So I drove out with a flat hauler and picked her up.
The outside is dentless, and I think with a little polish and elbow grease it will shine up real nice. The interior definitely shows that it hauled kids around and lived in a ranch area (gooey candy in all the pockets/carpet, dirt/grease/humansludge on everything. Took some scrubbing bubbles to the dash and it cleaned up and looked like new, so Ill be going to Costco to buy a bulk pack and soak the interior before taking the upholstery cleaner to it.
Pulled the distributor yesterday and found I was correct about the distributor, so I ordered a Skip White unit and should HOPEFULLY be able to fire this pig up in the coming weekend.
Plans are to scrub it down and get it all clean, replace the valve cover gaskets and oil pan gasket, replace the power steering pump and reservoir hose, bleed out the brakes, flush the cooling system, recharge the AC, add a tow hitch, add a 4" lift and 235/75r15 AT tires, and some lighting upgrades.
Super stoked to be back in an Astro!
