This Oaf's Adventure With His Astro
Postby AstroOafAdventurer [OP] » August 19th 2020, 9:49pm
Hey hey AstroSafari.com!
I'm a relatively new member having recently purchased my 1997 Astro conversion van with 62k miles.
I went to this van from a 2004 Honda Odyssey with 205k miles, and so far really like my Astro.
My plans are to get all, or most, the small things worked out, bring everything up current maintenance wise, and then gut and camperize.
I went to a local pick a part this morning and got a temp and fan control knob along with a sliding door window catch lever.
After, I took it in for a pre-purchase inspection which found the following:
Driver's front window (known)
No AC (Will diagnose according to FSM to determine/verify low freon, I added 2 Wally World cans but still no clutch engagement)
Air blows out defrost only (have already found rotted vacuum line for control)
Slight leaks in rear pinion seal, rear main seal, and oil cooler lines (no puddles under vehicle, will prob look at oil cooler lines)
Battery hold down missing (battery tray is fairly rusted too, will look for when I go to pick a part again)
Headlamps cloudy (would like to replace with better aftermarket headlights anyway)
EVAP monitor not ready (no clue how they arrived at this, no CEL or codes, WTF is this?!)
First order of business is getting the window working, and the air duct control.
I have replacement motors and vacuum line part en route for delivery tomorrow.
Pics coming soon...
Last edited by AstroOafAdventurer on August 19th 2020, 11:42pm, edited 1 time in total.
97 Astro Conversion Van 62k 64k miles
AstroOafAdventurer
Topics: 40
Alias (AKA): Thorsteenster
  • 2003 AWD Astro - Elderforest
    by elderforest » August 29th 2020, 6:30pm in Projects/Builds
    December 1st 2020, 2:07am
  • 2002 Chevy Astro Cargo AWD Stealth Camper Conversion
    by YaYa » September 2nd 2020, 9:18pm in Projects/Builds
    Last post by YaYa View the latest post
    September 7th 2020, 1:32am
    9
    51
    February 27th 2021, 4:22am
Re: This Oaf's Adventure With His Astro
Postby AstroOafAdventurer [OP] » August 20th 2020, 2:02pm
In the meantime, here's some back story on the van.
I bought it from a guy down the street, which I'm not sure how long he owned but I'm guessing not long as he hadn't transferred the title yet.
He lives in a townhouse and moved it weekly for parking, he told me the guy he got from, he'd done some work for a few years back and had asked him about the van as it was sitting on the street. He was told it was the guys father's van, and he was keeping it for it sentimentality.
So 5 years later, the guy calls the guy I bought it from and asked if he wanted it, and he came and got it.
From there, the PO indicated he'd wanted to start using it as a family vehicle but had another car or something and ended up listing it for sale. I think his wife had some prompting in this...
It certainly runs like a van with only 62k miles, but things inside make me think some hellions had been on the loose, missing knobs, missing/loose screws etc.
AstroOafAdventurer
Topics: 40
Postby AstroOafAdventurer [OP] » September 13th 2020, 9:50pm
I started removing the interior, I had initially planned on gutting it, but after starting, being I have a conversion van already, I don't have the plastic interior pieces like other passenger vans.
I will strip out the high top to install a vent, and it won't be insulated or covered as I like hearing rain.
After removing parts I'm thinking I'll leave the major part of it alone, probably even the carpeting. I don't know how well they insulate before building them out, but the cloth has a foam backing and has minimal intrusion to the interior.
I like the area overhead in the cockpit, makes for a nice storage shelf.
Here's what I've cleared so far, next will be more the rear and liner.
AstroOafAdventurer
Topics: 40
Postby AstroOafAdventurer [OP] » October 21st 2020, 9:03pm
I started painting the inside of the high top with Kilz primer and should be finishing it up today, it's got three coats. I'm no painter, but I'm wondering if I can leave it the primer, or should I put a coat of paint on it?
I also got my MaxxFan Deluxe 5100K model, Amazon had an open box I nabbed for $250 and doesn't look to have been opened at all.
I made a template for marking where to cut in the roof.
Further also, I installed my dutch seal:
https://www.astrosafari.com/viewtopic.php?f=11&t=144242
AstroOafAdventurer
Topics: 40
Postby sixsix » October 24th 2020, 12:33am
And boy, do I have some catching up to do.
Nice... so far
So only CAL, ILL & NY Elects
Firing on 6 Cylinders (L5)
Topics: 38
Images: 1320
Postby AstroWill » October 24th 2020, 12:58am
AstroOafAdventurer wrote:I started painting the inside of the high top with Kilz primer and should be finishing it up today, it's got three coats. I'm no painter, but I'm wondering if I can leave it the primer, or should I put a coat of paint on it?
You can just leave it primer if you want, won't hurt anything.
AstroOafAdventurer wrote:I also got my MaxxFan Deluxe 5100K model, Amazon had an open box I nabbed for $250 and doesn't look to have been opened at all.
They are on sale for $238 shipped right now and are great fans! I love mine.
https://amzn.to/3ohWly5
Images: 472
Postby AstroOafAdventurer [OP] » December 10th 2020, 12:50am
And now $229, that was the final straw, I was still able to return mine and just got back from dropping it at Kohls.
However, for just $43 more I can get a 7500K for $298, that's the deluxe deluxe version with auto open and remote.
https://www.amazon.com/Maxx-Air-0000750 ... B002OW5JG2
I would go for the mid model again, but I decided i want to go with smoke, and it's $294
Also, I do believe these wired remotes will work with the Deluxe models:
https://www.adventurerv.net/maxxair-max ... 85669.html
AstroOafAdventurer
Topics: 40
Return to Projects/Builds
It is currently February 27th 2021, 4:22am
Projects/Builds Forum
Bigforkg
in Projects/Builds
Comments: 32
Date: Feb 24 '21
Time: 3:29pm
Attached by: Sparkydog
Sparkydog
in Projects/Builds
Comments: 120
Date: Feb 23 '21
Time: 4:28pm
Sparkydog
in Projects/Builds
Comments: 120
Date: Feb 23 '21
Time: 4:13pm
JD_GM
in Projects/Builds
Comments: 48
Date: Feb 23 '21
Time: 6:03am
JD_GM
in Projects/Builds
Comments: 48
Date: Feb 23 '21
Time: 5:51am
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 7 guests
