Driver door wont open manually
Postby Pierrot from Chile [OP] » July 3rd 2018, 10:50pm
New riddle for me : i cant open or close my driver door with my key nor pushing the lock manually. Only with central command.
First day since i got my car it rained a lot. I left my car unattended but doesnt look forced.
I'm very concerned because since now my passenger door and hood locks never worked, so now my only door which i can go through is my rear door...
Pierrot from Chile
Years of Membership: Pierrot from Chile has been a member for 2 full yearsPierrot from Chile has been a member for 2 full years
Topics: 5
Alias (AKA): pierre
Extra Info: 4.3 v6 rwd
  • to open rear doors from inside-idea
    by markmitch » June 20th 2020, 6:16pm in Interior
    Last post by augidog View the latest post
    July 18th 2020, 7:01pm
  • Door issues
    by mutable » May 17th 2020, 2:21am in Interior
    Last post by Old Barney View the latest post
    May 17th 2020, 2:50am
    87
    October 30th 2020, 7:54am
Re: Driver door wont open manually
Postby TurnNburn » July 3rd 2018, 11:00pm
by open and close, do you mean lock and unlock?
TurnNburn
Green Status (L4)
Green Status (L4)
Alias (AKA): iGoogle
Postby Pierrot from Chile [OP] » July 3rd 2018, 11:17pm
Yes sorry lock and unlock, it feels hard when i turn the key or when i push on the manual lock
Pierrot from Chile
Topics: 5
Alias (AKA): pierre
Postby TurnNburn » July 3rd 2018, 11:23pm
But works from the electrical switch?
Probably the door lock actuator giving up the ghost
TurnNburn
Green Status (L4)
Green Status (L4)
Postby dchan51360 » July 3rd 2018, 11:26pm
or the linkage from the key to the locking mechanism is binding on something.
dchan51360
Firing on 7 Cylinders (L1)
Postby multimoto » July 3rd 2018, 11:27pm
seems more like a mechanical linkage issue to me. or probably just a clip that holds one of the rods.
'87 GMC Safari Explorer
multimoto
Years of Membership: multimoto has been a member for 2 full yearsmultimoto has been a member for 2 full years
Topics: 12
Images: 369
Van Model Year: 1987
Extra Info: Explorer
Postby dchan51360 » July 3rd 2018, 11:28pm
I would take a look inside both and see if those linkages are connected properly and moving freely. (passenger and drivers) it could be why you can't operate the lock on the passenger side too.
dchan51360
Postby Pierrot from Chile [OP] » July 3rd 2018, 11:29pm
Ok i gave another try and i forced it a little bit more, and it worked i could unlock it. Everything is ok untill i lock it with the central command and its going harder again...
Pierrot from Chile
Topics: 5
Alias (AKA): pierre
Postby Pierrot from Chile [OP] » July 3rd 2018, 11:30pm
Yes its look like something is not moving freely now, and i guess its because of the humidity
Pierrot from Chile
Topics: 5
Alias (AKA): pierre
Postby Pierrot from Chile [OP] » July 3rd 2018, 11:54pm
How hard is to open door panel on a 2003 ? And what should use to lube if i need to ?
Pierrot from Chile
Topics: 5
Alias (AKA): pierre
Postby dchan51360 » July 4th 2018, 12:54am
Not hard, just takes patience and a thin screwdriver. Work your way around the panel carefully to pop the holders without pulling hard on the actual internal panel.
I used lithium grease (white grease) because it rarely gets gummy or hard. even in freezing conditions. Clean up all the connections with a little bit of alcohol or de-greaser, then lube. hinges and lock mechanisms I used triflow (teflon spray) what ever you do, do NOT use wd40.. that stuff will dry and harden.
dchan51360
Postby Pierrot from Chile [OP] » July 4th 2018, 1:05am
Ok thank you DC, i need to find all of this here in bolivia because i got only wd40!
Pierrot from Chile
Topics: 5
Alias (AKA): pierre
Postby dchan51360 » July 4th 2018, 4:20am
Any bicycle shop and automotive shop will have white grease. Sometimes called assembly grease for people that do machine work/engine building. Triflow is usually avail at home improvement stores and lock smiths.
Just to give you some ideas where to look.
dchan51360
Return to Interior
It is currently October 30th 2020, 7:54am
Interior Forum
95AstroLT
in Interior
Date: Oct 18 '20
Time: 4:54pm
Olivier02
in Interior
Date: Oct 11 '20
Time: 8:19pm
erykahmccarty
in Interior
Date: Oct 04 '20
Time: 9:52pm
Safariescapepod
in Interior
Date: Sep 19 '20
Time: 10:31pm
SoccerMom4x4
in Interior
Date: Sep 15 '20
Time: 1:45am
Users browsing this forum: Google Adsense [Bot] and 15 guests
