by augidog [OP] » March 2nd 2020, 12:03am
by Rockridge » March 2nd 2020, 1:31am
by Rod's Trucks » March 2nd 2020, 7:43am
by augidog [OP] » March 2nd 2020, 3:37pm
by augidog [OP] » March 3rd 2020, 9:44pm
by 90safari » March 4th 2020, 10:07pm
augidog wrote:This, along with the passenger seat power lift/swivel, is coming out.
Don't know if they have any appeal or value, but to me they don't.IMG_20200303_121304.jpgIMG_20200303_121328.jpgIMG_20200303_121902.jpg
by augidog [OP] » March 5th 2020, 12:04am
It works. As a Veteran who has received a lot of help over the years, I won't have a problem donating it to a worthy organization. Where you located? Come take it out and it's yours. That offer is 1st come 1st served, I've also called the local DAV.90safari wrote:You might see about donating it to a local "Center for independent living" organization IF it works. Some places will take it off your hands to help their customers. They might even give you a tax credit for doing so. I know my local organization would love to have it, as most places like that are always short on items to help their customers (more need than supply). Just a thought.
by augidog [OP] » March 5th 2020, 4:43pm
by augidog [OP] » March 6th 2020, 6:15am
by SportsBoy » March 6th 2020, 1:55pm
augidog wrote:
Fluids are full and relatively clean. Based on this picture, what would an experienced owner suspect is the source of the leak? Whatever it is, it isn't drastic, at least while parked, I only have a few drops on the driveway after a month.IMG_20200305_212140_311.jpg
by augidog [OP] » March 6th 2020, 2:58pm
The lines themselves...that's great news. Thank you, SportsBoy, i KNEW someone here would pick right up on it. This place rocks.SportsBoy wrote:
Oil cooler lines probably - super common problem
by Wiley » March 6th 2020, 3:43pm
by augidog [OP] » March 6th 2020, 4:43pm
Thank you. I appreciate the confirmation, and I DO believe I got myself a fine specimen. My worry was that someone was going to tell me a hard to reach and/or expensive component was dripping onto the lines. Life is full of surprises, and not always good ones.Wiley wrote:Agreed, you can see them in the last pic, def the problem. I cut my leaky lines and clamped on new ones successfully based on the write up here, but every year or so they would end up leaking, so I finally did the oil cooler line delete....have not decided if it is permanent yet, but it probably is.
Nice van
by augidog [OP] » March 7th 2020, 2:52am
by AstroWill » March 7th 2020, 3:34am
augidog wrote:About the delete...I won't ever be towing more than my utility trailer, and highway driving will be rare, so...any more opinions based on experience?
by Leeann_93 » March 7th 2020, 5:04pm
by augidog [OP] » March 7th 2020, 5:07pm
AstroWill wrote:I have done it, definitely didn't see a change in engine temp, don't have an oil temp gauge, but I will be doing it to my latest Astro as well once I get around to it. Trying to get my son to help out/learn as much as possible. Just makes everything take 10times as long as he doesn't have as much spare time as I do.
Leeann_93 wrote:I did it on my '02 when the brake lines all exploded; the brake fluid finished off already-leaking lines. That was in the fall, so I didn't drive it in a MD summer like that. The oil pressure increased and I never saw any temp-related problems, but it was winter and I didn't tow anything. And then I bought my '05 in the spring so I didn't drive the '02 when it warmed up, then a tree branch fell on it and finished it off.
The ones on the '05 are leaking and I have new ones to replace them with. I have a new radiator and new trans cooler lines (they're also starting to leak) and my plan is to do all of that at one time.
by 90safari » March 8th 2020, 8:40pm
augidog wrote:It works. As a Veteran who has received a lot of help over the years, I won't have a problem donating it to a worthy organization. Where you located? Come take it out and it's yours. That offer is 1st come 1st served, I've also called the local DAV.90safari wrote:You might see about donating it to a local "Center for independent living" organization IF it works. Some places will take it off your hands to help their customers. They might even give you a tax credit for doing so. I know my local organization would love to have it, as most places like that are always short on items to help their customers (more need than supply). Just a thought.
by 90safari » March 8th 2020, 8:53pm
augidog wrote:I can afford new OEM lines, but I'll look for that write-up about cutting and clamping. I suspect it will have something to do with being easier, and not about the money. About the delete...I won't ever be towing more than my utility trailer, and highway driving will be rare, so...any more opinions based on experience?
by augidog [OP] » March 24th 2020, 2:01pm
It is currently March 8th 2021, 1:49pm
Projects/Builds Forum |
Previous topic Next topic |
Sponsors |
Users browsing this forum: sixsix and 5 guests
