2000 Cargo Van interior
Postby Harleybowtie [OP] » August 10th 2013, 2:17am
Picked up my 2000 Astro 2wd cargo van about eight weeks ago. It's a creampuff with 70K miles. I stripped out the shelves & bulkhead (sold it on Craigslist) The noise of a bare metal van was giving me headaches. I decided to put self adhesive sound deadener on all the flat surfaces both walls and roof. Over that I installed some bubble wrap (kind of) insulation. In the roof I added a layer of carpet padding. I cut the roof for a crank up vent. I chose the smaller 9.5" instead of the 14" so I wouldn't have to cut two roof struts. I used 1/8" Masonite to make the panels and glued indoor/outdoor carpeting on. I mounted the panels with # 6 sheet metal screws.
Harleybowtie
Years of Membership: Harleybowtie has been a member for 7 full yearsHarleybowtie has been a member for 7 full yearsHarleybowtie has been a member for 7 full yearsHarleybowtie has been a member for 7 full yearsHarleybowtie has been a member for 7 full yearsHarleybowtie has been a member for 7 full yearsHarleybowtie has been a member for 7 full years
Topics: 19
Images: 45
  • Rorge Astro 2000 cargo build
    by rorgeastro » December 2nd 2020, 7:36am in Projects/Builds
    Last post by rorgeastro View the latest post
    December 22nd 2020, 11:10pm
  • 2002 Chevy Astro Cargo AWD Stealth Camper Conversion
    by YaYa » September 2nd 2020, 9:18pm in Projects/Builds
    Last post by YaYa View the latest post
    September 7th 2020, 1:32am
    26
    February 27th 2021, 10:01pm
Re: 2000 Cargo Van interior
Postby Harleybowtie [OP] » August 10th 2013, 2:37am
Moving on to the walls I used craft paper to make a template. It makes cutting the Masonite easier, and more accurate. I ran the carpet a few inches past the vertical on the walls. The stock plastic corners had to be trimmed a little but they work well. On the walls I added styrofoam in the deep pockets. I made some wheel well covers out of 5/8" pressboard. They hide the jack, lug wrench, some tools, etc. Covered them with the same in/out carpet.
Harleybowtie
Topics: 19
Images: 45
Postby Harleybowtie [OP] » August 10th 2013, 2:50am
Thinking outside the box I got a length of 3" PVC and ripped it into thirds. Cutting them to length I wrapped 'em in the carpet and screwed them up with # 8 screws.
On the side door post I used a heat gun and clamps to get the shape I needed. I slipped a 14" piece of 1/4" X 1.5" steel into the post, secured by 1/4" -20 button heads. I drilled & tapped the holes for the D-ring tie down too. That thing's going nowhere.
Harleybowtie
Topics: 19
Images: 45
Postby doyoulikeithere » August 10th 2013, 2:55am
:bow:
Thats really nice !
:twisted:
doyoulikeithere
Firing on 7 Cylinders (L1)
Years of Membership: doyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full yearsdoyoulikeithere has been a member for 12 full years
Topics: 26
Images: 11
Postby SilverBullet1997 » August 10th 2013, 3:21am
All I can say is WOW, that looks nicer then my passenger van lol...
So how much $? How much weight do you think it added?(I know you took the boxes out(which are not light..lifted them before)
R.I.P.-1997 Astro AWD SilverBullet I 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
R.I.P.-1999 Astro AWD SilverBullet II 1-4-1999 - July-2016 - Cause of death: Roadrash passenger side
Current: 1999 Astro AWD GreenBullet I - Purchased 02/2018
SilverBullet1997
Firing on 6 Cylinders (L2)
Years of Membership: SilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full yearsSilverBullet1997 has been a member for 7 full years
Topics: 54
Images: 247
Alias (AKA): Silver or Bullet or SB
Extra Info: 7in Lift AWD Z71
Postby gavio » August 10th 2013, 4:28am
That is some nice work, very thorough...... I'm impressed, and I don't impress all that easily.
gavio
Topics: 77
Images: 4
Postby Harleybowtie [OP] » August 10th 2013, 5:33am
Weight wise I think it's still lighter than it was with the bulkhead and tool box and shelves. The insulation weighs hardly anything. Three sheets of 4' X 8' 1/8" Masonite and less than one full sheet of 5/8" pressboard were the heaviest additions. The carpet is very light weight recycled plastic milk & water bottles. The PVC is also light weight. I'd guess total weight is under 175 lbs. As for cost, it's been a running project so I haven't totaled up the cost but I'd guess in the $350 dollar range. I'm going to take the drivers side panel off to reinforce the stamped steel structure with a piece of 1/4" X 1.5" steel bar stock to mount another D-ring tie down. This van is my antique bike hauler. When I do the retro fit I'll take more pix. When it's done I'll get shots of the bike loaded inside.
Thanks for the positive comments.
Harleybowtie
Topics: 19
Images: 45
Postby Ksmith » August 10th 2013, 12:07pm
You've done an outstanding job! Looks good.
Ksmith
Years of Membership: Ksmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full yearsKsmith has been a member for 10 full years
Topics: 21
Alias (AKA): Brushfire
Extra Info: AWD Z71
Postby Harleybowtie [OP] » August 12th 2013, 8:52pm
Took the drivers side panel off to retro fit the reinforcing steel for the hard point tie down. 1 1/2" X 1/4" steel bar stock, bent to the contour of the wall rib. 16" long, drilled & tapped.
Covered the gas fill bump w/carpeting too. That's a wrap.
Harleybowtie
Topics: 19
Images: 45
Postby safariking » August 12th 2013, 9:48pm
that's nice clean look makes me rethink about not buying a panel truck very nice
safariking
Years of Membership: safariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full yearssafariking has been a member for 7 full years
Topics: 23
Images: 9
Extra Info: SLE 4.3
Postby TheFridge2000Astro » August 19th 2013, 1:33pm
Very nice...I also have a 2000 Cargo that I've started removing the shelving. You've given me some ideas about how to finish my interior.
TheFridge2000Astro
Years of Membership: TheFridge2000Astro has been a member for 8 full yearsTheFridge2000Astro has been a member for 8 full yearsTheFridge2000Astro has been a member for 8 full yearsTheFridge2000Astro has been a member for 8 full yearsTheFridge2000Astro has been a member for 8 full yearsTheFridge2000Astro has been a member for 8 full yearsTheFridge2000Astro has been a member for 8 full yearsTheFridge2000Astro has been a member for 8 full years
Images: 14
Alias (AKA): Big O
Extra Info: Cargo 4.3L V6 RWD
Postby Tegnus » August 28th 2013, 6:50pm
Good job - gives me idea on how to convert my passenger van into a camper with saving tons of space and not looking very ugly. :)
2004 Astro AWD (Astrid), 3" Lift, BFG All-Terrain T/A KO2 LT225/75R16, Tru-Cool LPD-4490 Trans cooler, ARB Awning 2500 (ARB4401A)
Follow us on Facebook and Instagram | Check out the build of our 2004 Chevy Astro AWD "Astrid"
Tegnus
Years of Membership: Tegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full yearsTegnus has been a member for 7 full years
Topics: 38
Images: 6
Postby gatorfan » August 28th 2013, 8:42pm
k that is bad *** what kinda bike are you hauling around in it? i may do this to my van
gatorfan
Years of Membership: gatorfan has been a member for 7 full yearsgatorfan has been a member for 7 full yearsgatorfan has been a member for 7 full yearsgatorfan has been a member for 7 full yearsgatorfan has been a member for 7 full yearsgatorfan has been a member for 7 full yearsgatorfan has been a member for 7 full years
Extra Info: LT
Postby Harleybowtie [OP] » August 28th 2013, 9:42pm
I've got a '62 panhead that fits like a glove.
Check out my set up.
https://www.astrosafari.com/gallery/album.php?album_id=1698
And here are the rear speakers. I made angled boxes that attach to the front ends of the wheel well covers with 1/4" studs and wingnuts accessible from inside the wheelwell covers. The 6" X 9" JBL's are angled up and in to intersect the sound at ear level in the front seats. With JBL's in the doors the sound is impressive coming from the Alpine receiver. The speakers have extra wire to enable them to be put outside in camping situations.
Harleybowtie
Topics: 19
Images: 45
Postby crusader1xxx » August 29th 2013, 5:44am
Wow, looks almost like a stock interior and I mean that in a good way, looks great..thanks for showing it :banana:
crusader1xxx
Years of Membership: crusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full yearscrusader1xxx has been a member for 7 full years
Topics: 25
Images: 16
Alias (AKA): Andy
Extra Info: RwD
Postby Harleybowtie [OP] » September 3rd 2013, 9:05pm
I appreciate the compliment. That's what I was going for. :chevy:
Harleybowtie
Topics: 19
Images: 45
Postby Harleybowtie [OP] » September 19th 2013, 1:07pm
Harleybowtie
Topics: 19
Images: 45
Postby scott936 » September 19th 2013, 8:26pm
Wow that awesome... you're hired come do mine....
2002 Astro Van Cargo
Air Bags
Yokohama 225/60 17
Overhead console from 92 S 10
Custom Rear Bumper
Custom front seats
scott936
Years of Membership: scott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full yearsscott936 has been a member for 10 full years
Topics: 37
Images: 20
Van Model Year: 2002
Extra Info: 2 WD Cargo
Postby Harleybowtie [OP] » September 19th 2013, 9:16pm
Thanks but I'm glad I'm almost done with mine. I tried not to lose any hauling capability by keeping the floor clear of any permanent add ons. I have a Coleman Quickbed that fits right in. Just blow it up and relax. I did an expansion for base camp. Check out this thread, Scroll down.
https://www.astrosafari.com/viewtopic.php?f=13&t=20906&start=20
Harleybowtie
Topics: 19
Images: 45
Postby SilverBullet1997 » September 19th 2013, 9:21pm
Harleybowtie wrote:Thanks but I'm glad I'm almost done with mine. I tried not to lose any hauling capability by keeping the floor clear of any permanent add ons. I have a Coleman Quickbed that fits right in. Just blow it up and relax. I did an expansion for base camp. Check out this thread, Scroll down.
Looks good, HB, you should toss those pictures over in to that thread too :D
SilverBullet1997
Topics: 54
Images: 247
Return to Projects/Builds
It is currently February 27th 2021, 10:01pm
Projects/Builds Forum
Bigforkg
in Projects/Builds
Comments: 32
Date: Feb 24 '21
Time: 3:29pm
Attached by: Sparkydog
Sparkydog
in Projects/Builds
Comments: 120
Date: Feb 23 '21
Time: 4:28pm
Sparkydog
in Projects/Builds
Comments: 120
Date: Feb 23 '21
Time: 4:13pm
JD_GM
in Projects/Builds
Comments: 48
Date: Feb 23 '21
Time: 6:03am
JD_GM
in Projects/Builds
Comments: 48
Date: Feb 23 '21
Time: 5:51am
