have. I wont hassle shipping it but, it's free if you are ever in the neighborhood.
Well look at that. I'll actually be in Cincinnati in 2 weeks. I think I'll take you up on that since it looks like you're less than 2 hours from there! :banana: Got any pictures of the bumper you built? Maybe i could even pay you to build another if you had the time?
Thanks
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Postby 6door74 [OP] » November 28th 2019, 9:24pm
markmitch wrote:I would use the wire wheel on it cause if you leave any loose rust there it will allow moisture into the metal again. If possible get a bucket sand blaster and a compressor and blast it. I had an extra gril cleaning metal brush laying around and used that too. Also old toothbrushes can be used in there too for corners and such.
Your bucket sand blaster suggestion got my attention. That is until google showed me dustless sandblasting! I'm seeing mobile companies that can dustless sandblast the undercarriage with everything still in place. I've seen before and after pictures and I'm very interested. Wondering what the cost it of course... Anyone familiar with this process?
Thanks
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Postby ericstg » November 29th 2019, 3:03am
Is your right(passenger side) leaf spring broken? At the shackle? Looks like a crack all the way across.
2003 AWD Astro Cargo, 3+1(plus a shackle) lift, LT245/75R16, it's badass!
Update 12/31/20: It's dead!
https://www.astrosafari.com/viewtopic.p ... 7&t=129113
ericstg
Years of Membership: ericstg has been a member for 3 full yearsericstg has been a member for 3 full yearsericstg has been a member for 3 full years
Images: 4
Extra Info: AWD Cargo
Postby 6door74 [OP] » November 29th 2019, 5:28am
ericstg wrote:Is your right(passenger side) leaf spring broken? At the shackle? Looks like a crack all the way across.
Yes it is a crack
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Postby ericstg » November 29th 2019, 5:40am
Bummer. Just do this:
https://www.astrosafari.com/viewtopic.php?f=40&t=109802
Good looking van too!
ericstg
Images: 4
Postby 6door74 [OP] » November 29th 2019, 12:06pm
Thanks! The lift was already in the plans but thanks for the extra justification. :lol:
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Postby tungtide » November 29th 2019, 4:56pm
Glad to read that you may want the bumper. Yes about 2 hours south of Cincinnati. I will try to pm you. but i'm not so good on computers. If you like I am [email protected] from there we can exchange phone numbers the I'll send photos. I took all the cladding of of mine and you may want some of that also
Ken
tungtide
Topics: 27
Images: 22
Postby 6door74 [OP] » November 29th 2019, 6:13pm
Got a price from a company on the blasting. They quoted me $550. I think I'm going to go that route. As I said up top, there would be stuff I just pay for. My skill, availability, and patience dictate that I do. I want this project to last so i can work on other things that I'm more familiar with amd comfortable doing. Now i have to decide if i should do the lift first so more of the frame will be accessible to be blasted or just go over those areas by hand/wire wheel afterwards. That will be a little less intimidating.
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Postby markmitch » November 29th 2019, 6:54pm
I would like to see pictures after the blasting is done if that is possible.
Topics: 626
Images: 21
Postby 6door74 [OP] » November 29th 2019, 8:13pm
markmitch wrote:I would like to see pictures after the blasting is done if that is possible.
Most definitely. I don't know where to set my expectations yet, but I'm sure it'll better than i would have been able to do.
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Postby 6door74 [OP] » November 30th 2019, 1:25am
tungtide wrote:Glad to read that you may want the bumper. Yes about 2 hours south of Cincinnati. I will try to pm you. but i'm not so good on computers. If you like I am [email protected] from there we can exchange phone numbers the I'll send photos. I took all the cladding of of mine and you may want some of that also
Sounds good. I'll email you as we get closer to the day and I'm 100% certain I'll be there. In the event you have it listed for sale or someone else local who's interested, don't hesitate to let it go.
Thank you
2004 GMC Safari AWD
1991 Nissan D21
6door74
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 5
Return to Projects/Builds
It is currently March 9th 2021, 11:41am
Projects/Builds Forum
in Projects/Builds
Comments: 122
Date: Today
Time: 12:47am
Attached by: Sparkydog
Sparkydog
in Projects/Builds
Comments: 125
Time: 5:19pm
in Projects/Builds
Comments: 125
Time: 5:18pm
Sparkydog
in Projects/Builds
Comments: 125
Time: 4:45pm
AstroMung
in Projects/Builds
Date: Mar 07 '21
Time: 6:37pm
