Rorge is a 2000 Astro cargo van I bought to move stuff and tow cars. It's only the second van I've ever owned in over 40 years of driving and I regret not having a van like the Astro a lot earlier.
As i spend a lot of time restoring and driving my project cars, most of this build will focus on gradually making Rorge as reliable as possible and to replace a few worn out parts as I discover them.
The first fix is the sliding door, which more aptly has been the scraping door, as you will see in the pictures.
Pre-98 Astros have welded on mid door brackets and use a spring to help pop out the rear edge of the sliding door. The latch is positioned just above the bracket.
My 2000 van uses a different mid-door bracket design, which uses simple hinge geometry (no spring needed) and a higher mounted latch ppsition to nudge the rear of the sliding door open when the door handle first releases the latch from the striker.
the lower sliding door stop had a few pounds of dried clay clogging it.
the replacement forward bracket and old bracket looked similar from the top.
but the bottom roller was flat spotted and clogged with clay.
some closeups of the replacement roller
and the old flat spotted one
the mid door roller bracket had a small bearing fail.. so the back of the sliding door would jam and not pop out a bit when trying to slide back the sliding door..
a 5 gallon bucket supported the bottom of the door while I changed out the mid door hinge bracket.
All done.. a light application of white lithium grease on the bearings will help prevent clogged/seized rollers in the future. Door now slides easily and operates quietly.
