by dmilamj [OP] » October 14th 2015, 3:58pm
by WoodButcher » October 14th 2015, 6:38pm
by dmilamj [OP] » October 14th 2015, 8:58pm
WoodButcher wrote:If you trust the wrench I would consider that fair. While you may be able to perform a lot of this work yourself many items like the dizzy are just "on the way" to other fixes and worth doing at that time.
Things like the leaky shocks are things to put on your personal hit list and while you're there inspect / treat rust and undercoat.
by Corsemoto » October 14th 2015, 10:01pm
by dmilamj [OP] » February 12th 2016, 7:20pm
by ssbf1 » February 12th 2016, 7:41pm
by dmilamj [OP] » February 12th 2016, 8:04pm
ssbf1 wrote:I love it. What was the total turn around time, from order to completion?
by Lumpy » February 12th 2016, 8:23pm
dmilamj wrote:
Derek, over at CCV, is a nice guy and they do good work as far as I can tell, but he's a little disorganized. It's a small company and they have a lot going on.
by dmilamj [OP] » February 12th 2016, 8:49pm
by CopperFiremist
» February 12th 2016, 9:09pm
by Lumpy » February 12th 2016, 10:40pm
by WoodButcher » February 13th 2016, 12:11am
by HotWire » February 13th 2016, 1:51am
dmilamj wrote:So I was looking for a folding rear seat for the van. Most of the junkyard ones from custom vans are pretty small, only about 33" deep when folded down. They also seemed pretty cheezy.
I looked into a folding seat from qualitex, and it would have worked better, but still only 44" folded down. I need something 6 plus feet when folded down. Also, the Qualitex seats are on the order of $1100.
I came up with a plan that should create a folding seat, full width, that folds into a ~ 6' 4" bed/platform using:2 bench seats
some jackknife sofa hinges
assorted steel
some hinges
plywood 3/8" and 3/4"
other hardware
So, I headed to the junkyard and picked up a good ol' 3rd row bench seat for $40. Brought it home and took it apart.
My plan is to use the seat base and original mounting feet, so that it will lock into the OEM seat mounts. Also, all seat belt mounting locations will be maintained.
Here's the seat base with the back unbolted and the spring supports cut out:
Cut off both ends:
Weld in some 1x1 tube steel extensions to attach the folding hinges to:
Test fit the hinges:
With the hinges welded in, weld in the back:
Test fit the back in the van:
Stay tuned for more seat build photos...
by dmilamj [OP] » February 16th 2016, 4:07pm
WoodButcher wrote:Where did you find the hinges?
by dmilamj [OP] » February 16th 2016, 4:19pm
by dmilamj [OP] » February 16th 2016, 5:03pm
dmilamj wrote:WoodButcher wrote:Where did you find the hinges?
I couldn't find a supplier for these hinges so I ended up buying them off an ebay seller who was selling an entire jackknife sofa. I emailed him and made an offer on only the hinges.
I can't find any make/manufacturer info on them at all, but I have a feeling they come from Atwood in Indiana or a similar manufacturer.
by WoodButcher » February 16th 2016, 9:17pm
by dmilamj [OP] » February 16th 2016, 9:46pm
WoodButcher wrote:Maybe at retail $25 or $30 but to find a market, that would be the tough part.
Say you were able to sell 50 or 60 to those of us thinking to do what your working on, what would you do with the other 3,550 pair?
by Lumpy » February 16th 2016, 9:52pm
It is currently March 9th 2021, 11:53am
Projects/Builds Forum |
Previous topic Next topic |
Sponsors |
