99 SAFARI 2WD DRIVER BUILD
Postby JD_GM [OP] » December 23rd 2019, 6:33am
Purchased this van in 2004 from the original owner. Had the trans done 150k ago with HD internals, beast sun gear, corvette servo, RV cooler up front. Shifts great. Had the ECM tuned for intake, exhaust 3" flowmaster, advance curve. Edelbrock/KYB shocks. Rear sway bar, Timbren bumpstops. Drove it daily till 2018. Changed fluids and maintained regularly.
Began having cooling issues..first the heater core went so I bypassed it with a jack handle to connect the lines (hey it's all I had one morning before work)...then it started to blow radiators and water pump seals...but they would last a while...
Currently 220k on the motor, brand new installed parts include alternator, radiator, water pump, upgraded Spider, valve cover gaskets, PS hose, motor mounts. Brand new rear HD springs (with the overload removed so they fit in the clamshell), new shoes, cylinders.
Did all that stuff and now it has a coolant leak...I think at the intake manifold where it meets the driver side head...it's just pouring out when I add coolant...from behind the AC compressor... sooooo... time to get into the motor...
JD_GM
Years of Membership: JD_GM has been a member for 1 full year
  • 02 gmc safari build
    by Rahdigs » October 15th 2020, 5:40am in Projects/Builds
    October 21st 2020, 11:25pm
  • Alpine's 1995 AWD Safari Adventurevan Build Thread
    by AlpineVan » October 23rd 2020, 5:50pm in Projects/Builds
    Last post by AlpineVan View the latest post
    January 13th 2021, 8:34pm
    48
    February 27th 2021, 5:09am
Re: 99 SAFARI 2WD DRIVER BUILD
Postby chucksurette » December 23rd 2019, 3:47pm
Nice Safari!
I've got a 2wd 98 that got AF in the oil. Bearings didn't last long after that...
I'm interested to hear about the mods that you've done - (rear sway bar, vette servo etc...) as mine will be coming apart this spring for a new engine/tranny. Maybe the heater core, now that I read your post...
Good luck with the manifold. Are those bolts 1 time stretch like the head bolts?
The machine that we built
would never save us.
That's what they say....
chucksurette
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: chucksurette has been a member for 1 full year
Topics: 7
Images: 9
Extra Info: RWD
Postby scorean » December 23rd 2019, 8:10pm
Great looking van, love the color! Quick question about the tranny work, did you do it yourself or have a shop do it? What kind of prices did all that run you? (I know, it's not polite to ask but I'm guessing I'll be into beefing up the tranny before long)
scorean
Firing on 1 Cylinder (L2)
Years of Membership: scorean has been a member for 4 full yearsscorean has been a member for 4 full yearsscorean has been a member for 4 full yearsscorean has been a member for 4 full years
Topics: 13
Alias (AKA): Sam
Postby JD_GM [OP] » December 23rd 2019, 8:13pm
The oil still looks good. It was running much better with the Spider upgrade and all those new parts and then it sat for a month.
Then I went to open the radiator cap and as SOON as I did the coolant poured out of that spot somewhere from on top of the motor.
I am pulling stuff off now and going to remove the intake and see how I feel about it all. I am leaning towards yanking the motor because I really like this van even though it's got some things I need to fix like the damn back door is leaking when it rains. Anyone know about fixing that? It's got the 3 doors.
There is a machine shop 15 minutes from me and I'd love to have this van back on the road with a fresh engine....hmmm...92 CPI cam and even better exhaust...
JD_GM
Postby JD_GM [OP] » December 23rd 2019, 8:16pm
scorean wrote:Great looking van, love the color! Quick question about the tranny work, did you do it yourself or have a shop do it? What kind of prices did all that run you? (I know, it's not polite to ask but I'm guessing I'll be into beefing up the tranny before long)
I had a guy do it from the northeast area outside Atlanta. I forget his name but he did an awesome job...he had an ebay store with rebuild service that's how I found him. I did the removal and installation myself and I think he charged me $1000. Love the way it shifts.
JD_GM
Postby scorean » December 23rd 2019, 8:22pm
Nice, thanks for the response!
scorean
Topics: 13
Alias (AKA): Sam
Postby JD_GM [OP] » December 27th 2019, 5:32am
chucksurette wrote:Nice Safari!
Regarding the intake manifold. I am reading the vortecs have had gasket issues at times. This may have been what led up to coolant issues, whilst combined with the issues of the RED "extended life coolant" they stopped making. I noticed upon removal that I have rust colored stains in my fairly new radiator hoses already.
Once my coolant issues started they didn't stop until this intake gasket popped.
Here's a post on a Vortec Head thread I found about gaskets. It's from 2006...
http://nastyz28.com/threads/vortec-cyli ... ost-551372
I think it's interesting that the GM intake bolts come with thread sealer on them already. Do you think that stuff should be adequate by itself?
From what I have found I would have to agree that the MS98000T and GM bolts (12550027) are the way to go. I have seen a lot of people that have complained about intake leaks on their trucks that use vortec heads.
Apparently there was a GM service bulletin and GM has new gaskets that help seal better (GM# 89017465).
Technical Note: This gasket requires the use of GM attachment bolt P/N 12550027 because the bolt has a ball design on the end that seats in the head so it will not crush the intake manifold gasket.
I think the MS98000T is Fel-Pro's vesion of this gasket.
Fel-Pro PermaDryPlus Valve Cover Gaskets feature:
* Aluminized steel carrier
* Fluoroelastomeric coating
* Edge-molded seals
* Sealing beads
* Self-centering torque-limiters
FEL-PRO HAS INTRODUCED AN ADVANCED PERMADRYPLUS
REPLACEMENT INTAKE MANIFOLD GASKET DESIGNED TO SOLVE CHRONIC COOLANT LEAKAGE ISSUES FACING SOME FOURTEEN MILLION GM LIGHT TRUCKS AND SUV'S WITH 5.0L AND 5.7L ENGINES MANUFACTURED FROM 1996 THROUGH 2002. THIS TIME SAVING NEW SET CONTAINS ALL THE PREMIUM TECHNOLOGIES NEEDED TO COMPLETE AN INTAKE MANIFOLD GASKET REPAIR, INCLUDING PERMADRYPLUS LOWER MANIFOLD GASKETS, UPPER MANIFOLD GASKETS AND AN ADVANCED PERMADRY VALVE COVER GASKET.
IT APPEARS THAT ON MANY OF THESE ENGINES, THE USE OF CONVENTIONAL PLASTIC-AND-RUBBER GASKETS IN COMBINATION WITH THE MORE AGGRESSIVE 'OAT' (ORGANIC ACID TECHNOLOGY) ENGINE COOLANTS HAS CAUSED A SIGNIFICANT NUMER OF SEALING- RELATED ISSUES.
JD_GM
Postby JD_GM [OP] » December 27th 2019, 5:41am
Glorious original motor that still runs ok. Minor "chevy ticking" ... probably needs a distributor that thing is squeaking... I changed the oil religiously and always used AC Delco PF52 filters...usually Castrol 10/40...Yes I am thinking of pulling the whole thing and rebuilding it. I will see how it goes tearing this stuff off and getting the intake off.
JD_GM
Postby JD_GM [OP] » December 29th 2019, 6:36am
Hopefully this RV cooler kept the trans cool. 150k on trans heavy duty rebuild.
Taking stuff off the front. Need to remove the AC condenser
Then make some plates before cutting the upper core support out. I think I will drill the holes in the plates and then do the cutting. The cuts will probably be as wide as the edges of the condenser.
JD_GM
Postby markmitch » December 29th 2019, 2:13pm
If you can locate a 1st gen van in a salvage yard you can take the to core support off it and use it in place of the section you cut off as it is a bolt on item. see the picture of a 1st gen where it unbolts and you can see how you could modify yours to accept the earlier version to make it easier.
Firing on 8 Cylinders (L6)
Topics: 626
Images: 20
Extra Info: RS V8 AWD
Postby Mmusicman » December 29th 2019, 3:51pm
JD_GM wrote:Then make some plates before cutting the upper core support out. I think I will drill the holes in the plates and then do the cutting..
Perfect! It's pretty basic, and even better when done right!
Even on my Gen 1.. I still permanently removed these tabs..
(this was actually done for a radiator upgrade.. but good for V8 swaps too)
JD_GM wrote:I think I will drill the holes in the plates and then do the cutting..
Good plan! Fit the brace first.. then cut!
Topics: 73
Images: 49
Postby JD_GM [OP] » January 3rd 2020, 4:20am
Thanks for the info guys looks good. Here's the plates but I am also going to add a front piece which will be like a U-cup and I will weld it all to the center so it pushes onto the side pieces and then bolts only on the sides.
I'll post pics when I get to that but I think you know what I mean.
JD_GM
Postby JD_GM [OP] » January 3rd 2020, 4:29am
My cut lines for the plasma cutter
fiber blanket to protect stuff
cut out and easier to reach engine!
some more hoses off, broke the heater valve, the plastic was brittle
JD_GM
Postby JD_GM [OP] » January 3rd 2020, 4:37am
More stuff off.
I can remove the EGR hose going down to the manifold header and also plate off the EGR valve, correct?
I will have it turned off in the tune. I may replace the lower intake with a 2002(?) and newer...
JD_GM
Postby JD_GM [OP] » January 3rd 2020, 4:42am
Now it looks like a motor! hmmmmm....350?
I'd love to... but I need to get a solid van again as soon as I can. I will do the CPI cam in this, open the bowls up in the heads and maybe do headers. Was thinking of the Pacesetter set.
I am definitely going to have the exhaust crossover redone that thing looks restrictive as all heck.
JD_GM
Postby JD_GM [OP] » May 14th 2020, 1:26am
Lets do some pics updates!
Motor coming out (a few months ago)
JD_GM
Postby JD_GM [OP] » May 14th 2020, 1:46am
The mounting plate for the engine stand. The stand was given to me by my friend Rick who passed away years ago, his dad home built it and he had a mopar 440 on it with a blower so I think it will hold this engine. The stand has had a few engines on it including a mopar 318 I built with swirl port heads, also a Toyota 22RE
The middle cylinder here had some water in the cylinder and mild rust, the intake gasket had leaked. Good thing I decided to tear it down instead of just do the intake gasket.
JD_GM
Postby JD_GM [OP] » May 14th 2020, 4:12am
Block bored .030 over
I have to look up which part # these are, we chose them from a 350 they have the one sided valve reliefs and are a little higher compression than stock, they are cast with the coated skirts
The stock rods with pressed pins were resized with ARP rod bolts
JD_GM
Postby JD_GM [OP] » May 14th 2020, 4:26am
The exhaust was more important to get more flow from what I researched so I asked Ken to cut the seats open to 1.60 inch (stock 1.50) and unshroud the seats with a nice multi angle valve job. He cut way down into the openings and I plan on running a nice big long Y pipe 2.25" or maybe 2.5" into the 3" exhaust.
The intake is stock 1.94 but also similar work on the valve seats and also a new set of valves.
We considered going to 2.02 intakes but they were really close in the middle between them and decided to leave them stock.
The tops of the guides and spring seats were cut down to allow the right valve height and HD Erson springs were used with the original retainers.
The guides themselves were sleeved with iron sleeves and then new PC seals.
The rocker arm studs will be new screw in adjustable studs that will work with the stamped and self aligning 1.6 rocker arms to get some more lift from the '92-'95 CPI cam.
JD_GM
Postby JD_GM [OP] » May 14th 2020, 4:37am
Old stock cam on right is stock '99 Vortec
You can see the obvious difference in duration and lift!
New stock cam on left is Sealed Power CS1537 for 92-95 "CPI"
specs as follows:
1992-’95 VIN “W” WITH BALANCE SHAFT: The premium high output engine came with central fuel injection, a balance shaft and a better cam starting in ’92. They are comparable grinds so most rebuilders are interchanging them.
10144047
10241693
Opens : -17 BTC/39 BBC
Closes : 45 ABC/-11 ATC
Duration : 208/208
Opens : 13 BTC/70 BBC
Closes : 84 ABC/24 ATC
Duration : 277/274
Cam Lift : .288/.293
Gross Valve Lift : .432/.439 (w/ 1.6 rockers----.460/.468)
Center Line C/L : 121/115
Rocker Arm Ratio : 1.5/1.5
Valve Lash Clearance : HYD/ROLLER
(Cross referenced from Mellings OE equipment guide)
A E CLEVITE 1668
DANA/CLEVITE 229-2286
ENGINE POWER COMPONENT EPC-4613A
GENERAL MOTORS 10144047
SEALED POWER/FEDERAL MOG CS-1537
data here:
http://www.earlycj5.com/xf_cj5/index.ph ... tes.95401/
JD_GM
Return to Projects/Builds
It is currently February 27th 2021, 5:09am
Projects/Builds Forum
Bigforkg
in Projects/Builds
Comments: 32
Date: Feb 24 '21
Time: 3:29pm
Attached by: Sparkydog
Sparkydog
in Projects/Builds
Comments: 120
Date: Feb 23 '21
Time: 4:28pm
Sparkydog
in Projects/Builds
Comments: 120
Date: Feb 23 '21
Time: 4:13pm
JD_GM
in Projects/Builds
Comments: 48
Date: Feb 23 '21
Time: 6:03am
JD_GM
in Projects/Builds
Comments: 48
Date: Feb 23 '21
Time: 5:51am
