Replaced carpet
Replaced carpet
Postby dantheman [OP] » August 29th 2016, 3:37am
Lifted the carpet in the rear the other day to find the padding soaked up to the middle row. Pretty much tracked the leak down to a stopped up rear a/c drain and a leaky gasket in the rear window (driver side).
Picked up some carpet for $40 at a local warehouse and padding at Lowes for $30 and she feels like a new van again.
dantheman
Fueling (3/4 tank)
Fueling (3/4 tank)
Years of Membership: dantheman has been a member for 5 full yearsdantheman has been a member for 5 full yearsdantheman has been a member for 5 full yearsdantheman has been a member for 5 full yearsdantheman has been a member for 5 full years
Topics: 19
Alias (AKA): Dan
Extra Info: 4.3L RWD
Re: Replaced carpet
Postby markmitch » August 29th 2016, 3:40am
Looks good I took my carpet out last summer washed it hung it on my fence left it there a week to dry then I put new padding and old cleaned carpet.
Firing on 8 Cylinders (L6)
Topics: 626
Images: 21
Extra Info: RS V8 AWD
Re: Replaced carpet
Postby MI_Ghost » August 30th 2016, 2:39pm
Looks good.
If you want to add a finishing touch to it.
The 1st gen vans had removable trim pieces around the cutouts for the seat mounting holes.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Re: Replaced carpet
Postby AstroWill » August 30th 2016, 2:56pm
Looks good, makes you want to grab your SO and roll around back there ;)
Images: 472
Re: Replaced carpet
Postby Astrox2 » September 5th 2016, 11:28pm
Did you run it all the way to the front
Cannot tell from the pics. If so any more pics
And how it worked out?
Or just behind the front seats back
It does look great!!!!
Astrox2
Years of Membership: Astrox2 has been a member for 4 full yearsAstrox2 has been a member for 4 full yearsAstrox2 has been a member for 4 full yearsAstrox2 has been a member for 4 full years
Topics: 21
Images: 10
Extra Info: 4.3 v6 rwd
Re: Replaced carpet
Postby dantheman [OP] » September 6th 2016, 3:56am
Thanks!!
I'll have to shoot some more pics when I get back from Denver. I laid it all the way to the firewall. I basically kept the old carpet and used it almost like a stencil to cut the new carpet.
It's commercial grade carpet so it's very easy to vacuum and clean up.
dantheman
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 19
Alias (AKA): Dan
Re: Replaced carpet
Postby LoriB » September 12th 2016, 10:30pm
That looks really good.
I just took out my carpet and padding since it was soaking wet and growing mold. I'm using mine to haul pottery to art fairs so I just installed those rubber squares in the floor. I had to take out the plastic trim that fits around the places where the seats instal. They are tan so they should look good with your van. You can have them for a couple buck for the postage.
95 Safari
LoriB
Years of Membership: LoriB has been a member for 5 full yearsLoriB has been a member for 5 full yearsLoriB has been a member for 5 full yearsLoriB has been a member for 5 full yearsLoriB has been a member for 5 full years
Extra Info: XTL
Re: Replaced carpet
Postby jaywoo65 » September 12th 2016, 11:35pm
I've got that same leak around the rear driver's side glass. I haven't fixed it yet. Did you just put some silicone around the inside of the glass?
1999 AWD Astro - under construction
"She may not look like much kid but she's got it where it counts"
jaywoo65
Years of Membership: jaywoo65 has been a member for 6 full yearsjaywoo65 has been a member for 6 full yearsjaywoo65 has been a member for 6 full yearsjaywoo65 has been a member for 6 full yearsjaywoo65 has been a member for 6 full yearsjaywoo65 has been a member for 6 full years
Topics: 12
Extra Info: AWD baby
Re: Replaced carpet
Postby dantheman [OP] » September 13th 2016, 3:05am
I actually pulled the glass and the gasket. I put a bead of silicone under the gasket, then put it back in place. I also ran a bead of silicone along the outside of the gasket before putting the window back in place.
dantheman
Fueling (3/4 tank)
Fueling (3/4 tank)
Topics: 19
Alias (AKA): Dan
Return to Interior
It is currently March 7th 2021, 6:01am
Interior Forum
TheGreatAstroDane
in Interior
Date: Feb 04 '21
Time: 8:22pm
Arrow99
in Interior
Date: Jan 22 '21
Time: 5:25am
Arrow99
in Interior
Date: Jan 21 '21
Time: 4:55am
Attached by: MI_Ghost
MI_Ghost
in Interior
Comments: 13
Date: Jan 19 '21
Time: 6:55pm
copperhead
in Interior
Comments: 17
Date: Jan 18 '21
Time: 3:43pm
