As it sat a short 4 months ago
P.S. please use the zoom button in the upper left of the picture as it is a better zoom than linking to photobucket gives you
I started with doing an onboard air compressor and small tank. I used a Viar 400c and a modified fire extinguisher for the tank.
The setup has been cleaned up a bit since then but it is still functionally the same
After that, a lot changed quite quickly. Pieces started arriving and I couldn’t wait to start working on the lift.
Who needs OLV brackets?
The original plan was to keep the stock leaf spring clamps so off the overload leafs came
The last picture of her ever taken at stock height ;(
The parts list so far was
6 - 2” high, 3” diameter pucks from summit
4 - M12 x 150mm class 12.9 socket head cap screws (SHCS)
2 – M14 x 150mm SHCS from Fastenal
Pair of 22-687HD springs new from SDTruckSprings
2 - Rancho RS7112 - I decided to go with the longer shock instead of changing the stock shock mount
2 - Rancho RS7150
2 - MOOG forged upper ball joints from rock auto
With all the parts, the fun could start!
