Mark's rear drive to AWD/4x4 conversion
Postby markmitch [OP] » November 2nd 2020, 2:57am
Moderators/admin please feel free to put the other posts about this into this thread.
I started with a rear drive 89 Astro RS, I added a 350 from a 91 silverado. Now I am taking the frame, front differential
from a 1998 AWD cargo van I bought for 400 cash. Luckily the 98 has the same gear ratio as my 89 rear axle so I do not need the axle from the 98. I sold the engine for 100, the trans for 100 and various other parts for about 100. So I have the frame, front differential, transfer and front suspension. The 98 had new shocks all around so I got them too.
I did a lot of reading and asking questions possibly some of the same questions more then once lol. I had to buy a special oil pan to fit this frame with my 350 V8. I also had to buy a different transmission to transfer adapter because I am using a 700R4 instead of the 98 4l60E. I also bought an add a leaf and the 6 each 2" body lift pucks. I have no idea what they are called now but years ago they called them pucks. I am using the stock 98 driveshafts for now with the factory transfer case for AWD but I plan on swapping it for a 233C in the future. I removed all the wiring and brake lines from the 98 frame since I will be using the braking system from the 89 for simplification. I already had the steel leaf springs from a 2000 Astro installed on my Astro so that part is done. I will update this as I go.
Firing on 7 Cylinders (L6)
Topics: 622
Images: 20
Extra Info: RS V8
  • 1989- RS to 4x4 swap list
    by markmitch » September 12th 2020, 4:27pm in Projects/Builds
    November 8th 2020, 4:48pm
  • 2002 Chevy Astro Cargo AWD Stealth Camper Conversion
    by YaYa » September 2nd 2020, 9:18pm in Projects/Builds
    Last post by YaYa View the latest post
    September 7th 2020, 1:32am
    40
    January 17th 2021, 8:16am
Re: Mark's rear drive to AWD/4x4 conversion
Postby AstroWill » November 3rd 2020, 7:23pm
Sure thing Mark, just copy the links for the threads you want merged and I will take care of it for you.
Images: 460
Postby markmitch [OP] » November 15th 2020, 12:51am
The 89 Body sitting on the 98 frame with 2 inch body lift and a sticker I had made for the van. Also 1 pic of the 2 wd drive frame prior to being stripped.
I figured out the power steering lines are the same thread so those are done and the brake lines are the same thread also so I will have to make one to three lines since the frames are shaped different. I will figure out what I will have to make or at least bend tomorrow weather permitting. The rear drive frame has the brake line crossing on the crossmember beneath the engine oil pan but the AWD frame it crosses in the front right behind the bumper so I will try to use the original brake line but I don't think it will work.
Topics: 622
Images: 20
Extra Info: RS V8
Postby markmitch [OP] » November 15th 2020, 4:27am
I will also have to buy some type of clips to hold the brake lines on to the frame.The factory clips are very brittle from age.
Topics: 622
Images: 20
Extra Info: RS V8
Postby markmitch [OP] » November 16th 2020, 5:30pm
I did encounter a potential problem that I will have to figure out: the 98 came with a totally different system for the shifting of the transmission. The 1st gen vans have a mechanical armature that attaches to the steering column and then down to the frame then to the transmission. The 2nd gen van used a cable of sorts. I may have to go back to a floor shift like I had before. I will post what I come up with when I figure out how to do it. I can't use the system from the 98 since my transmission is a 91 700R4.
Topics: 622
Images: 20
Extra Info: RS V8
Postby M_a_t_t » November 16th 2020, 6:08pm
When I was looking at the cable shift trans (not very long or paying attention to detail) it looked like you could just undo the nut holding the shifter connection on and replace with the linkage connection from the 1st gen.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Topics: 27
Images: 96
Extra Info: cl rwd
Postby WoodButcher » November 16th 2020, 6:12pm
Got my eye on you!
:D
WoodButcher
Firing on 5 Cylinders (L6)
Topics: 30
Images: 514
Alias (AKA): Bruce
Extra Info: 5.7L RWD
Postby markmitch [OP] » November 16th 2020, 6:27pm
I did something stupid lol I was kinda rushing getting the AWD frame ready and I cut all the cables and brake lines to just get them out of my way. Its all good I will just have to redo the console I built to fit the hurst shifter I had in the van in the past and put it back in. No big deal to me since I already own the shifter. I remember there was a member that posted a console he got from a ford I think and put a floor shift in it where the original shifter (ford) was and I believe he used a mega shifter. But I can't find the post. I may just start searching pick n pull vehicles till I find one that suits me. As for the brake lines I will just buy new lines and bend them then paint them and install them its pretty simply stuff.
Topics: 622
Images: 20
Extra Info: RS V8
Postby 90safari » November 16th 2020, 7:11pm
When I did my V8 swap (on my old 85 panel van) I used a B&M shifter, and cut a hole in the floor where the factory would have cut for a floor shifter. It was kind of close to the seat, but worked just fine. It was also a cable shifter with a very long cable attached to it. I think I got it from Summit for 100 bucks. Sorry no pics of it though.
867378671386681
90safari
Firing on 1 Cylinder (L2)
Topics: 5
Images: 160
Van Model Year: 1990
Extra Info: plus an 88 Astro
Postby AstroWill » November 17th 2020, 5:09am
Awesome Mark! Will be watching your progress.
Images: 460
Postby markmitch [OP] » November 20th 2020, 12:20am
OK so I got the adapter that was incorrect to work by cutting a ring out of the inside. After that it lined right up. Today I took the 700R4 apart and removed the rear drive output shaft and slide the AWD shaft in to its place. Tomorrow I will finish up cause my transmission was not shifting properly so I need to look into what could be the cause. I also noticed the inner tie rod end on the passenger side is missing the boot. I know I can just replace the boot but for 20 bucks I may as well just replace it. Project is moving right along, not much for REAL problems as of yet just little stuff like misplacing things lol.I am thinking of replacing the rear springs with the S-10 springs to match the 2" body lift instead of working with the steel springs I already installed a few years ago.
I replaced the rear main seal and oil pan gasket since I am swapping oil pans anyway.
Topics: 622
Images: 20
Extra Info: RS V8
Postby markmitch [OP] » November 20th 2020, 1:33am
My new oil pan for the AWD/4x4 V8 swap.
Topics: 622
Images: 20
Extra Info: RS V8
Postby sixsix » November 20th 2020, 2:00am
I think I see that shaft... under the jacket... right there...
... See you been to the "chevymaher garage box / organization / shelving system course".
Think you'll need AWD/4WD/4X4 in Texas too? Desert / Mountain climbing instead of Blown Snow.
Well, after all... what would Banacek say ?... Anyone that condones the actions of the American People during the Storming of the Capitol are as complicit as the Assholes themselves.
But no way does this let the Democrats or the MSM off the Hook.
Firing on 5 Cylinders (L5)
Topics: 38
Images: 1316
Postby markmitch [OP] » November 20th 2020, 2:29am
My van will be in New Hampshire when its done, When we go to Texas we will possibly get a little car to keep there just to get around.The sticker was just me playing around.
Topics: 622
Images: 20
Extra Info: RS V8
Postby AstroWill » November 20th 2020, 8:29pm
Can you give the dimensions of that pan?
Images: 460
Postby markmitch [OP] » November 21st 2020, 12:57am
Yes here is the info, also you will need the oil pick up tube for a 90 4x4 blazer 4.3 to work with the pan. The silver pan is the custom one I got from JTR.
Topics: 622
Images: 20
Extra Info: RS V8
Postby AstroWill » November 21st 2020, 8:16pm
That is what I was looking for. Thanks!
Images: 460
Postby markmitch [OP] » November 22nd 2020, 12:04am
Anytime! glad to be of help. Mark
Topics: 622
Images: 20
Extra Info: RS V8
Postby 90safari » November 22nd 2020, 8:54pm
Seeing that reminds me of the old V8 Vega days. I modified a few pans back in the day. Had a few V8 Vegas too. ;)
867378671386681
90safari
Topics: 5
Images: 160
Postby markmitch [OP] » November 28th 2020, 2:25am
So a few years ago I rebuilt my 700R4 and I never did figure out why the reverse was out. However I took it apart again to swap the output shaft to make it AWD. So I found one valve that was stuck, so I tried to get it out and it came out in two pieces. One piece is still stuck in the valve body. Not sure if this is common but I will have to get a non screwed up one to finish this. Mark
Topics: 622
Images: 20
Extra Info: RS V8
Return to Projects/Builds
It is currently January 17th 2021, 8:16am
Projects/Builds Forum
VANDAYUM
in Projects/Builds
Date: Jan 15 '21
Time: 5:04pm
Attached by: markmitch
in Projects/Builds
Comments: 56
Date: Jan 14 '21
Time: 12:01am
Attached by: AlpineVan
AlpineVan
in Projects/Builds
Comments: 14
Date: Jan 13 '21
Time: 8:27pm
in Projects/Builds
Comments: 113
Date: Jan 12 '21
Time: 9:36pm
in Projects/Builds
Comments: 114
Date: Jan 12 '21
Time: 3:21am
