unreals build
unreals build
Postby unrreal [OP] » February 9th 2010, 11:13pm
i just installed a set of hood struts in my van, i just thought it was a good idea and it only took me an hour to do so. so heres the list :
- 2 mighty lifts part# E95212 this set will run you at about $24.00 a piece but they do come with the round bolts but (no nuts) how absurd is that!
- the nuts are gonna be M8-1.25 AND YOU ARE GOING TO NEED 4 OF THEM.
- 7/16" wrench, 12mm socket and ratchet, drill bits.
the overall dimension of the struts are from end to end 15.25" and from center hole to center hole [highlight=] 14.50"[/highlight] this is your most important measurement dont forget. and of course a couple of pictures :
at the beginning..
part number
[/attachment] sorry i forgot to take some pics.... :whistle:
AND FINALLY....
HOOD open and NO PROP ROD.... :thumbup:
AND dont forget to close the hood gently the first couple of times so that you can get used to the strength of the struts, YOU DONT WANT TO DAMAGE YOUR HOOD...
unrreal
Years of Membership: unrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full yearsunrreal has been a member for 11 full years
Topics: 22
Images: 12
Extra Info: 4.3L LS AWD
  • 02 gmc safari build
    by Rahdigs » October 15th 2020, 5:40am in Projects/Builds
    October 21st 2020, 11:25pm
  • And so it begins, my van build
    by mglsite » October 17th 2020, 11:02pm in Projects/Builds
    Last post by mglsite View the latest post
    October 18th 2020, 12:36am
    64
    April 11th 2021, 5:23pm
Re: hood struts installed!!!
Postby marcus38 » February 10th 2010, 12:23am
good post!! i was wondering if anybody on this site had done this mod yet. was thinkin about doin it but wasnt sure on the strut length. i get my struts at www.liftsupportsdepot.com where did u get those?
1990 astro CS 4.3 z engine 700r trans 2WD radical custom build
marcus38
Years of Membership: marcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full years
Topics: 35
Images: 5
Alias (AKA): mark
Postby astro355 » February 10th 2010, 12:32am
That is a nice edition. I do hate that prop rod. But I have a question.
Do you think you could have used shorter struts?
astro355
Firing on 4 Cylinders (L6)
Extra Info: 355 V8 700R4
Postby marcus38 » February 10th 2010, 12:37am
1 more question..whats the lbs. of force on that model. i think that means force to compress the strut. i see em for $15 each plus shipping on the site above. i got some 36 in from them already for my gullwing slider door. heavy duty and built well..no problems or complaints. several options also. lbs. of force,ball ends or eyelet ends. even mix matched ends!! check em out. shipped from cali to kentucky in 4 days!!
marcus38
Topics: 35
Images: 5
Alias (AKA): mark
Postby unrreal [OP] » February 10th 2010, 12:47am
marcus38 wrote:good post!! i was wondering if anybody on this site had done this mod yet. was thinkin about doin it but wasnt sure on the strut length. i get my struts at http://www.liftsupportsdepot.com where did u get those?
i got them over at my local autozone, i was looking at the big selection they had and i decided to get those because of the bolts were already included.
unrreal
Topics: 22
Images: 12
Postby unrreal [OP] » February 10th 2010, 12:59am
marcus38 wrote:1 more question..whats the lbs. of force on that model. i think that means force to compress the strut. i see em for $15 each plus shipping on the site above. i got some 36 in from them already for my gullwing slider door. heavy duty and built well..no problems or complaints. several options also. lbs. of force,ball ends or eyelet ends. even mix matched ends!! check em out. shipped from cali to kentucky in 4 days!!
unfortunately i wasnt able to find the information on the lbs. i havent even been able to find a website for them.... :confused:
unrreal
Topics: 22
Images: 12
Postby Jasen » February 10th 2010, 1:27am
This is one of the mods I've been thinking about. Nice :thumbup:
Heres another good source for gas springs, all kinds of them along with force lbs. and all the various accessories to go with them and all the info. They carry both pushers and puller.
Scroll through the page numbers at the top left highlighted in yellow.
http://www.mcmaster.com/#gas-springs/=5qyn4n
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
Postby workinVan » February 21st 2010, 2:52am
i just did the mod the other day and it was a simple 5 minute install, once i found some nuts to hold the bolts on.
I did however end up drilling to close to the backend of the hoodand had to redrill closer to the bend in thehood bracket, if anybody else is going to try it i would suggest drilling in the hood brackets first as close to that bend as possible allowing enough room for the nut you` use to contact flushly, then put the lower swivel bolt on the struts and eyeball where to drill it on the fender rails.
definately make sure you compress the struts by hand before you install them as they might be jammed up and you WILL bend the hood if you don't
mine looks exactly the same as the pics allready posted
2000 cargo 4.3 v6 W rwd, a/c, G80, silverstars, hood struts, magnaflow cat
and a big honkin air filter....possibly for sale make an offer
workinVan
Years of Membership: workinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full yearsworkinVan has been a member for 11 full years
Topics: 9
Alias (AKA): notjim
Extra Info: 4.3 rwd cargo
Postby webcat » February 21st 2010, 3:22am
How about a video of you opening and closing?
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby Leeann_93 » February 21st 2010, 4:19pm
That is the one thing I miss from my Lumina....I hate the damn prop rod on both the Bravada and the Astro. I'll have to consider this one...
Postby unrreal [OP] » February 28th 2010, 5:22am
webcat wrote:How about a video of you opening and closing?
i'll do that tomorrow when i get a chance... :)
unrreal
Topics: 22
Images: 12
Postby workinVan » March 1st 2010, 2:36am
http://smg.photobucket.com/albums/v710/ ... deo035.flv
hope this works
quick vid sorry about sounding all sick and crap
workinVan
Topics: 9
Alias (AKA): notjim
Postby JaxSPL » March 1st 2010, 3:54am
God I want to do this. Would it be any different installing these on an earlier model astro?
This is probably going to sound newbish, but.. What about measurements? How did you measure out where exactly to drill the holes for them?
"Installer's Nightmare" has officially come to life. Only 1 sub, but loud and clear.
Subwoofer enclosure designer. PM For More Info
JaxSPL
Firing on 8 Cylinders (L1)
Years of Membership: JaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full yearsJaxSPL has been a member for 11 full years
Topics: 45
Images: 9
Extra Info: 4.3L V6 SPL
Postby workinVan » March 1st 2010, 5:11am
JaxSPL wrote:God I want to do this. Would it be any different installing these on an earlier model astro?
i based mine on looking where the bolt could be mounted without hitting anything when closing the hood, you might notice on my video there is an extra hole that would be the first attempt but i couldn't get the nut on cuz i used a self locking nut that was flared at thebase
start at the mount location on the upper hood bracket and it falls into place as the lower mount can be put pretty much anywhere on the fender rail, then just mirror it on the other side.
any longer or shorter of a strut would probably cause a binding issue but longer would be less likely then shorter
workinVan
Topics: 9
Alias (AKA): notjim
Postby astroturf » March 1st 2010, 5:14am
Very Nice. Jim
astroturf
Topics: 112
Extra Info: 2wd Passenger
Postby ProStreet_LS1 » March 4th 2010, 5:10pm
Can you give us a measurement from the hood mount bolts to the strut mount? The early Astro has a different hood hinge, no bend to go by. Will probably have to modified the early Astro hood to make the struts work. Mike
1985 Pro Street Chevy Astro: parted, scrapped & upgraded to
1998 Pro Street Chevy Astro: Tubbed w/ 33x22 rear tires, 350 hp aluminum LS1 V8
PRO STREET 4 LIFE, GEARHEAD 4 LIFE
ProStreet_LS1
Years of Membership: ProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full yearsProStreet_LS1 has been a member for 11 full years
Topics: 54
Extra Info: LS1 V8 Pro Street
Postby webcat » March 4th 2010, 11:29pm
workinVan wrote:http://smg.photobucket.com/albums/v710/newmanbabies/Fish/?action=view&current=Video035.flv
hope this works
Nice , i was just wondering if there's any resistance when you go to close it , in the video i see it opens very well.
thanks
webcat
Topics: 253
Postby workinVan » March 6th 2010, 12:40am
took another video with my cell phone opening and closing.
once it reaches almost closed it shuts itself and latchs so no need to slam it
http://smg.photobucket.com/albums/v710/ ... deo039.flv
oh i forgot the measurment for a second from the hood hinge bolt to the strut mount point is 7 - 7.5 inchs
workinVan
Topics: 9
Alias (AKA): notjim
Postby astro355 » March 6th 2010, 12:47am
workinVan wrote:took another video with my cell phone opening and closing.
Yeah, that's what I want to here. Regardless of how I align that hood, you have to slam it to get it to shut.
astro355
Postby webcat » March 6th 2010, 1:49am
Yea nice , closes like magic
webcat
Topics: 253
Return to Projects/Builds
It is currently April 11th 2021, 5:23pm
Projects/Builds Forum
in Projects/Builds
Comments: 123
Date: Today
Time: 12:54am
LumaWJ
in Projects/Builds
Comments: 23
Time: 7:35pm
LumaWJ
in Projects/Builds
Comments: 23
Date: Apr 08 '21
Time: 8:19pm
LumaWJ
in Projects/Builds
Comments: 23
Date: Apr 05 '21
Time: 6:55pm
LumaWJ
in Projects/Builds
Comments: 23
Date: Apr 04 '21
Time: 6:54pm
