Drivers grab handle? A pillar
Postby nonhog [OP] » January 18th 2018, 11:04pm
Never noticed one yet haven't looked too hard. Typical searches show nothing. My knee is trashed and thinking how the van seating style is nicer than the car with a knee that wont bend.
I can pull myself up on the RH grab handle which works great since its my RH knee that is messed up.
Ergonomics don't play as well on the LH side. My luck. Probably too crippled to fab something anyway.
Curious..... and bored, Netflix is getting old fast. :banghead:
Recovering hoarder
My Slow build..... viewtopic.php?f=127&t=107426
nonhog
Firing on 7 Cylinders (L1)
Years of Membership: nonhog has been a member for 4 full yearsnonhog has been a member for 4 full yearsnonhog has been a member for 4 full yearsnonhog has been a member for 4 full years
Topics: 37
Images: 16
Van Model Year: 1996
Re: Drivers grab handle? A pillar
Postby TurnNburn » January 19th 2018, 12:23am
I think the General assumed that you would be using the steering wheel to pull yourself in. If you grabbed a right side handle it shouldn't be to hard to fab it into the other side. Making it look good, or like it belongs will be the trickier part
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby nonhog [OP] » January 19th 2018, 12:30am
TurnNburn wrote: Making it look good, or like it belongs will be the trickier part
Always looks great and works great in my head. LOL
Recovering hoarder
nonhog
Topics: 37
Images: 16
Postby TurnNburn » January 19th 2018, 12:48am
I am more along the lines of, if it works great, then it looks great.
TurnNburn
Green Status (L4)
Green Status (L4)
Postby MI_Ghost » January 19th 2018, 3:23am
Much the same reason I got my '88 Astro. I had a bad left knee and the astro was just easier to get in and out of vs dropping down into a car. My method for driver side entry was back to the seat. Use good leg in step well to push up with. Hands braced on A&B pillars.
The A-pillar is plenty strong and will handle the stress of adding a grab handle with no problems. Like TnB mentioned you can easily grab either passenger or slider grab handles and mount them will minimal effort. Just make sure you use a solid mounting fastener like a rivnut or jacknut.
And just to throw and idea at you. Handles on both A&B pillars work extremely well. You could even add one across the top if need to help pull yourself up with.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby nonhog [OP] » January 19th 2018, 5:25am
Thanks guys!
I'm hoping my knee will get better w/o surgery. Funny thing is I don't feel well enough to work on this project and by the time I do I may not need it?
I will follow through as my wife might drive it on a rare occasion. She is little. :D
Recovering hoarder
nonhog
Topics: 37
Images: 16
Postby TurnNburn » January 19th 2018, 6:28pm
I would stay away from a rivnut for this particular use. they are good for mounting stuff to other stuff, but if someone is going to be yanking on it a couple of times ever day I don't think they will last in sheet metal. I suggest a plusnut instead
TurnNburn
Green Status (L4)
Green Status (L4)
Postby Old Barney » January 19th 2018, 6:56pm
I will peal the plastic away from the pillar and above the door on my 1999 Astro donor van and see if the factory has added threaded holes for a grab handle some times assembly line even leaves dimples for future drilling for handles and such. If so I'll take photo of bare metal pillar. If there is threaded holes I can send the right handle for you to use maybe adapt it?? remember "up with the good down with the weak"
Old Barney
Years of Membership: Old Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full years
Topics: 23
Images: 47
Alias (AKA): Barney
Extra Info: awd
Postby nonhog [OP] » January 19th 2018, 7:22pm
Old Barney wrote:I will peal the plastic away from the pillar and above the door on my 1999 Astro donor van and see if the factory has added threaded holes for a grab handle some times assembly line even leaves dimples for future drilling for handles and such. If so I'll take photo of bare metal pillar. If there is threaded holes I can send the right handle for you to use maybe adapt it?? remember "up with the good down with the weak"
Cool thanks! I cant help but wonder if they do have holes for RH drive vans? (if there is such a thing?)
Recovering hoarder
nonhog
Topics: 37
Images: 16
Postby WimpTech » January 19th 2018, 7:25pm
good question, the one i saw in Japan was LH drive though... doesn't mean they don't exist!
WimpTech
Firing on 3 Cylinders (L5)
Years of Membership: WimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full yearsWimpTech has been a member for 4 full years
Topics: 38
Images: 322
Alias (AKA): =Wimpy=
Extra Info: AWD 3+1 Lift
Postby Big_kid » January 20th 2018, 3:48am
I think I saw pics of a one off RH drive conversion someone was working on once. If I didn't imagine it, I saw it here. Other than that one I don't believe they exist. I also noticed today for the the first time that Ford vans have a driver side grab handle. At least my buddy's work van has one.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby GreatWhite » April 25th 2018, 8:46am
Barney, did you ever investigate that pillar? I'm looking into installing one as well. Climbing in with a sore back after work can be less than pleasant.
'04 GMC Safari SLT AWD
'07 Honda Element AWD
'97 Nissan Hardbody 4x4
https://www.youtube.com/watch?v=HWAAXrlt43s
GreatWhite
Years of Membership: GreatWhite has been a member for 4 full yearsGreatWhite has been a member for 4 full yearsGreatWhite has been a member for 4 full yearsGreatWhite has been a member for 4 full years
Topics: 18
Extra Info: AWD SLT 3+1 Lift
Postby GreatWhite » June 7th 2018, 4:49am
Still haven't gotten around to this. Haven't had time to mess around at PNP. Anyone have a pic of the A pillar without the molding? Could really use a grab handle mod.
GreatWhite
Topics: 18
Postby nonhog [OP] » June 7th 2018, 5:12pm
Dang it! I should have looked at the PnP.
Recovering hoarder
nonhog
Topics: 37
Images: 16
Return to Interior
It is currently December 1st 2020, 1:18am
Interior Forum
nwmod39
in Interior
Time: 3:24am
nwmod39
in Interior
Date: Nov 28 '20
Time: 3:21am
nwmod39
in Interior
Comments: 18
Date: Nov 27 '20
Time: 1:12am
Attached by: Birdshake
Birdshake
in Interior
Comments: 18
Date: Nov 26 '20
Time: 4:29am
nwmod39
in Interior
Comments: 18
Date: Nov 25 '20
Time: 4:41am
